Old Jun 28, 2014, 10:39 AM
Joined Dec 2009
new pl8 won't beep
hi,
i bought a new pl8 and i'm having a small issue. i can't make the charger beep correctly at the end of the charging when using preset #3. i set it to beep 6 times. preset #7 beeps correctly, but #3 only beeps twice. the 1st beep is very short, the second one is normal, but only two beeps instead of 6.
what could be wrong, please? a firmware issue? it is the latest version.
thanks.
Can'tFly is offline Find More Posts by Can'tFly
Old Jun 28, 2014, 11:48 PM
USA
Joined Jan 2002
The "Charge Done Beeps" in the Audio Setting section of the Options Tab in the CCS is a global setting and cannot be changed at the preset level. At the preset level under the Fuel tab there is the option "Sound Beep at" to choose charge % to sound two or three beeps at (DPL8 manual says two, DPL8 CCS mouse over says three) beeps.
Ohmic is online now Find More Posts by Ohmic
Old Jun 29, 2014, 07:49 AM
Joined Dec 2009
so, do i have another defective pl8?
fma?
Old Jun 29, 2014, 12:59 PM
Seattle
Joined Sep 2007
That's odd that it seems to be preset specific. It might be worth restoring the preset from the library preset, or perhaps do a factory restore (on the firmware tab). Be sure to backup your presets before performing a factory restore.
Gregor99 is offline Find More Posts by Gregor99
Old Jul 01, 2014, 05:43 PM
Joined Dec 2009
hello Gregor,
it worked!
thanks a lot!
Old Jul 01, 2014, 05:50 PM
Seattle
Joined Sep 2007
Good deal! Did you just restore the preset, or do the complete factory restore?
Old Jul 01, 2014, 05:55 PM
Joined Dec 2009
hi,
restored the preset only.
as you suggested...
Discussion XJT + Jr8103 won't stop beeping JIM CALDWELLA Radios 2 Jun 04, 2014 11:33 AM
Help! ESC beeps every 2 sec. motor won't operate. Mode One Electric Plane Talk 9 Jan 15, 2014 09:56 PM
Discussion Motor Beeps but won't turn. servos work great allthenameswere8 Power Systems 24 Dec 20, 2013 11:26 AM
Discussion Naza 3 red beeps after startup won't do anythjng abiddar Power Systems 3 Oct 29, 2013 01:33 PM
Help! PL8 Won't connect to PC skycarcass FMA Direct 1 Jan 22, 2011 11:44 PM
