Old Jul 26, 2014, 05:44 PM
United States, VA, Virginia Beach
Joined Jul 2014
Question
Battery Connector
Plan on getting new batteries. What is the best type of connector to use on a Ni-Mh? I was thing of Deans as that is what I currently use. It means I'll probably have to change the connector on the new battery or get a adaptor, or change the connector on the speed control. Recommendations Please!!
Thanks -
Rcsmitty11 is offline Find More Posts by Rcsmitty11
Old Jul 27, 2014, 02:55 AM
Bradford West Yorkshire, UK
Joined Apr 2010
Depends how the speed controller is connected to the steam supply valve?
In the same vein, I'm just about to have my bathroom re-tiled, on fixing the tiling boards to the studwork, should I be using a Bosch or Ryobi electric drill?
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Jul 27, 2014, 12:56 PM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
weld them.
you may be able to weld wood in a hydrogen rich atmosphere using cheese straws as the electrode.
dunc2504 is online now Find More Posts by dunc2504
Old Jul 28, 2014, 08:59 PM
Hong Kong
Joined Dec 2003
Electric boiler
CM Cheng is offline Find More Posts by CM Cheng
Old Jul 31, 2014, 11:11 AM
Joined Jul 2014
DEANS.are always best unless u use more than 60 amp draw..
ElectricMann is offline Find More Posts by ElectricMann
Reply With Quote  (Disabled)
Old Oct 20, 2014, 01:23 PM
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
OP may be talking about RC system connectors or (horrors), may have posted in the wrong forum.
E-Challenged is offline Find More Posts by E-Challenged
Old Oct 22, 2014, 12:30 AM
Joined Apr 2010
Oh wow, never thought of that, English is a strange language to understand. I used a Power Master in the end, worked well for drilling the tiles too.
Regards Ian
Discussion Battery cable felt off the battery under run, ec3 connector waterprooof Racing Boats - Electric 3 Jun 19, 2014 12:08 AM
Sold Battery connectors HXT 4mm Gold Connector w/ Protector (10pcs/set) MiG-3 Reno Rocket Aircraft - General - Miscellaneous (FS/W) 2 Jun 02, 2014 11:29 AM
Found JST-PH connector (2s E-flite battery connector) moteasa Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 May 02, 2014 05:32 PM
Question Battery short at Deans connector; battery ok? Neil_SC Batteries and Chargers 9 May 02, 2014 05:19 PM
Wanted 130x battery lead or 2s balance female connector or bad board soccerj4y Aircraft - Electric - Helis (FS/W) 4 Oct 07, 2013 03:22 PM
