Old Oct 20, 2014, 05:00 PM
capteasy's Avatar
USA, Texas Hill Country
Joined May 2008
Still Rolling Left
Left roll has continued to be an issue with my MM since maiden. Test flights following repairs after my crash still required 10 clicks of right trim to maintain level flight.
Lateral balance seemed indicate the left wing was heavy so 2oz of lead was added to the wing tip. Aileron trim was neutralized on the first test flight but had no effect at all and it continued to roll left until 10 clicks of right trim was added.
Wing and horizontal stab are perfectly in line and the rudder is straight. left and right wing tips and incidence appear the same.
I'm at a loss to understand what is wrong or out of rig. If anyone can help I'd appreciate it.
Dick
edit: .........just happened to think maybe the motor mount might not have enough right angle - would that account for the fact the added weight might not have had any effect?
capteasy is offline Find More Posts by capteasy
Old Oct 21, 2014, 01:10 AM
Joined Mar 2013
Right thrust
I was going to say check the thrust angle. It needs right and down. In the 2Bfly review, they had the same problem and corrected it by shifting the battery. Check out the video. Lateral balance doesn't have a drastic effect on roll trim. It usually rears its head at the top of a loop. I do fly mine with a couple of clicks right rudder, adjusting the tailwheel for straight roll. Also check for a loose or cracked motor mount.
mark l is offline Find More Posts by mark l
Old Oct 21, 2014, 11:08 AM
Joined Mar 2013
Right trim
Dick, I watched that 2Bfly review again and it should definately help you. Click on review and go to the sixth page. It's a 2 part video review and the cogent points are in part 2. They had exactly the same problem you are describing.
Old Oct 21, 2014, 03:29 PM
capteasy's Avatar
Joined May 2008
Okay, reviewed the vid again and I can't see how moving the battery over to the right would have any affect at all. I'm going to check the thrust angle first chance I get.
Old Oct 21, 2014, 08:04 PM
Joined Mar 2013
thrust angle
Lack of sufficient thrust angle should result in a throttle sensitive roll. If you're adding 10 clicks right trim at 3/4 throttle, it should roll right when the throttle is decreased. Your repair might have thrown the balance of the fuse off. The battery movement might do the trick. I'll be interested to hear about what you find. You gotta admit, their description of the problem does sound identicle to yours.
Old Oct 22, 2014, 12:55 AM
capteasy's Avatar
Joined May 2008
Yeah, I admit it sounds similar but it seemed they didn't say that much other than shifting the battery. I'll look at it again.
Following the repair it still wanted to roll left - identically to the first three flights before the crash.
I think I'll fly it at cruise throttle straight and level, reduce power and see if it rolls right.
I'll let you know soon as I find anything but it may be a few days yet.
Latest blog entry: E-flite hawker Hurricane 25E
Old Oct 24, 2014, 12:13 AM
capteasy's Avatar
Joined May 2008
Since the added wing tip weight had no effect I guess it won't make any difference to remove then... ?
Old Oct 24, 2014, 06:21 AM
Joined Mar 2013
tip weight
How much is it?
Old Oct 24, 2014, 09:08 AM
capteasy's Avatar
Joined May 2008
It was almost 2 oz.
Old Oct 24, 2014, 11:59 AM
Joined Mar 2013
tip weight.
Not sure. Is it out of balance laterally with the weight in?
Old Oct 25, 2014, 01:48 PM
capteasy's Avatar
Joined May 2008
I just did another lat balance and now the right wing is heavy. I need to remove the weight and start all over....
Thanks, I'll get back soon as I have time.
Old Nov 10, 2014, 07:53 PM
Joined Mar 2013
Mm
Wrecked another GeeBee. Started back in on my Mr. Mulligan gas conversion. New firewall's in, working on a new dummy radial and waiting for the engine mounts. the 20cc is going to fit nicely inside the cowl and looks like the spark plug cap will be the only thing protruding. Should be a screamer with about the same power to weight as the original(full scale).
Old Nov 10, 2014, 08:44 PM
capteasy's Avatar
Joined May 2008
.........what happened to the GB?
Old Nov 12, 2014, 07:20 AM
Joined Mar 2013
GeeBee demise
Dumb Thumbs. Hadn't flown it in months, flying an unfamiliar pattern and stalled it turning downwind for an approach. Nothing exciting....could probably fix it but I don't think I will.
Article Great Planes P-51 Mustang Sport Scale GP/EP ARF Review pda4you Electric Warbirds 30 May 04, 2014 08:01 PM
Sold Great Planes Yak 55 EP 3D ARF H2daB Aircraft - Electric - Airplanes (FS/W) 4 Apr 03, 2011 01:50 PM
Sold Great Planes 54" Shoestring ARF GP/EP NIB chriscap Aircraft - Fuel - Airplanes (FS/W) 1 Mar 18, 2011 02:21 PM
Sold Great Planes 54" Shoestring ARF GP/EP NIB chriscap Aircraft - Electric - Airplanes (FS/W) 3 Mar 18, 2011 01:06 AM
Sold Brand New Mister Mulligan Ep Park Flyer birdy233 Aircraft - Electric - Airplanes (FS/W) 1 Aug 09, 2009 10:25 AM
