Old Yesterday, 11:48 AM
Alumnite is offline
Find More Posts by Alumnite
Joined Mar 2013
Question
Hot-Swapping Taranis Profiles And Still Controlling The Same Receiver
I just bought a Taranis and it is on it's way here. But I was thinking, if I wanted to practice with my quad on 3S until I get a maneuver/track down and then had a whole slew of different settings to accommodate a 4S (with different sized props) setup on the same quad (so the same receiver) could I just power down the frame, swap profiles in the Taranis and then boogy?
I know of this "receiver number" (which is basically the same thing as Spektrum Model Match) and if I am thinking about it correctly, since you can assign your own number to that receiver, then as long as both profiles have the same receiver number assigned to them, it shouldn't be a problem right?
I know there's other ways around it and all the important changes are done to the FC, but I'm just brewin ideas.
Alumnite is offline Find More Posts by Alumnite
Old Yesterday, 12:25 PM
Jet_Flyer is online now
Find More Posts by Jet_Flyer
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
By profile I think you mean what is called a "Model" in the Taranis Plus and models can use the same receiver number if needed.
Jet_Flyer is online now Find More Posts by Jet_Flyer
Old Yesterday, 01:13 PM
Alumnite is offline
Joined Mar 2013
Yea I meant model. But what I was explaining is correct then? As long as the receiver numbers are the same for both models in the Taranis then this is do-able?
Old Yesterday, 01:22 PM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
Yes, of course you will need to go through the process of selecting the model to switch, but you can do that without powering down the Taranis Plus. It is one of the first pages in the menu system.
Old Yesterday, 01:30 PM
Alumnite is offline
Joined Mar 2013
Awesome thanks man. But when I said I power down, I was talking about the quad. But that's minutia haha. And like I said, I know all the major setting changes that are affected by a difference S count on batteries are done through the FC
Thank you much!
Old Yesterday, 02:04 PM
MattyB is online now
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
As an FYI you can also disable the model match completely for a specific model if you wish.
MattyB is online now Find More Posts by MattyB
Discussion Using same Tx to control multiple aircraft (not at the same time) kjriisne Multirotor Electronics 2 Mar 22, 2015 05:14 AM
Sold OMP Profiles and Morris Hobbies Profile Hots ton2di Aircraft - Fuel - Airplanes (FS/W) 0 Aug 26, 2014 01:27 PM
Discussion Watts to weight ratio still the same for foamies? ChiTownFlyer 3D Foamies 4 Mar 02, 2014 10:26 PM
Discussion Blade MSR revised or still the same stuff? northerngames Micro Helis 10 Jan 09, 2014 10:34 PM
Discussion Is 'speed control' the same as a 'receiver'? Kevinfred Electric Plane Talk 11 Dec 09, 2008 08:48 PM
