Old Feb 27, 2015, 12:02 AM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
That's ok. We need one for testing, but thanks!
JimDrew is offline Find More Posts by JimDrew
Old Feb 27, 2015, 08:55 AM
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
Originally Posted by HiFlite View Post
Is there any way that I can disable my 14SG from transmitting on one model? I am running DragonLink for control and the 2.4 transmitting drains the battery. I found that with the throttle cut engaged the 14SG will ask whether or not to transmit. Is there any way to disable it completely?
I'm not sure that it can be disabled by model but what you can do is use the trainer port where your dragon-link is plugged in to turn on the transmitter. This is simply accomplished by providing a logic high signal to the Vswitch / Vin pin on the trainer port. There is a diagram of this here:
http://cankov.com/modelairplane/futaba/t8fgs-dm8002.jpg
Hope this helps.
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Feb 27, 2015, 10:04 AM
Retreating Blade Stall
Arcturus97's Avatar
United States, VA, Woodbridge
Joined Apr 2011
You can also hold the RTN button when switching on the transmitter. This will give you a menu of Range Check, RF Off, and RF On. The last model used will be active and shown in bottom right of the screen. I'm not aware of any means to permanently disable transmit by model.
Arcturus97 is offline Find More Posts by Arcturus97
Old Feb 27, 2015, 02:21 PM
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
Hope this helps.
- Birger
Please note that Vin is actual power to the encoder not just logic high signal. The current draw is relatively low (100-200mAh) but definitely higher than a logic signal can provide (1-5mA).
Ivan
ivanc is offline Find More Posts by ivanc
Old Feb 27, 2015, 03:01 PM
X-Hover Team Pilot
HiFlite's Avatar
United States, HI, Maui County
Joined Mar 2013
Hope this helps.
- Birger
Thanks Birger. I might give that a try.
Thank you Arcturus. I used to do that but you have to repeat it every time you restart the radio.
HiFlite is online now Find More Posts by HiFlite
Old Feb 27, 2015, 03:21 PM
S.A.D. member
ivanc's Avatar
Joined Dec 2004
For my BNFs which I fly with an external RF module I put the throttle stick in the middle before turning the power on or selecting a new model. Very easy to do. And even if I forget to do it and the internal RF is running it won't hurt anything other than using a little extra power.
Ivan
Old Feb 27, 2015, 04:38 PM
X-Hover Team Pilot
HiFlite's Avatar
Joined Mar 2013
Ivan
Thanks Ivan. I fly FPV with 2.3 GHz video so if I don't turn off the 2.4 on the radio there will be some interference. That sounds like it might be the easiest way to disable the 2.4 from transmitting.
Old Feb 27, 2015, 06:06 PM
S.A.D. member
ivanc's Avatar
Joined Dec 2004
Just make sure throttle position warning is enabled which it is by default but you may have disabled it.
Ivan
Wanted Futaba 9cap\JRXP9303 Airplane\FUTABA 10C tx wanted Defacto Aircraft - General - Radio Equipment (FS/W) 8 Mar 26, 2013 07:54 PM
Whoops! The Futaba 8J S-FHSS is better than Futaba 18MZ S-FHSS! The 8J may get Telemetry... SimonChambers Radios 1 Jul 09, 2012 05:54 PM
Sold Genuine Futaba GY401 gyro with Futaba S9650 servo BD Flyer Aircraft - Electric - Helis (FS/W) 1 Jul 01, 2012 11:33 PM
Sold Genuine Futaba GY401 gyro with Futaba S9650 servo BD Flyer Aircraft - General - Radio Equipment (FS/W) 3 Jun 27, 2012 10:47 PM
Sold Futaba S9650 Digital Servo + Futaba Gryo GY401 / Futaba 2.4GHz 8Ch R608FS wefao Aircraft - General - Radio Equipment (FS/W) 4 Mar 10, 2012 09:45 PM
