Old Dec 18, 2014, 12:59 PM
Joined Feb 2013
Build Log
1.8m pw51 plank 4 servo
This winter decided to experiment with glass fibre and lost foam construction. Had a trial go with a lost foam fuselage. Interest in planks from last winters build at this link - balsa construction of 1.5 and 2.4 metre planks.
http://www.rcgroups.com/forums/showthread.php?t=1916599
going to keep with the four servo wing construction. Plan to use blue craft foam as wing cores and then glass on the outside. Wing to have carbon fibre tube spar and tow spars. I have blue foam in 10 mm thick sheets so will glue several sheets together to make up the thickness. Span to be 1.8 metres, with MAC around 250 mm, root chord 290mm. Ailerons/elevons 60 mm.
For the fuselage going with a pw51 outline, and using the blue foam in a lost foam fuselage method. Tail fin - eta shaped and 8% wing area.
sketches of the plank are attached.
Andynrose is online now Find More Posts by Andynrose
Old Yesterday, 04:57 AM
Joined Feb 2013
wing panel - 3 layers of 10 mm foam stuck together with pva adhesive. channels sanded for carbon fibre spar and servo wires. airfoils shape sanded using Mark Drela's method - marked on intermediate bevel points at selected locations then joined the dots to form sanding lines. Craft foam shapes sanded with 120 grit then 320 grit.
Old Yesterday, 08:38 AM
Joined Feb 2013
in preparing the foam for laying glass fibre, the foam was absorbing a certain amount of laminating resin. a little discussion on the composite forum to see if it should be sealed. link is here
http://www.rcgroups.com/forums/showthread.php?t=2296124
tested a few samples, and applying pva adhesive followed by a light sanding reduced the absorption, and improved the sanded foam finish.
Old Yesterday, 11:33 PM
skumgummi dave
Gresham, OR.
Joined Mar 2004
Lurking...
foamdave is online now Find More Posts by foamdave
Old Today, 12:14 PM
Joined Feb 2013
stuck four sheets of 10 mm foam together and cut then sanded to rough shape (pw 51 airfoil shape - modified on rear to accommodate tail fin. Previous attempt at lost foam fuselage had tail and fuselage joined. Struggled to remove all the foam residue with a one piece construction, so thought i would go with a fuselage and separate tail fin. fuselage is 40 mm at its widest. Once achieved a reasonable shape i parcel taped the centre section in preparation for making canopy hatch and cowl to cover the wing. Might go with a single canopy hatch that extends from the front from the reciever/battery access over the wing seating area to the tail fin. not decided as yet.
Build Log PW51 plank build c.walker Slope 18 Dec 18, 2014 05:07 AM
Build Log Drive65 PW51 plank (Was: Anhedral/Dihedral and washout in planks) +video! Crashaholic Slope 117 Sep 21, 2008 08:17 AM
Sold Omega 1.8M with 4 servos N3KM Aircraft - Sailplanes (FS/W) 9 Nov 16, 2007 06:40 AM
Discussion Recommendations Wanted for PW51 Plank Planform screamin' eagle Slope 33 Mar 15, 2007 08:56 PM
Discussion soure for pw51 airfoil for a plank? Ryan Archer Slope 10 Mar 02, 2007 05:17 PM
