Old May 14, 2013, 06:23 AM
Joined May 2013
is it dangerous to cut small triangle in the wing to fit retracts?
Hi...
I'm new in this forum and i would like to have your opinion for a problem i have or maybe better... a solution...
Lately i bought a set of electric retracts to my hangar 9 spitfire , which did not fit to my plane...
While fitting it i hat to cut a triangle hole in the bottom side of the wing, as can be seen in the pictures.
I'm am afraid that a air that will go into the wing will tear the wing a part.
What shell i do?
I did not fit the other wheel since i did not no if to do the same or to remove the triangle part from the retracts...
AidoSsy is offline Find More Posts by AidoSsy
Old May 16, 2013, 10:42 PM
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Box it in from underneath... I would not keep an open area like that. The wing won't be torn apart but don't want to have a large hole there either...
Thermalin is offline Find More Posts by Thermalin
Discussion How do I KF a triangle wing? himeros Foamies (Scratchbuilt) 7 Jan 16, 2013 01:27 PM
Discussion AAAA batteries to power small R/C glider? Hidden in 9V battery? ***DANGER***!!!!!!! Little-Acorn Scratchbuilt Indoor and Micro Models 9 Aug 28, 2009 06:38 AM
Discussion ***DANGER*** - cheap&easy small batteries for small, cheap 24" styro glider Little-Acorn Batteries and Chargers 5 Aug 27, 2009 02:03 PM
Fitting Retracts in a foam wing?? lordspyro The Builders Workshop 0 Feb 24, 2005 11:39 AM
