Old May 17, 2015, 02:52 PM
jetjocky is offline
Find More Posts by jetjocky
United States, TX, Houston
Joined Feb 2008
Help!
Dr. Mad Thrust 40mm 8 Blade EDF Electroplated Version 7000kv/3S
Does anyone know how to remove and replace the fan blade on the
The nose cone seems to be seamless,so how do you get the dang thing off??? Help! Help!
jetjocky is offline Find More Posts by jetjocky
Old May 17, 2015, 05:49 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Oops Failure to read
Electroplated version requires that you Saw the glued on rotor Off.
Unlikely you can find a replacement rotor tho.
Bare is offline Find More Posts by Bare
Old Jun 28, 2015, 11:03 AM
jetjocky is offline
Joined Feb 2008
Thanks Bare,what kind of engineering nut came with this setup?? Do you know if the black blade will fit on the shaft??? Thanks again.......
Old Yesterday, 11:53 AM
Bare is offline
Canada
Joined Nov 2000
Likely the Same genius that thought that Chroming the things would make them sell faster.
Actually the Regular AEO 8 blade 40 mm rotor could be ..erm ..Glued on as well.
Given that it has a 3mm ID shaft hole :-)
Does that motor feature a 3mm shaft?
Cheap enough to buy those 8 bladers and Likely a FAR better performing rotor as bonus
New Product HobbyKing Dr. Mad Thrust 40mm 8 Blade EDF MegaTesla Micro EDF Jets and Power Systems 34 May 20, 2015 09:38 AM
Sold Dr. Mad Thrust 90mm 12 Blade Alloy EDF 1400kv - 3600w (8s) ** Reduced ** Roly72 Aircraft - Electric - Jets (FS/W) 1 May 12, 2015 12:57 PM
Sold NIB Dr. Mad Thrust Alloy 90mm EDF Unit 1000kv-4200w 8S To 10S 11.5lbs Thrust chebert Aircraft - Electric - Jets (FS/W) 0 Apr 07, 2015 10:32 PM
Sold NIB** Dr Mad Thrust 1600kv 2400watt 90mm EDF Inrunner 6s version (36mm) lmpbpd Aircraft - Electric - Jets (FS/W) 4 Nov 05, 2013 09:06 PM
