Old Nov 10, 2013, 05:22 AM
KK4EHM--FPV Mon!
3DMON's Avatar
United States, FL, Sebastian
Joined May 2005
Pins 4 and 5 must be connected to activate the live out.
3DMON is online now Find More Posts by 3DMON
Old Nov 10, 2013, 05:54 AM
dayanki's Avatar
Joined Dec 2010
Hi. The question is where they must be connected. I believe that, according to my schematics, the pin 4 is however connected to ground, where is also connected the pin 5.
dayanki is offline Find More Posts by dayanki
Old Nov 10, 2013, 06:32 AM
KK4EHM--FPV Mon!
3DMON's Avatar
Joined May 2005
They just need to be shorted together, which means they are both connected to ground.
Old Nov 10, 2013, 08:18 AM
Joined Nov 2010
Originally Posted by dayanki View Post
Hi to all. The video-out cable supplied with the Mobius is stiff and heavy.
I built my following the attached drawing. I hope you find it useful.
DO NOT use the cable like you posted. I'm not sure what will happen if you do, but if some +V leaks into pin #4 you could be in for big trouble.
I've posted a technical reply in the main Mobius support thread.
BTW, try and avoid cross-posting in the future .
Isoprop is offline Find More Posts by Isoprop
Old Nov 10, 2013, 01:17 PM
Don't be popular, be right.
United States, FL, Port St Lucie
Joined Aug 2004
How exactly does voltage "leak" onto a pin? It's either connected or it isn't. The video and power grounds are going to be bonded somehwere anyway especially if power is supplied by a VTX with only a common ground.
bigddybn is offline Find More Posts by bigddybn
Old Nov 10, 2013, 03:39 PM
define("BEASTMODE", "1");
KeithLuneau's Avatar
United States, LA, Moreauville
Joined Jan 2002
It's possible, look at the theory behind a "floating ground" and ground loops. It's best to short the two pins at the connector, even if you still run two ground wires out.
KeithLuneau is online now Find More Posts by KeithLuneau
Old Nov 11, 2013, 01:52 AM
Joined Nov 2010
Exactly, but I wasn't thinking so much about a floating ground but rather that pin #4 was being used as a ground when it isn't a ground! Pin #4 expects to be grounded, it does not expect to be misused as a ground. If you use it as a ground when you don't have a ground because pin #5 was left disconnected, current may very well try and flow thru the internal components making it's way to pin #4. I don't know how pin #4 is wired, but in the worse case you could destroy your camera if you use pin #4 as a ground. Pin #4 is a sense pin (it senses ground), it is not a ground. The sense circuitry most likely expects either an open connection (probably pulled high under normal conditions when a ground is present) or a ground. It certainly wasn't designed as a return path for current to the power supply, which the original poster wanted to do.
Old Nov 13, 2013, 03:06 PM
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
What plug was used? Is it the stock one and removed the plastic or is a new usb plug?
I'm considering doing the same or like I did on the #16 install a plug socket in the case.
IceWind is offline Find More Posts by IceWind
Old Nov 13, 2013, 05:03 PM
dayanki's Avatar
Joined Dec 2010
Thanks again, Isoprop. I modified the connections bridging between pins 4 and 5 and connecting the ground wires to pin 5.
I bought the plugs here
Old Nov 14, 2013, 02:35 AM
Joined Nov 2010
Your new schematic is now PERFECT
Old Nov 14, 2013, 02:48 AM
IceWind's Avatar
Joined Feb 2005
I forgot to say but I say it now.
That cable gets super clean! Way way way....way better than the stock one.
Thanks for the link dayanki!
Old Nov 14, 2013, 07:30 AM
Mortimer's Avatar
Joined Apr 2010
Very interesting link. Thanks.
Mortimer is online now Find More Posts by Mortimer
Latest blog entry: 5V Power Supply
Old Nov 18, 2013, 07:01 AM
AKCobra's Avatar
United States, RI, Cumberland
Joined Feb 2013
Here's an easycap capture flying fpv using my möbius on my blade 350qx. The video is a little glitchy because I was flying from inside my house, and the image I see in the fatsharks is better than what is represented here. You lose a lot of detail in file conversions and YouTube compression.
Blade 350 QX FPV: Flying From Inside My House at 5.8 Ghz using a Mobius as my FPV cam! (4 min 34 sec)
AKCobra is offline Find More Posts by AKCobra
Old Nov 18, 2013, 08:08 AM
Where we going, we need roads
Jake Bullit's Avatar
Southport,N.W. England
Joined Nov 2007
If I power mobius from my rx using the adapter, can I be sure it won't cut out, even if the card were to get full?
Jake Bullit is offline Find More Posts by Jake Bullit
Old Nov 18, 2013, 01:11 PM
Joined Aug 2004
Well you can never be sure but mine did fill it's card in the air once. You get a "card full" in the middle of the screen but don't lose the picture. There have been several firmware updates since then so not sure if something has changed but I wouldn't worry about that particular issue.
Discussion FPV'ing successfully using tricopter/tcopters - tell us how you did it? shauntot FPV Talk 7 Apr 24, 2013 02:55 PM
Discussion Question about using computer monitors for FPV Koo FPV Talk 2 Feb 13, 2013 01:13 AM
Discussion OT, for those still on the fence about GoPro cams for your FPV needs. bgnome Dock Talk 9 Sep 19, 2012 12:59 PM
Discussion FPV cam your daughter would approve: Barbie Cam Steph280 FPV Talk 14 Aug 12, 2010 10:09 PM
Discussion Building Clear Canopy's for your FPV cams... IamLegend FPV Talk 2 Nov 16, 2007 02:50 PM
