Old Mar 19, 2015, 06:34 PM
RcBoater
Joined Feb 2014
Runs great.
Dennis Manning is offline Find More Posts by Dennis Manning
Old Mar 20, 2015, 05:28 AM
Joined Mar 2015
did the original integrated ESC survive the Engine? what's the Amp that you think it will survive?
Gamma00 is online now Find More Posts by Gamma00
Old Mar 20, 2015, 05:37 AM
Norway, Aust-Agder, Arendal
Joined Dec 2012
The esc and motor are running cooler than stock! I didn't measure amp, but I think the esc would even handle a higher pitch prop.
Remember that this video is at wintertime in cold Norway:-) I don't know if there would be problems in hot weather.
Ole Jacob is online now Find More Posts by Ole Jacob
Old Mar 28, 2015, 08:58 AM
Joined Dec 2012
Will try a different prop from Hobbyking. The one on top from HK seems to have a higher pitch. Same diameter 35mm.
Old Mar 29, 2015, 12:50 PM
Joined Feb 2015
How did you secure the " threaded socket" to the new prop?
Originally Posted by kristofera View Post
Took about 12 days. International (Traceable) Air Mail Hong Kong Post 0g - 100g $3.99
Im using the standard shaft, I drilled the prop to 5mm and used the threaded socket or what its called from a standard prop
alanfred is offline Find More Posts by alanfred
Old Yesterday, 08:37 PM
Ondahelipad's Avatar
United States, FL, Summerfield
Joined May 2014
My upgrade mod
I upgraded the boat.
1. Custom made stainless steel shaft with threaded prop end.
2. Atomic Fireball 15T brushed motor.
http://www.amazon.com/Atomik-Double-.../dp/B000HKEWAM
3. Universal joint coupler.
4. I used the standard FT009 motor mount. It's a direct fit. Reviews on this motor are for a non water cooled race buggy. Comments say" This motor runs hot." The OE aluminum cooling tube wrap is required. It fits snuggly on the motor. With a little wiggling, the motor with cooling coil,fit perfect into the OE motor mount
I did a sink test on it. Plenty of power! No leaks. No vibrations
Full run in the pond next.
Ondahelipad is online now Find More Posts by Ondahelipad
Discussion Skywalker 2014 - 1800mm - FPVModel - Spanish Review Japanx FPV Aircraft 9 Dec 14, 2013 09:48 PM
Mini-Review Turbodrone Micro Quad review stallion explosi Multirotor Talk 0 Nov 22, 2013 08:27 AM
New Product Vitality H36's Brother Vitality H39 2.4G 4-axis RC Quadcopter With camera RTF Aaron qin Mini Multirotors 14 Sep 18, 2013 09:02 AM
