Espritmodel.com Heli Air
Old Jun 14, 2011, 01:14 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
New CP antennas from TrueRC
I completely remade the website www.truerc.net/canada and I'm now offering a range of CP antennas, both omnis and directional.
Our omnis:
The "virevent" as some already know, is offered in all popular freq.
The "turbine" our newly developed CP omni, offered in 1.2ghz, 2.4ghz, and on 5.8ghz for a limited run. The "turbine" feature even more pronounced multipath rejection than the virevent (-24db or better) and better coverage on top and bottom.
The directionals:
The helical that is already well documented here and the open biquad.
I been testing the open-biquad against the helical in both 1.2 and 2.4ghz and found it extremely capable. The form factor is also a big advantage.
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Jun 14, 2011, 02:02 PM
Joined Jun 2011
great to see all these antennas popping up. well done!
LongJohnTrappy is offline Find More Posts by LongJohnTrappy
Old Jun 14, 2011, 02:31 PM
Alberta, Canada
Joined Sep 2001
I'm guessing these are built to order hence the lack of stock on the website? Can we order them with a 0 stock level?
Mikey-flies is offline Find More Posts by Mikey-flies
Old Jun 14, 2011, 02:43 PM
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
You need to post a photo for every antenna you have on there. A picture is worth 1000 words
malcr001 is offline Find More Posts by malcr001
Old Jun 14, 2011, 02:47 PM
San Marcos, TX
Joined Jan 2010
What are the dimensions of these antennas at 1280 mHz?
shawn
Mactadpole is offline Find More Posts by Mactadpole
Old Jun 14, 2011, 03:01 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Yes, I offer you to choose the coax length you want and sma type as well. Then, I built to your spec. When the log-book is filled, order will be turned off.
-Hugo
Old Jun 14, 2011, 03:23 PM
Alberta, Canada
Joined Sep 2001
Excellent You should post up the 4nec radiation plots from your other posts to the web site as well (and perhaps generate one for the turbine)!
Old Jun 14, 2011, 03:33 PM
San Marcos, TX
Joined Jan 2010
Originally Posted by mikey-flies View Post
excellent you should post up the 4nec radiation plots from your other posts to the web site as well (and perhaps generate one for the turbine)!
+1!
Old Jun 15, 2011, 09:01 AM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Updated the website with radiation plots for the 1280mhz model.
Here two 3D plots of the opposite polarization rejection of the virevent and the turbine. You can see that the virevent has some weakness at the bottom while the turbine is fully armored.
-Hugo
Old Jun 15, 2011, 09:10 AM
ysb
use the force..or a quadcopter
ysb's Avatar
quebec
Joined Dec 2010
damn... If I had known this before, I bought a turbine instead of a Virevent....
ysb is offline Find More Posts by ysb
Old Jun 16, 2011, 03:36 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
The turbine in action:
Turbine antenna (2 min 47 sec)
I made you a turbine, just need post to resume and I'll ship it to you.
-Hugo
Old Jun 17, 2011, 10:06 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Finally!
It took you long enough, Hugo Now prepare to be swamped with more orders that you can handle.
I personally have built Hugo's virevent and do fly it on occasion. It is an excellent antenna. I have not tried the turbine yet.
Keep up the good work, Hugo!
Your friend in performance video,
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jun 17, 2011, 05:57 PM
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Commande passée Merci Hugo !
saucisse is offline Find More Posts by saucisse
Old Jun 18, 2011, 12:04 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Thx Alex
Here's a pic of a 5.8ghz turbine. Understand why they are a limited edition, building these is a jeweler job.
Old Jun 18, 2011, 01:30 PM
teebok's Avatar
Pico Rivera, CA
Joined Apr 2004
Originally Posted by Hugeone View Post
Thx Alex
Hi, I would like to purchase a 5.8 turbine. I'm currently using CP cloverleafs on both TX & RX. can i use 1 cloverleaf & 1 turbine? or do i need a matching pair?
thanks
teebok is offline Find More Posts by teebok
Discussion Lawmate 1.2ghz and CP antennas? Does it work. airbagit13 Video Piloting (FPV/RPV) 23 May 20, 2011 06:58 AM
Question upgrade from fp to cp kkfd Electric Heli Talk 2 Apr 08, 2011 07:28 PM
Sold 2 New - TrueRC 900mAh 11.1V 3S1P (Blade CP) SOLD simages Aircraft - Electric - Batteries & Chargers (FS/W) 3 Sep 17, 2008 02:16 PM
New 11.1V 15C 2200mAh packs from TrueRC supi7 Batteries and Chargers 17 Nov 30, 2005 04:55 AM
F/S New powerfull cells and packs from TrueRC supi7 Product Announcements 8 Oct 06, 2005 11:47 PM
