Old Mar 21, 2015, 08:40 AM
Dlucksone is offline
Find More Posts by Dlucksone
United States, OR, Portland
Joined Mar 2015
Hubsan H107D Motor Problem
Hi all,
I've recently damaged my x4's shell so I purchased a new one. I had to detach each motor in order to remove them and get them into the new shell. It worked well for around 2-3 minutes then all of a sudden one of the motors stopped working. I thought I had burned it out but I didn't. The reason I know this is because I removed it then resoldered it back to the board, as soon as I plugged the battery back in that motor just started spinning full speed (my TX wasn't even on or anything). So I removed the battery and de-soldered the motor off. Plugged the battery in to check all the other motors and they all work fine, I repeated this process again and the same result. When I solder the motor on and plug in the battery it just spins like crazy....
Does anyone know what is happening here or how I can fix it?
Thanks guys
Dlucksone is offline Find More Posts by Dlucksone
Old Mar 22, 2015, 02:16 AM
davidTs is offline
Find More Posts by davidTs
Joined Nov 2012
Hi,
I guess you burned the FC and not the motor. The cheapest option is to get a new FC (e.g. from Banggood), but you have to wait long...
David
davidTs is offline Find More Posts by davidTs
Discussion Dealer list for Hubsan X4 Family (H107/H107L/H107C/H107D) and spareparts! bangkomit Mini Multirotors 518 Feb 05, 2015 05:05 AM
Discussion Hubsan H107D - Red light blinking, no screen on power *PROBLEM* PilotPatch Mini Multirotors 1 Jan 15, 2015 11:40 AM
Discussion The Hubsan FPV X4 -(No.H107D) - What Happened?! JHawk19 Mini Multirotors 5 Nov 25, 2014 07:00 AM
For Sale Hubsan X4 H107D FPV RC Quadcopter H107D Spare Parts Crash Pack H107D-A07 Elisa FPV Equipment (FS/W) 0 Sep 02, 2014 05:14 AM
Discussion The Hubsan FPV X4 -(No.H107D) hubsan Mini Multirotors 35 Dec 27, 2012 09:34 PM
