Old Jan 09, 2015, 07:07 PM
stratocus is offline
Find More Posts by stratocus
stratocus's Avatar
Joined Feb 2013
New Product
ARKBIRD Automatic Antenna Tracker
Arkbird released its antenna tracker, too curious to know more about that!
So far no english manual :-(
There are 2 modules: air and ground, also OSD firmware must be updated @ V3.10.25.
It can be buy so far from here at 270 USD.
http://www.goodluckbuy.com/arkbird-f...air-combo.html
That's all i can say, anyone to give more info?
stratocus is offline Find More Posts by stratocus
Old Jan 09, 2015, 07:32 PM
stratocus's Avatar
Joined Feb 2013
google translate of the chinese manual found here:
http://www.uutao.ru/item?id=41233133941#69617203458
or
http://item.taobao.com/item.htm?id=41233133941
Arkbird AAT, the most advanced and cost-effective tracking PTZ; small spot, the need to start as soon as possible.
You can take a small 3.5mm power adapter and RCA adapter, do not shoot them off (5.8G available).
Welcome to the largest group of 19,329,609 FPV qq download the latest manual.
Products:
ARKBIRD-AAT (Auto Antenna Tracker) is designed for long-range antenna tracking module that allows you to always align panel antenna ground plane you maintain optimum image transmission reception, greatly improving the image transmission distance.
Adhering Arkbird series plug and play, reliable design style; six innovative design to provide you with the best use of experience ::
1. Two dual sensor coupling correction, while equipped with inertial compass (gyro) and magnetic compass, high-precision pointing;
2. Plug and play, with Arkbird OSD can avoid welding installed; advanced automatic calibration algorithm, a key to complete the calibration;
3. The video, audio 2-channel transmission, reliable double (video channel 50hz, audio channel 10hz);
4. One sucker integrated antenna and tripod mounting hole, ultra-compact and portable design (PTZ subject only 11cm * 8.8cm * 3.9cm), quality vigorously servos (12kg / cm), 360-degree non-wound slip ring design;
5. saved automatically after a power take-off point coordinates, you can take off without setting. Ground interface module with GPS, support for walking point, can be used for dynamic positioning. (For example, in driving the process to use, or looking after the plane landed unexpectedly machine);
6. autobauding, 9600-115200 any baud GPS, without any set, compatible with the market FPV equipment;
Old Jan 14, 2015, 03:22 AM
w12martin is offline
Find More Posts by w12martin
Joined Sep 2011
Hi guys!
I got one recently. It arrives without manual. Not even Chinese manual (I live in China).
Contacted the seller and through him, contacted the designer to get some help and get the manual.
So far, no answers, no manual, no explanation in English of how to setup this thing
w12martin is offline Find More Posts by w12martin
Old Jan 15, 2015, 05:33 AM
Joined Sep 2011
Here is the module I've got.
As you can see is different from the picture advertised by Arkbird.
Old Jan 16, 2015, 08:51 AM
Joined Sep 2011
A few more pictures...
Old Mar 21, 2015, 05:10 AM
stratocus's Avatar
Joined Feb 2013
Is it a prototype version? Case doesn't match the one from user manual.
Can we have a review?
Old Mar 21, 2015, 09:37 AM
ican3d is offline
Find More Posts by ican3d
flying ninja!
ican3d's Avatar
Joined Jun 2011
One question...does it worked?
ican3d is offline Find More Posts by ican3d
Old Mar 24, 2015, 08:26 AM
zbemerson is offline
Find More Posts by zbemerson
FPV Funds Accepted. Thanks.
United States, KY, Lexington
Joined Jan 2015
I'm VERY interested to hear more about this product, but there seems to be very little information out there about it. I had been looking at the MFD ATT and was pretty well set on buying it but the price point on this model is far more attractive. Couple that with myself already having the Arkbird OSD and I'm definitely interested in this model now. Like I said tho, there seems to be very little support out there for this, which makes me hesitant to purchase.
zbemerson is offline Find More Posts by zbemerson
Old Mar 24, 2015, 08:28 AM
Joined Jan 2015
Originally Posted by stratocus View Post
Do you know of a link to an English manual?
Sold MyFlyDream V3 AAT Automatic Antenna Tracker 6 Channel kjoy45 FPV Equipment (FS/W) 1 Dec 07, 2014 07:37 PM
Wanted MyFlyDream Automatic Antenna Tracker hotrod5607 FPV Equipment (FS/W) 2 Jul 22, 2014 10:37 PM
Sold Myflydream Automatic Antenna Tracker V5 lh59 FPV Equipment (FS/W) 2 Jul 16, 2014 02:11 AM
For Sale MYFLYDREAM (new) Automatic Antenna Tracker jumpen Aircraft - General - Radio Equipment (FS/W) 0 Jul 01, 2014 10:15 PM
News MyFlyDream Automatic Antenna Tracker Jason Cole FPV Equipment 8 Jan 10, 2014 04:19 PM
