Old Yesterday, 09:23 AM
Go fast, pull up.
Fidelity101's Avatar
United States, NY, Clarence Center
Joined Nov 2008
I charged 4 identical batteries. Two on each port of the icharger 4010 and two on the fma chargelab 8x2. The batteries on the Icharger settled to 4.18v after the charge while the fma charger fully charged the batteries to 4.2v per cell at rest...although it took a few minutes longer to charge.
I'm also powering the Chargers with two deep cycle marine batteries and I get a serious spark when connecting the fma...more so than the Icharger for sure. I think I need to solder a resistor on the alligator clips to suppress the spark else it's going to reform the clips in short order
Fidelity101 is online now Find More Posts by Fidelity101
Old Yesterday, 09:33 AM
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
It seems we all experience that. Maybe set end voltage at 4.22 to end at 4.2?
struggleforlife is online now Find More Posts by struggleforlife
Old Yesterday, 09:51 AM
Go fast, pull up.
Joined Nov 2008
I've been hesitant to change any settings on the charger but that may work as a temp fix. It seems the charger goes from 10a charge rate to finish quickly so it doesn't take the time to finish the charge. I'm doing normal charge mode...it seems the fma does a better job but takes longer
Old Yesterday, 09:55 AM
USA
Joined Jan 2002
Which preset are you using on the PowerLab? Different presets have different termination rates. Now that you have your PowerLab connected to the Charge Control Software (CCS) you can view the preset parameters to see how the presets differ. Look at the termination tab for each preset in the CCS.
Ohmic is online now Find More Posts by Ohmic
Old Yesterday, 10:55 AM
Joined Dec 2011
You can use User Balance with custom settings for more accurate charge
User Balance
Balance Start = CV-0.2V
Balance Diff = 5mV
Balance Set Point = 2mV
Balance Over Charge = 0mV
Balance Done Delay = 1Min
If you need end voltage at 4.20, you can also try Balance Over Charge = 1 - 2mV.
vlad_vy is online now Find More Posts by vlad_vy
Old Yesterday, 11:58 AM
Germany, HE, Frankfurt
Joined Apr 2014
You can also set the end current to less percent (e.g. 5%), then the charge will last longer and the lipo is more to 4.2v/cell, so this is what you want.
Or the best if you arenīt a high end user: ignore the little difference, it is nothing you will see in flight time, maybe 2 seconds, but who cares. And the lipo maybe does more cycles when it is not totally full charged. But more important is not to discharge under 3.7V/cell for a long life.
xenoRC is online now Find More Posts by xenoRC
Old Yesterday, 12:08 PM
United States, MA
Joined Jan 2011
Originally Posted by bigemike View Post
I was actually hoping to use a bank of light bulbs or a resistor bank or something. I saw another thread where a guy used a resistor bank, but he wasn't clear on how it all went together...
I bought the charger for stock 17.5 racing where you want to dump your pack hard at like 20-30 amps and then recharge it at 30 amps to drop the IR and give a boost to the battery...
I have decided not to run 17.5 this year, but I still want to know how to make the charger work
Ahh, OK. Terminology strikes again.
Regenerative discharge is when you move the energy from one battery into another battery. Often into your source battery, maybe a deep-cycle lead acid.
What you're talking about is what the Duos call channel-to-channel discharge, into an external resistive load.
You put your pack(s) on one channel, and connect an appropriate resistive load to the other channel. The charger pulls from the packs, steps the voltage up/down as required, and sends it out to the resistors (which can be resistors, bulbs, etc, wired appropriately). Thus generating the heat outside the charger, which is much easier on the charger. And also allowing much higher-wattage and -amperage discharges, vs using the "internal" discharge function. The 308Duo can give you a 650W discharge this way, the 4010Duo can do 1000W.
This has been discussed numerous times, because it's a good subject, but a little confusing at first. It came up again within the last few weeks. Search the thread for "discharge".
These are some older discussions on the topic:
- This is a spreadsheet I made for helping people calculate an appropriate-resistance for what they need to build, depending on the discharge watts they want:
http://www.rcgroups.com/forums/showt...e#post26838498
- This is an older post discussing it. Again, this is just one of several discussions.
http://www.rcgroups.com/forums/showt...e#post27449057
Ask questions, people will help. But fortunately there is info out there already to help get started.
RedOctobyr is online now Find More Posts by RedOctobyr
Old Yesterday, 12:48 PM
czorzella's Avatar
United States, FL, Kissimmee
Joined Jan 2012
User Balance
Balance Diff = 5mV
You would also have to configure the iCharger to stop the balance charge only when the "End Current condition" and the "Balance condition" are both met; This is how I do and sometimes the whole charging process takes considerably longer to completion.
czorzella is online now Find More Posts by czorzella
Article iCharger 4010Duo - Review CSpaced Batteries and Chargers 204 Sep 07, 2014 12:25 PM
Question What else has Jack been hiding from us? Newtron North Coast Electric Flyers 2 Mar 05, 2012 10:09 PM
Suggestion How do I know if my warning point has been retracted AndyOne Site Suggestions / Complaints 2 Mar 05, 2012 08:21 AM
Sold message has been deleted sonicboom24 Cars - Cars and Parts (FS/W) 0 Feb 22, 2012 12:34 PM
