Old Jul 30, 2008, 10:58 PM
Fan-atic
cray2602's Avatar
Plain ole KS
Highest thrust in 70mm EDF
Anyone know what motor and 70mm fan setup has the highest thrust for a 3s or 4s setup? I am in need of a motor fan combo that can produce around 1100grams or more static thrust without going over 45 amps if its possible. Not sure whats out there in the major power department.
cray2602 is offline Find More Posts by cray2602
Old Jul 30, 2008, 11:27 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
that might be tough ...how many pounds of thrust are you looking for ...sorry i suck at metric stuff.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jul 31, 2008, 12:29 AM
USA, PA, Pittsburgh
Joined Jul 2001
This is what I use for a year now. GP ammo 2845 3600 kv, 4s, 48A, 1280 grams in wemo mini fan.
darmar is online now Find More Posts by darmar
Old Jul 31, 2008, 05:04 AM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
1 kg = 2.205 lb..
1100 gram = 2.4255 lb
Claus at Velocity-RC
clausxpf is offline Find More Posts by clausxpf
Old Jun 13, 2014, 11:53 AM
Joined Jun 2012
Is this in an air frame or a bench number? From the manufacturer or something you measured?
To the OP,
I sort of doubt that you can get a system like you want with 48A draw if you want that thrust as measured in the airframe in a ground test (how I measure). I get about 2.125 lb @49A for the 3200kv eflite fan/motor as measured in the airframe on 4S. You will need to beat eflite's efficiency significantly.
sothpaw is offline Find More Posts by sothpaw
Discussion Micro EDF Contest: F-22 Raptor with thrust vectoring for EDF-40 - plans in post #1 Esprit440 Micro EDF Jets and Power Systems 290 Feb 04, 2013 11:57 AM
Discussion 70mm EDF Power System - 850g~900g Thrust AirPower RC Electric Ducted Fan Jet Talk 4 Oct 31, 2006 08:01 PM
Why do I need right thrust in my motormount? RandyK1 Electric Plane Talk 6 Nov 13, 2002 06:08 AM
To much thrust in EDF 50!!! henke Electric Ducted Fan Jet Talk 11 Feb 24, 2002 11:02 AM
Litestick motor thrust in ounces? AW Parkflyers 10 Sep 06, 2001 08:53 AM
