Old May 31, 2014, 10:24 AM
Israel, Adi
Joined May 2006
Question
Doe's any one use YellowJacket RPV?
Hi
just saw this rx
http://www.readymaderc.com/store/ind...oducts_id=2586
and i couldn't find any review / opinions about it... has any one here tried it?
my current setup is:
rv 910mhz 800mw tx
rmrc 900MHz-1.3Ghz v3 rx
ibcrazy mad mushroom on tx
ibcrazy crosshair on rx
i already got about 6-7 KM but looking to increase my range and video quality
guytzoler is offline Find More Posts by guytzoler
Old Jun 01, 2014, 06:58 AM
peter.braswell's Avatar
United States, VA, Chesterfield
Joined Apr 2008
Very pricy but looks very interesting. Anxious for somebody to chime in!
-Peter
peter.braswell is offline Find More Posts by peter.braswell
Old Jun 01, 2014, 10:53 AM
Senior Gravity Checker
Tampa, Florida
Joined Mar 2001
I would like to see a test between this receiver and a regular 900Mhz receiver setup connected to an oracle. Perhaps someone can contact Ira at Iftron to make this happen. Receivers are the heart of our hobby and a real spot for improvement.
kist2001 is offline Find More Posts by kist2001
Old Sep 28, 2014, 08:27 AM
When a hobby gets a passion
Thailand, Chon Buri, Pattaya
Joined Sep 2012
I have been using the Yellow Jacket receiver on 1200 MHz video for a while and get the following:
1. Diversity doesn’t work when the signal gets low. I’ve been testing the product for long range flying , and when the signal gets below 1 bar, diversity doesn’t work anymore, It just stays with the antenna that has been selected and that’s it.
2. You have to push a button to switch the receiver on or off. The system should have a selectable option to switch on automatically when power is applied, or use the power button. Although I think it should just switch on when power is applied, as I cannot imagine someone would like to switch of the unit when power is still applied. Using a 10 or 20 meter mast will make it very difficult to switch the unit on.
3. The OSD should be a true OSD. That means the signal strength and other information should be on the life video screen, not just replace the video. Even my cheapo DVR does that.
4. The 2 receivers are not balanced. One is more sensitive than the other. Which leads to wrong information to the diversity selection
5. It seems it is sensitive to interference. I have 915 MHz data antenna’s at about 50 cm distance, and the bursts of data are clearly visible on the video
Pattaya01 is offline Find More Posts by Pattaya01
Discussion does any one have or know Folding Locust X-Shape quadcopter frame? boss777 Multirotor Talk 10 Mar 21, 2014 12:32 PM
Discussion Any one Using Castle Creations 25 amp Multi ESC's NEAGRON Multirotor Electronics 0 Feb 11, 2014 01:19 PM
Question Does anyone have any experience with E-flite's universal light kit controller? SkylineFlyer Night Flying 0 Dec 28, 2013 09:29 PM
Discussion Any one using this PCB Circular Polarized Patch Atenna? hcker2000 FPV Equipment 0 Oct 23, 2013 12:34 PM
Discussion Does any one use a fuse in the RX bat? Stuart B Slope 7 Jul 03, 2008 02:15 PM
