Old Yesterday, 03:26 PM
Joined Aug 2012
Just tested my gear again.. now in low power mode i put my tx in my car and started to walk.. wow... walked about 1 km into a par with trees and buildings between tx and rx... seems to work...
jonasdromberg is online now Find More Posts by jonasdromberg
Old Yesterday, 04:22 PM
Flying to help
Joined Apr 2013
HI,
I am testing again my scherrer Tx700 pro, I am getting failsafe every 1 moment, even if I am 30 meters, 100 meters, 300 meters from the Rx, on the 0.5W power and on the 1W and 2W, is always failsafe.
Is there anything we can do here?
CaptainElios is online now Find More Posts by CaptainElios
Old Yesterday, 05:32 PM
Joined Oct 2010
Originally Posted by Dominikk View Post
Rastislavko are you completely sure, that Taranis gives me all 12 channels ppm?
I'm ready to buy this transmitter if it will work well with Thomas TX :-)
...but Taranis have other serious problem when TX is attached on back. On 0.5W there is bad noise and lcd menu start jumping, on 1w or 2w taranis freeze.
It is not very uhf friendly.
bovi is offline Find More Posts by bovi
Old Today, 06:55 AM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Is that the Taranis+ as well? I have problems with the potentiometers not being exact on my Futaba 12FG which is/was a relatively high-end radio. I had to relocate the TSLRS TX away and at an angle to reduce the interferences to an acceptable level.
On my Turnigy 9X (ER9X) I solved most of these problems by putting alutape inside the radio and grounding it. It actually reduced the interference a lot. On the ER9X it was only the LCD which was affected and not as serious flaw as on the Futaba where actual controls suffered.
Regarding UHF I don't have any problema at all using a EzUHF module on the Taranis, bt that is only 600mW I think? I have yet to make a mount for my TSLRS v6 but it will happen soon. So far I like the Taranis sooo much better then the Futaba in almost everything.
boopidoo is online now Find More Posts by boopidoo
Discussion Long range flight using new DMD 868Mhz RC equipment tron FPV Talk 500 Feb 25, 2014 02:22 AM
Idea Long Range RC pmarek UAV - Unmanned Aerial Vehicles 22 Nov 07, 2011 06:17 PM
Long Range RC Link? cloudy Radios 2 Aug 09, 2008 12:11 PM
long range radio system suggestions?? oracle_9 Thermal 15 Aug 09, 2008 10:44 AM
Discussion Long Range 2.4 Ghz Wireless RC Camera edplane Aerial Photography 8 Apr 18, 2008 08:24 PM
