Old Sep 09, 2014, 01:35 AM
Dogdude is offline
Find More Posts by Dogdude
Joined Aug 2012
Goodluckbuy 250 Mini Quadcopter aka GLB QAV250
Yeah, dodgy naming by GLB I know
http://www.goodluckbuy.com/qav250-fi...pcb-board.html
Anyway, here's a first flight with the Dart 250
Hobbyking Dart 250 Mini Quad QAV250 Blackout (1 min 57 sec)
It's a very high quality frame weighing in at a mere 136 grams with all fittings (no electronics)
It's a clean and dirty system with two top plates and two bottom plates
It has the PCB built into the board for power distribution with more solder points than you'll ever need, also an XT60 can be soldered directly to the rear with no need for cables (cool)
The ESC's fit nicely between the two bottom plates
All in it was very easy to put togther and very well thought out, even with little channels for the esc wires where the arms meet the frame
This one has an original Copter Control board which flew fantastically stable on the recommended settings, it's using ZMR 2400kv motors and SimonK 12a ESC's with a 1300mah 3S battery
Oh and those LED's on the front will blind you if you're not carefull
Dogdude is offline Find More Posts by Dogdude
Old Sep 09, 2014, 04:15 AM
Dogdude is offline
Joined Aug 2012
Some pictures for you....
Old Sep 10, 2014, 09:00 AM
superjon is offline
Find More Posts by superjon
superjon's Avatar
United States, PA, Shippensburg
Joined Feb 2011
Dogdude,
Can you get me the exact measurements inside the upper box ("clean" area)? I would like the actual measurement between the aluminum posts and the actual measurement between the top and bottom plates. Also, can you tell me the length of the top plates?
I am trying to decide which parts to go with and which batteries to go with and having these measurements would seriously help.
Jon
superjon is offline Find More Posts by superjon
Old Mar 01, 2015, 02:19 AM
betibeau is offline
Find More Posts by betibeau
Belgium, Walloon Region, Waterloo
Joined May 2010
Measurement and lipo place
The best battery place is underneath (velcoed to the lowest plate). You 'll have no limit (using from 1300Mah 3S upto 4500mah 4S). Do not forget the camera is normally mounted between the 2 upper plates, means, to room to put the lipo. The distance between 2 adjacent bronze spacer is 4cm (ok for 3S, KO for 4S). Better to add a strap around the battery to sustain Gs during flips. Enjoy.....
betibeau is offline Find More Posts by betibeau
Discussion ZMR 250 carbon fiber frame aka CloneOut 250 (Blackout Clone) CoolD Mini Multirotors 26389 Today 03:46 AM
New Product HobbyKing Dart 250 Akura2 Mini Multirotors 9 Feb 22, 2015 04:12 PM
Discussion Goodluckbuy 250 mini Quad aka GLB QAV250 Dogdude Mini Multirotors 7 Sep 24, 2014 02:39 PM
Discussion Goodluckbuy 250 Mini Quadcopter aka GLB QAV250 Dogdude Mini Multirotors 1 Sep 11, 2014 07:04 AM
Sold Slope AKA Mach Dart Carbon RTF "PRO BUILT" Just flyy Aircraft - Sailplanes (FS/W) 2 Dec 31, 2008 09:24 PM
