Old Apr 12, 2014, 02:55 AM
rinatka7's Avatar
Russian Federation, MO, Podolsk
Joined Dec 2010
Hello to all.
I have one idea, but i cant do it in real life!
The idea is to use serial modem like:
1)http://www.mikrokopter.de/ucwiki/en/RadioTronix
2)https://store.3drobotics.com/products/3dr-radio
3) or even serial bluetooth module(much more preferable)
First modem will be attached to PL and second one to PC side.
I found one scheme from Russian forum where one guy use DIY "FUIM3" cable.
I know when i connect genuine FUIM3 cable, i can see in device manager that its recognize as USB serial port.
I also can connect my modem to PC via FTDI board and in device manager i will see USB serial port.
Problem to me is how to connect modem to PL, as modem have (rx,tx,gnd and 5v) and on PL i have (gnd, 5v and signal).
How you think, can we make some wireless connection between PL and PC.
Thank you.
rinatka7 is online now Find More Posts by rinatka7
Old Apr 13, 2014, 01:17 PM
rinatka7's Avatar
Joined Dec 2010
Today i try to connect PL to PC by Wi232 serial modem, but with out luck!
If you see scheme in my previous post, you can see "FT232" chip, i just change this "FT232" to my serial modem.
What is default serial console speed? 9600, 19200, 38400, 57600 and 115200 bits per second?
I choose 9600 bits per sec in both modem.
Old Apr 13, 2014, 06:24 PM
Seattle
Joined Sep 2007
Its 19200. More details here http://www.revolectrix.com/support_docs/item_1374.pdf
Gregor99 is online now Find More Posts by Gregor99
Latest blog entry: Dual Powerlab Case Project
Old Apr 14, 2014, 12:34 AM
rinatka7's Avatar
Joined Dec 2010
Originally Posted by Gregor99 View Post
Gregor, thank you very much for link!
I change speed from 9600 to 19200, but also without luck!
Old Apr 17, 2014, 11:29 AM
Joined Mar 2014
Hi,
i have the powerlab8 and found a lot of infos on the topic and the manual. i just have something i don't understand : after put all parameters, the last things the charger ask is : charge on 1 cycle charge or monitor, i put charge but want to know what is 1 cycle charge.
I don't understand the manual explanation, can you help me please.
What is 1 cycle charge ? And what is better for the battery ?
Thanks !!!
mat321 is offline Find More Posts by mat321
Old Apr 17, 2014, 11:31 AM
Joined Mar 2014
Hi,
I have a powerlab8 and happy with. Just a question i don't find response in the post or manual :
The last thing the chargeur ask for before charge is : charge or 1 cycle charge or monitor. i put charge but don't know what is exactly 1 cycle charge.
Can you explain me the difference ?
So what is best for the battery ?
Old Apr 17, 2014, 11:43 AM
Seattle
Joined Sep 2007
Cycling is for performing charge and discharge cycles. This is useful for pack testing and categorization.
The Powerlab is a battery workstation. Useful for more than just charging pack. Its offers a very powerful lab tool for testing packs categorizing battery packs of all chemistries.
Old Apr 17, 2014, 11:57 AM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Are you using the Charge Control Software (CCS)?
If so you can find explanations for each of the preset parameters on your computer. Just position the mouse pointer over each parameter and short description will be displayed. For more information click on the parameter.
Each of the LiPo presets has the option of Charging, Discharging, Monitoring, or Cycling the LiPo battery. The charger is asking you what you want to do.
Charging, Discharging, and Monitoring are, or should be, self explanatory.
Cycling is a function whereby the pack is charged then discharged some number of times. This can be set for none, or 1 to 20 cycles. Generally you will have no use for this function, Set the Cycles parameter in the Discharge tab to None.
Glen
PS: Greg types faster than I do.
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Apr 17, 2014, 12:41 PM
Seattle
Joined Sep 2007
Perhaps, but I like your reply better than mine. The popup text is a hidden gem in the CCS. Thanks for the reminder. Also, you can download the software and run it without a charger connected. This would let your read all of the pop-up text even if you don't have a USB connector, or even have a Powerlab.
Old Apr 17, 2014, 12:52 PM
Joined Mar 2014
Hi thanks, unfornunately, i don't have the usb cable, just buy it and wait for it, damn it's not inside when buy it...
I will test the softawrae soon i hope.
Old Apr 17, 2014, 02:08 PM
USA, GA, Marietta
Joined Aug 2005
Originally Posted by mat321 View Post
Hi thanks, unfortunately, i don't have the usb cable, just buy it and wait for it, damn it's not inside when buy it...
I will test the software soon i hope.
As Greg said you can run the software without connecting to the charger. Obviously you cannot perform any functions but it will still be worth your time to get familiar with the software.
Glen
Discussion Sneak Peek! 2, 1:8 scale scratchbuilts ooby Scale Boats 31 Jul 24, 2011 08:30 AM
Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! Matt Halton Electric Ducted Fan Jet Talk 3 Dec 20, 2009 03:11 AM
Discussion Sneak Peek at the New Creation Museum Miami Mike Life, The Universe, and Politics 38 May 30, 2007 05:01 PM
Hey Mr. Lin, how about a sneak peek at the Hellcat? splatman GWS (Grand Wing Servo) 1 Jul 05, 2003 04:43 AM
