Old Aug 02, 2015, 11:53 AM
SanderHG is offline
Find More Posts by SanderHG
SanderHG's Avatar
Germany, RP, Nittel
Joined Sep 2014
Build Log
The plane that still needs a name
In my quest for making stuff go fast, I'm now going to build this thing. If it flies well enough, the plan is to make molds off of it and make a fully composite version of it. It has a span of 80cm and is 106cm long, and can fit a 40mm diameter inrunner in the back (it's a pusher). For testing it, I'll put a 1400kv 4082 inrunner in it, running on 6S or 8S (I'll use a 7x10 APC Sport prop). If it all works OK I'll go with a 12S setup with something like an HET 700-98 if the weight allows it.
Anyway, here are some pics :
SanderHG is offline Find More Posts by SanderHG
Old Aug 02, 2015, 02:30 PM
arcticflyer is offline
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
Stratos...and let me say THAT is beautiful wood work. As a composite that will be awesome! Here is mine 54" span.
arcticflyer is offline Find More Posts by arcticflyer
Old Aug 03, 2015, 11:08 AM
Jebera is offline
Find More Posts by Jebera
Jebera's Avatar
United States, NH, Nashua
Joined Oct 2006
Spike bolt
Jebera is offline Find More Posts by Jebera
Old Aug 03, 2015, 11:11 AM
Jebera is offline
Jebera's Avatar
Joined Oct 2006
Yes, Beautifull wood work but great computer work before!
Hope you sheet it with Plywood!
Geat job!
Old Aug 03, 2015, 11:33 AM
ronin4740 is offline
Find More Posts by ronin4740
Wandering IT geek
ronin4740's Avatar
United States, NV, Reno
Joined Aug 2005
The X-67 Re-Volt!
ronin4740 is offline Find More Posts by ronin4740
Old Aug 03, 2015, 10:23 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Scramjet?
Looks beautiful, a full scale version would definitely run scramjet engines ;-)
DownUnderPilot is offline Find More Posts by DownUnderPilot
Old Aug 07, 2015, 03:10 PM
SanderHG is offline
SanderHG's Avatar
Germany, RP, Nittel
Joined Sep 2014
Thanks . Some progress, put the motor and ESC in and started with the balsa skin. I also 3D printed some stands which go from the flat surface of the table to certain points on the wing, to make sure it will be nice and straight when I build it.
Old Aug 07, 2015, 05:06 PM
Joined Jan 2006
Was looking closely at your pics are there any composite materials back in the motor mount area?
Old Aug 08, 2015, 11:01 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Scrambler is my submission
Seriously, I am so jealous of you guys that can 3D model like this. And 3D printed building jigs, awesome! I can build a lot of stuff and can 3D print, but I truly respect this kind of design work!
I want to convert my wing to E-power.... Screamin' Demon
Troy is offline Find More Posts by Troy
Latest blog entry: Flying Ghost
Old Aug 10, 2015, 10:00 AM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
bungee launch?
stoneenforcer is offline Find More Posts by stoneenforcer
Old Aug 10, 2015, 04:04 PM
SanderHG is offline
SanderHG's Avatar
Germany, RP, Nittel
Joined Sep 2014
At this point in the build, not yet. That will all come when it gets glassed, I'll add carbon reinforcement to the motor mount area.
Originally Posted by stoneenforcer View Post
bungee launch?
Correct, it'll be bungee launched. I don't want my fingers anywhere near the prop on this thing :P
It starts to look a bit like a plane now, I filled in the top surface with depron and sanded it down. It makes a nice and smooth surface on which I'll glue the thin balsa sheeting.
Old Aug 12, 2015, 04:37 PM
SanderHG is offline
SanderHG's Avatar
Germany, RP, Nittel
Joined Sep 2014
Had some time to work on it over the last two days:
Old Aug 13, 2015, 01:24 AM
joe_crash is offline
Find More Posts by joe_crash
Pelagicide
joe_crash's Avatar
United States, MD, Gaithersburg
Joined Oct 2010
I love this plane on first sight! Is there any way you would cut a 2nd kit? Or if you have complete plans, give me permission to have Manzano or like him cut a kit from the plans? Incredible design, outstanding execution of the build!
joe_crash is offline Find More Posts by joe_crash
Old Aug 15, 2015, 04:46 PM
SanderHG is offline
SanderHG's Avatar
Germany, RP, Nittel
Joined Sep 2014
Time for an update, I got a lot done in the past two afternoons, all the balsa sheeting on the plane is done now, and I finished one rudder (minus the cutout for the flight controls). Took quite a bit of time to get the round corners etc done, but I'm happy with how it turned out.
Thanks! As discussed via pm, sure I can make a second kit.
Old Aug 15, 2015, 10:32 PM
buildcrashrepair is offline
Find More Posts by buildcrashrepair
How low can you go?
buildcrashrepair's Avatar
United States, KS, Leawood
Joined Jul 2013
That is surely a thing of beauty!!!
buildcrashrepair is offline Find More Posts by buildcrashrepair
Latest blog entry: MXY-7 Ohka
Help! Name that Plane Game. FoamFlyinfool Fuel Plane Talk 5 May 13, 2014 03:55 PM
Help! name that plane! stroland Electric Plane Talk 6 May 02, 2014 10:02 PM
Discussion Name planes that use the Eflight 1S 3.7V Chicklet Lipo kiteboarderdc Electric Plane Talk 5 Apr 08, 2014 05:11 PM
Discussion Name That (1930's?)Plane SpadCat2000 Scale Fuel Planes 7 Feb 13, 2014 09:00 PM
Discussion The plane that currently has no name. (now named N2) (Like N-squared) lmopar69 Foamies (Scratchbuilt) 420 Jun 28, 2011 02:32 AM
