Old Mar 07, 2015, 05:59 PM
Joined Sep 2008
Help!
Robbe Tigra motor
I need motor recommendations for a Robbe Tigra......Would like to use 4S , and or 5S batteries. its original recommendation is :
Specs: Type: Fiberglass/Balsa 12 cell Formula 1 pylon racer
Length: 46 inches
Wingspan: 53 inches
Wing Area: 460 square inches
Power System: Aveox V12 motor, 16x1700 nicad pack
Weight: 85 ounces on 16 cells. Roughly 77 ounces on the recommended 12 cell Nicad pack.
Wing Loading: 25 ounces/square foot as reviewed
absolute max power is not what I am going for.....fast , yes Just not insane.....lets just say hot sport flying
Kenbogunz is offline Find More Posts by Kenbogunz
Old Mar 08, 2015, 04:09 AM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Length: 46 inches
Wingspan: 53 inches
Presume you meant F12?
Effective Kv of a F12 is 700 rpm/V from the old Aveox specs I have, rated for around 70A. NiCds would be about 1V each under load. So a system that can handle over 70A and has Kv x V around 8400 (12cell) to 11200 (16cell) would be roughly equivalent.
Matching the 16 cell setup, at say 3.5V/cell loaded, Kv of 800 would be roughly equivalent for 4S, 640 for 5S and 533 for 6s .
In a 120oz Seagull Nemesis 46 I ran a Hyperion Zs 4025-10, Kv=505 on 6S with a 12 x 13 at around 65A. Kv x V = 10605. - that's a similar setup to a 16 cell F12, Definitely a hot sports model but not super fast (rather thick wing section). Something like that would be pretty brutal in a slipperier lighter F1 model.
scirocco is offline Find More Posts by scirocco
Old Mar 08, 2015, 09:15 AM
Joined Sep 2008
thanks for the input......
Help! Robbe Tigra motor Kenbogunz Pylon Racing 0 Mar 07, 2015 07:26 AM
Sold 53" Tigra Electric Sport Pylon Racer or Aerobatics by Robbe of Germany Whitman Flyers Aircraft - Electric - Airplanes (FS/W) 2 Feb 24, 2015 10:43 AM
For Sale Robbe Tigra onio condor Aircraft - Electric - Airplanes (FS/W) 5 Oct 07, 2014 04:42 AM
Robbe Tigra with Astro motor. jks Aircraft - Fuel - Airplanes (FS/W) 0 Apr 19, 2002 11:57 PM
Robbe Tigra with Astro motor jks Aircraft - Electric - Helis (FS/W) 0 Apr 19, 2002 11:50 PM
