Old Jul 18, 2014, 01:02 AM
United States, MD, Frederick
Joined Jun 2014
ESC for SunnySky X3508S KV580
I have been looking for ESC's to go with my SunnySky X3508S KV580 http://www.buddyrc.com/sunnysky-x350...ess-motor.html I just ordered and was about to go with these http://www.ebay.com/itm/ZTW-SPIDER-S...item58b0495e51 ZTW Sprider 30A ESCs until i read the following post
"you only need one ubec and that will power your board and receiver with 5 volts. Just tap into your battery connector and your good to go. When an esc has no bec commonly called opto, that means it does not supply any power to the flight board or rx, so you need a ubec. If you are using pancake style motors that esc does not work well, the version off Simonk firmware causes the motors to stop when given full throttle. I exchanged mine for the ipeaka ones from altitude and they work great." - http://www.rcgroups.com/forums/showthread.php?t=2149482
I am not very notigable yet and most of that is over my head but I think the motors I have are considered pancake motors so I am trying to see if that means I should stay away from SimonK or Opto or what! I am trying to find a good 30amp for under $16 each (preferably on ebay because i have credits to use that are expiring.
Any suggestions are appreciated.
MarylandFly is offline Find More Posts by MarylandFly
For Sale SunnySky V3508-20 KV580 Brushless Motors quadcopter Tonycapil Aircraft - Electric - Multirotor (FS/W) 3 Jun 12, 2014 01:41 PM
Discussion Which props for Sunnysky x3508s 700KV airfix Multirotor Talk 3 May 12, 2014 09:11 AM
Wanted SunnySky V3508-20 KV580 Brushless Motor 1morehobby Aircraft - Electric - Multirotor (FS/W) 7 Mar 05, 2014 06:34 AM
Sold 4x sunnysky 3508-20 kv580 john howard Aircraft - Electric - Multirotor (FS/W) 1 Dec 17, 2013 10:40 AM
Discussion Where to buy Hengli w4225 610kv or SunnySky V3508-20 KV580? MARTYNOLY Multirotor Electronics 1 Nov 21, 2013 09:59 PM
