Old Aug 12, 2015, 06:42 PM
kimboviper is offline
Find More Posts by kimboviper
Joined Aug 2015
Charging 4 3cell Zippy lifepo4's all together at once without a Paraboard
Noob to RC stuff so please bear with me.
I have four 3cell Zippy lifepo4's wired in series with EC5 connectors to make a 12cell 4200mah pack. I would like to just charge them all together with one connector from my series adapter that I made as just a regular charge and not a balance charge. I would like to do it without a Paraboard.
I know the Thunder 1220 is capable of charging 12S but is this a good idea or not?
The reason I ask this because I have these packs on a Electric Longboard and would rather not open the enclosure, disconnect and hookup all 4 packs to a Paraboard in order to recharge the packs. Id rather just connect one EC5 connector to my charger and let it fill up all 4 packs at once. I could balance charge the packs once in a while but not often....
TIA
kimboviper is offline Find More Posts by kimboviper
Old Aug 13, 2015, 03:52 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Welcome to the forum
As you've realised, if you do what you're suggesting you won't be balancing the cells during charge. Depending on how good quality the packs are, that may not be a big deal, but personally I prefer to balance charge every time.
It's not recommended to leave the batteries in the model while charging, because you'll have a problem getting to them if they start to swell, or worse, during charging. Also, you must always disconnect the batteries from the ESC after you've finished your flight, otherwise the batteries will run down to zero volts, and be destroyed, due to the small current the ESC draws while it's not in use.
Lastly, rather than wait for the batteries to charge before you can have another flight, it's much simpler to swap the batteries for a fresh pack and then go fly again. So I would advise that you should ensure that battery access is easy, and then take them out for charging.
abenn is offline Find More Posts by abenn
Old Aug 13, 2015, 04:45 AM
Wayne Giles is offline
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
Perfect advice. - I would take it!
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old Aug 13, 2015, 08:35 AM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
I think you guys missed the "Electric longboard" part of his question.
Kim, any reason you would not balance charge? The charger you referenced is capable of balancing 12S.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Aug 13, 2015, 01:25 PM
Joined Aug 2015
Yes this is on a Electric Longboard
Would I be able to balance them if I just had access to all 4 balance leads and the one EC5 connection?
Old Aug 13, 2015, 01:34 PM
USA, GA, Marietta
Joined Aug 2005
Yes. You would have to make two balance leads. One would be to balance cells 1 - 6 and the other for cells 7 - 12.
Glen
Old Aug 13, 2015, 01:48 PM
Joined Aug 2015
I could use 2 of these...
http://www.3drcparts.com/jst-xh-6s-t...dapter-charge/
and charge as 12S
Old Aug 13, 2015, 01:56 PM
USA, GA, Marietta
Joined Aug 2005
and charge as 12S
Yes.
Old Aug 13, 2015, 03:04 PM
abenn is offline
Joined Jul 2004
Originally Posted by ggcrandall1 View Post
I think you guys missed the "Electric longboard" part of his question. ...
I just thought that "longboard" was the name of one of the many plane models I've never heard of
But my comments about charging in-situ are, I believe, still relevant.
Discussion Charge 4 batteries at once warrenmiller Batteries and Chargers 6 Aug 05, 2014 11:26 PM
Cool USB charger hack. Charge 4 batteries at once. Matts175 Mini Multirotors 1 Dec 17, 2013 09:17 AM
Sold Lifepo4 Packs to charge ALL your lipos at the field.... la528it Aircraft - Electric - Batteries & Chargers (FS/W) 2 Dec 15, 2010 07:02 PM
Sold Hyperion EOS1210i With 2 LBA 10's and all cords to charge two packs at once $150.00 JAM Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jul 11, 2008 09:47 AM
Sold PolyCharge4 charge 4 LiPo's at once $85 shipped NEW jerrit1 Aircraft - Electric - Batteries & Chargers (FS/W) 9 Mar 19, 2007 03:48 PM
