Old Jul 02, 2013, 11:21 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Hobbymate HB800 V2.0 Flybarless 3-Axis Gyro
Looks like Hobbymate have released their MB clone gyro with v2.0 firmware. Currently it's on special at Target Hobby and is only $39.90.
http://www.targethobby.com/hobbymate...p-4162190.html
It states that it supports satellite/sum signal, but we will have to wait for someone to report that it actually works, as they have stated this in the past, when it hasn't.
Update: Satellite support for this unit has now been proven. Note, you must use the correct adaptor cable.
Also remember that the pots on the HB800 v1 worked backwards. I'm not sure whether this one will be the same.
Attached is the HB800 v2 manual.
beenflying is offline Find More Posts by beenflying
Old Jul 03, 2013, 12:48 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I'm intrigued that they have greyed out the 560us box in the HB800 v2 manual (note the different shade of grey). In the MB v2 manual it shows that it's supported:
Old Jul 03, 2013, 01:20 AM
No Longer Active
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
Dave, I would of thought with the current technology that people have now days. They wouldn't struggle that much in reverse engineering. But yet it seems they still do. They get close, but no cigar. Not yet anyway. It's still good, but not the real deal. I'm just picturing these people doing it. Going at it, to crack the code
pitchp is offline Find More Posts by pitchp
Old Jul 03, 2013, 11:47 AM
Joined Oct 2012
A very basic question, how will this be different from the turnigy 3d-h?
Lentar is online now Find More Posts by Lentar
Old Jul 03, 2013, 03:03 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
This unit has the v2 firmware, whereas the 3D-H is v1. There were a lot of improvements in v2, especially regarding the tail and sat/sum signal was introduced.
Old Jul 04, 2013, 01:30 PM
Canada, ON, Ottawa
Joined Jun 2009
Shouldn't the FW be upgradable, say from V1 to V2?
Wasp09 is offline Find More Posts by Wasp09
Old Jul 09, 2013, 01:48 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
No the firmware is not upgradable, because the boot code does not have the correct decryption routine to flash the MB firmware. It will most likely brick the gyro.
Old Jul 09, 2013, 01:51 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
This gyro is better value than the 3D-H and using the v2 firmware and should perform better as well. Make sure you use the HobbyKing price war option, if you really want that one, to get the price lowered, even though the 3D-H is v1. I must say IMO the 3D-H does have a nicer looking label.
Old Jul 14, 2013, 12:26 PM
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
How can you tell what firmware it is other than the manual? Just wondering if there is a way to find tell for sure.
efx is online now Find More Posts by efx
Old Jul 14, 2013, 04:10 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
It might show up in the BX Microsettings & Updater tool, which was support from v2.0.0 onwards, but you would need the BX USB adaptor.
Old Jul 14, 2013, 07:37 PM
Canada, ON, Ottawa
Joined Jun 2009
Is it AVR based? Can we flash this thing via ISP?
Old Jul 14, 2013, 07:48 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
It's an Arm processor.
Old Jul 14, 2013, 10:59 PM
mligosh's Avatar
New Smyrna Beach, FL
Joined Jun 2005
Anybody try this yet?
mligosh is online now Find More Posts by mligosh
Old Jul 14, 2013, 11:29 PM
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Thanks. I was just curious about that. So unless you have a BX then it's just a guess like HK's...or I guess someone can also try the satellite receivers too, but I think you still need another piece to connect those too? Well they work fine with what I have so far but it's good to have other options. What's the processor on HK's? They erased those for whatever reason which I thought was weird.
Latest blog entry: CNC Gimbal
Old Jul 19, 2013, 09:30 AM
stormheli's Avatar
United States, NY, Greenfield Center
Joined Mar 2012
has anyone done a setup video for this unit?
stormheli is offline Find More Posts by stormheli
Discussion Hobbyzone TGZ380 Flybarless 3 Axis Gyro System kgd1 Mini Helis 752 Apr 19, 2014 09:03 PM
Off Site 3 CopterX (CX-3X1000) Flybarless 3-Axis Gyros, USB, Bluetooth Adaptors Heli stretch1100 Aircraft - General - Radio Equipment (FS/W) 6 May 25, 2013 11:05 PM
Wanted Wanted Bigoale or Hobbymate HB800 fbl gyro snackdaddy185 Aircraft - Electric - Helis (FS/W) 1 May 22, 2013 03:53 PM
Sold Align 3GX nib 3 axis gyro flybarless system viper7 Aircraft - Electric - Helis (FS/W) 0 Feb 24, 2013 11:33 PM
Sold Hobbymate HB800 3 Axis FBL controller BeastX V1 clone Dan37tz Aircraft - Electric - Helis (FS/W) 2 Nov 19, 2012 12:59 PM
