Old Oct 26, 2014, 11:57 AM
Joined Apr 2012
Range issues (multiple) OPENLRS and FrSky
Hi
I have tried to solve my severe range problems for some time. (if it helps i can up load the recording of my last flight, including OSD)
I have the following setup
Plush ESC 30A
RvOSD 5.1
Orange Open LRS (latest firmware) RX
Orange open LRS 1w (latest firmware) TX (programmed in mode 7 = 1w)
I have build my own RSSI connector (capacitor and resistor)
Horizon 1080 HD
400mw "boscam" video TX (cloverleaf antenna)
600tvline "sony" board camera
Radio is a Turnigy 9X (custom firmware)
the RC RX antenna is all the way back on the horizontal stabilizer, GPS i located on the tail boom. ESC all the way forward together with FPV camera. On the "hood" i got the Horizon recording camera and just behind i have the Video TX. In the middle of all this i got the RC RX and the OSD.
I have tried stock antennas, Sander style on RX and RMILEC on TX. I have now built my own IBcrazy V antenna.. results are the same I have about 500m rage and RSSI drops fasts (RC TX is beeping like hell). I first thought that this had something to do with the LRS system so i changed to FrSky diversity / telemetry system and it suffers from the exact same symptoms
So i start to wounder if there is something very noisy within my setup that is causing this issues for me, but without an spectrum analyzer i don't know where to start.. Anyone on here whom might have an idea or whom have suffered from the same kind of range issue on both 2,4Ghz and 433Mhz?
if it matters, everything share the same ground (except the horizon HD camera who has its own battery).
I have eliminated the Horizan HD cam, same problems even if powered off.
swefpv is offline Find More Posts by swefpv
Old Oct 28, 2014, 02:38 PM
Joined Apr 2012
i gave up, purchased a dragon link..
Old Nov 16, 2014, 05:44 PM
Joined Nov 2010
Try upgrading the firmware to Openlrsng. The stock firmware on these things is terrible. I've been out 3 miles an could probably go a lot farther.
Use Google Chrome and install this add on: https://chrome.google.com/webstore/d...imbdkgnpndjnkl
Be sure you upgrade your tx and rx.
utjason8 is online now Find More Posts by utjason8
Old Nov 16, 2014, 08:07 PM
Unemployed mattress tester
Qwin's Avatar
United States, GA, Kennesaw
Joined May 2011
did that fix it?
Qwin is online now Find More Posts by Qwin
Discussion Mavlink on 9xr via 3dr radio without frsky or openlrs. jt41time Multirotor Electronics 4 Oct 17, 2014 08:51 PM
Question ORANGE OPENLRS range with stock ant? matanmax Radios 1 Oct 17, 2014 01:02 AM
Sold FrSky L9R Long Range Receiver (9/12ch Non-Telemetry) Chad2323 Aircraft - General - Radio Equipment (FS/W) 0 Oct 03, 2014 04:04 PM
Discussion Orangerx Openlrs your setup and range. bbells FPV Talk 0 Sep 21, 2014 08:22 PM
Discussion OpenLRS 1W range issue halloweenlv Radios 4 Sep 15, 2013 01:38 PM
