Old Jul 19, 2011, 01:22 PM
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Nine Eagles Bravo SX Mods thread
Although this heli shares many parts with the Solo Pro, there are still some mods possible on this scale-like heli, that are not likely to be performed on the Solo Pro. So if you have a Bravo SX specific mod, this is the topic to show these!
SoloProFan is online now Find More Posts by SoloProFan
Old Jul 19, 2011, 03:47 PM
Vienna calling...
Donaldsneffe's Avatar
Österreich, Wien
Joined Aug 2010
OK,
than this is the place for my Nine Eagles Bravo SX MIA S300 mod
http://www.rcgroups.com/forums/member.php?u=324658
Walter
Donaldsneffe is offline Find More Posts by Donaldsneffe
Old Jul 19, 2011, 06:34 PM
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Originally Posted by Donaldsneffe View Post
OK,
Walter
Your mod has motivated me to want to build my own MIA/Bravo SX based heli.
Brosol is offline Find More Posts by Brosol
Old Jul 20, 2011, 05:35 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I read a while ago MIA was going to make a version of their kit expecially for the Bravo SX, so there was no additional modding needed to fit it. Anyone knows more about this, if this idea has been executed?
Old Jul 20, 2011, 12:16 PM
PaulGilbert's Avatar
Joined Jan 2011
Little howto about nav lights on Bravo Sx. (I decided to put it apart because that way I dont have to read everyday the mods topic to know if someone asks something. I receive notification on email and its easier for me:
http://www.rcgroups.com/forums/showthread.php?t=1474474
Will add more info if requested.
PaulGilbert is offline Find More Posts by PaulGilbert
Old Jul 26, 2011, 08:42 AM
Vienna calling...
Österreich, Wien
Joined Aug 2010
Hi,
I did it - modified a Bravo SX with Blade mCP x parts to a Bravo SX collective pitch flybarless heli, ca. 19 cm rotor diameter.
Did not believe, that this heli would fly - but it does
Anyway, it is far from perfect - main problem is the main motor, it is too weak.
Edit: Weight is exactly 35 g without battery - probably a little too much for a really good and strong flight performance with the small Bravo SX main motor.
But it is possible, and work is probably not finished.
Walter
Old Jul 26, 2011, 09:30 AM
helicopcat's Avatar
Joined Jan 2011
Hi,
Walter
Only one word.... WOW!!
helicopcat is offline Find More Posts by helicopcat
Old Jul 26, 2011, 09:32 AM
2011 - Year of the clones!!!
Frank_fjs's Avatar
Australia, SA, Adelaide
Joined Nov 2010
Super cool.
Frank_fjs is offline Find More Posts by Frank_fjs
Old Jul 26, 2011, 09:47 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Considering that the electronics and head setup is Blade mCP X, I would call it a modded mCP x with Bravo SX parts instead, but nevertheless very nice.
Old Jul 26, 2011, 05:30 PM
Vienna calling...
Österreich, Wien
Joined Aug 2010
SX canopy, SX main frame, SX tail, SX main motor, SX main gear - it's an SX with some mCP x parts in it.
If you put Porsche electronics into a VW beetle, it is still a VW beetle...
Walter
Old Jul 26, 2011, 07:11 PM
Joined Jan 2011
Awesome!! Would be nice to see it flying
Old Jul 26, 2011, 08:04 PM
United States, OH, New Vienna
Joined Mar 2011
Nav lights on my SX. I removed the spot light pod (factory lights). Looks really cool in dark, but hard to photograph, lights smear real bad.
og1974 is offline Find More Posts by og1974
Old Jul 27, 2011, 09:41 AM
Vienna calling...
Österreich, Wien
Joined Aug 2010
Finally weighed the SX CP:
It is exactly 35 g without battery.
Thats probably too much for the small Bravo SX main motor for a really good flight performance (rotor head should also be heavier than the Solo Pro / Bravo SX rotor head, maybe also a problem for the small motor).
So lets go brushless
Problem:
Not really much room for modding at the Bravo SX frame any more.
Servos fit tight between the canopy; had to take a smaller than the mCP x servo as nick servo (HK ultra micro).
Brushless motor would need more room - so motor mount would have to be cut (even for the tiny Turnigy Inrunner 1015, which maybe would not have enough power either).
But then servos would touch the canopy.
Have to think about this.
Maybe I will try 3 of the tiny HK ultra micro servos - despite the bad reviews.
Actually out of stock, and I had ordered only one for testing... (mine works fine).
Have some other tiny HK servos here, maybe I will use those.
But first brushless main motor has to work - probably will try this first in a Solo Pro and if it works well make this for the Bravo SX CP
Walter
Old Jul 28, 2011, 06:24 PM
Joined May 2011
Just got my PIC code running on PIC12f675 for my tr100 brushless attempt. If you know the frequency of the NE PWM signal i can probably make a version of the code for it.
Currently it is for 1kHz signal (less than this will need a bit of though, higher should be reasonably straight forward). Signal polarity is controlled externally with a transistor to flip the signal. Native is negative (low) for power on. The tr100 needs the inversion. This gives you a PPM signal that will drive a standard brushless controller. You need a controller that does not require a BEC (5volt standard). XP3A or similar works, the XP3A seems to have a reputation for not liking high LiPo voltage though.
Running it from an oscillator on the bench and looking at the signal on the scope it seems to work very well, hopefully try it in anger in a few days time.
h106frp is offline Find More Posts by h106frp
Old Aug 24, 2011, 02:10 AM
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Problem:
Walter
Any updates on your Bravo SX brushless motor experiments?
Discussion Nine Eagles Solo Pro or Bravo SX ???? sam-smith Micro Helis 2 Jun 26, 2011 11:18 PM
Build Log Nine Eagles Bravo II SX build RogueTitan Micro Helis 11 May 28, 2011 11:53 PM
Sold Nine Eagles Bravo SX (Dk Blue) w/ lotsa Extras! MaladroitFL Aircraft - Electric - Helis (FS/W) 1 Mar 29, 2011 05:20 PM
