Old Feb 24, 2015, 03:19 PM
lionel_69's Avatar
France, RA, Villeurbanne
Joined Oct 2011
Build Log
Fouga Magister CM-170
Hi all,
Here is my new project for next spring....a 1200mm wing span , twin edf, Fouga magister. This plane was used till the 80's by the french show team "patrouille de France"....
For now, it weight under 700g with the EDF and the servos. The wings are covered with glued kraft paper,: very very strong
I hope to stay near 1kg. it should be ok with the 2 Dr Mad Thrust 55mm EDF I guess....
Regards
lionel_69 is offline Find More Posts by lionel_69
Old Feb 24, 2015, 04:09 PM
Keep calm and don't blink
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
Looking forward to watching this build progress Lionel - you have great skills.
The Magister is one of my favourite airplanes.
I was flying my slopey just last weekend.
KiwiKid is offline Find More Posts by KiwiKid
Latest blog entry: SZD-45 Ogar
Old Feb 24, 2015, 04:45 PM
Dirty Dee's Avatar
United States, IL, Northbrook
Joined Sep 2011
Looks great!
Subscribed
Dirty Dee is offline Find More Posts by Dirty Dee
Old Feb 25, 2015, 02:48 AM
Frank_K's Avatar
Antwerp, Belgium
Joined Sep 2004
looking very nice Lionel
success with your build!
Frank
btw: there was at least one more show team, using the fouga
Frank_K is offline Find More Posts by Frank_K
Old Feb 25, 2015, 05:27 AM
lionel_69's Avatar
Joined Oct 2011
Frank
Thanks Franck.
You are right, I forgot the belgian team !
Old Feb 26, 2015, 12:44 AM
lionel_69's Avatar
Joined Oct 2011
Hi
Today I cut the aileron through the foam. The upper side of the kraft paper is kept, to make the hinge.
I drill the front part of the canopy too.
Old Feb 26, 2015, 12:46 AM
lionel_69's Avatar
Joined Oct 2011
Very nice Kiwi!
Is it a kit or a scratchbuild? Wood or foam?
Old Feb 26, 2015, 07:11 AM
KiwiKid's Avatar
Joined Jun 2005
Thanks Lionel.
It is a real fun (all balsawood) model to fly and is scratch built based on plans made by Paul Janssens: http://www.pjmodelclassics.be/
PSS Fouga Magister (2 min 53 sec)
Old Feb 26, 2015, 12:05 PM
perttime's Avatar
Tampere, Finland
Joined Nov 2004
I've grown used to seeing the Fouga in a bare metal scheme - so it looks right to me that way...
(wikimedia image)
perttime is offline Find More Posts by perttime
Old Mar 02, 2015, 09:07 AM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
awesome! cant wait to see it finished just saw one flying around last week.
corsair nut is offline Find More Posts by corsair nut
Old Mar 12, 2015, 05:42 PM
lionel_69's Avatar
Joined Oct 2011
Hi all
Recently, i covered the plane with kraft paper and wood glue.
I started to install the ESC and wonder how to cool them...
The cockpit is in glassing phase...looks decent
Old Mar 12, 2015, 06:08 PM
KiwiKid's Avatar
Joined Jun 2005
Nice work - perhaps you could install naca type air ducts in the inside of the jet intakes? http://www.hobbyking.com/hobbyking/s..._Duct_Set.html
You will also need to make an outlet that is about 1.5 times the combined size of the inlets.
Old Mar 12, 2015, 06:52 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Just cut a hole that the ESC will fit into in the side of the duct/ fuse in the hatch area and set the esc flush with the inside of the duct.
Discussion fouga magister Christen Diffusion 90mm fan gianni sanchez Large EDF Jets 18 Nov 17, 2014 12:36 PM
Build Log Fouga Magister fudi50 Slope 3 Nov 21, 2013 12:39 AM
Wanted Fouga magister cm 170 kit innoplastic Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2012 02:43 PM
