Old Today, 01:42 AM
markzz is online now
Find More Posts by markzz
Joined Jun 2015
Balance charging taking waaaaay too long
I am paralleling balance charging some Turnigy 4S 5Ah Hard Cases.
Its sitting at 0.2A, 16.77V and put in about 00189. It was set to 5A originally and 4S.
My 4 cells are 4.17, 4.17, 4.22, 4.17.
Before the cells were off by 0.07V, so I tried to discharge down to an even number where they were all close, then balance charge them up again. Of course I stopped and started the process but I think I will just leave it as is, because the delta V is a concern for me now. I still need to do another 2 batteries on the same pack, I thought my parallel board was messing something up, as some of the leads in the 4S connector on the parallel board are sticking more out then the rest because of "Mr. Sparky"
......See now its been 30 minutes, its dumped 00223 into it.
markzz is online now Find More Posts by markzz
Old Today, 02:35 AM
jiggz is online now
Find More Posts by jiggz
"its not a hobby its obsession
jiggz's Avatar
United Kingdom, Meopham
Joined Jul 2014
It does take a while to balance ...don't let the cells go beyond 4.20 if they do u run the risk of fire or explosion..
I charge mine at 2a
If the Batts r new 3.17 should b fine just don't over do the discharge in the model ..after a few cycles the Batts should start to balance out properly..
Jeff
jiggz is online now Find More Posts by jiggz
Old Today, 02:59 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
If you are parallel charging several (how many) 5Ah packs at only 5A total you'd expect it to take quite a while.
Steve
slipstick is online now Find More Posts by slipstick
Help! LiPo battery taking too long to charge Tyler103 Batteries and Chargers 10 Jun 30, 2012 10:44 AM
Discussion Charging at higher C takes longer - Balancer Too Slow DKNguyen Batteries and Chargers 12 Jun 20, 2010 05:44 AM
Discussion Takes too long to charge skate5290 Batteries and Chargers 4 Jun 05, 2008 03:57 PM
First time LiPO charging taking too long on Schulz drabunich Batteries and Chargers 4 Mar 27, 2004 05:07 PM
8 cell 800Mah battery charging takes too long? try2fly Power Systems 12 Feb 04, 2002 06:40 PM
