Old Aug 17, 2014, 03:19 AM
shoey's Avatar
Australia, SA, Adelaide
Joined Jan 2009
Jim, sorry the parts didn't turn out as you expected, but thanks for posting the result here. Sometimes you get more info from "what not to do" than successes. I look forward to seeing what you come up with to remedy the situation... I know the end product will be outstanding! Still really enjoying your two builds going!
shoey is online now Find More Posts by shoey
Old Aug 17, 2014, 08:17 AM
Tumbler's Avatar
New Jersey
Joined Feb 2003
I can definitely see why you are using foam because I have had a tough time keepibg weight down using glass with mine. My bombs are big (34"long), but the best ilI have been able to do is 3.5ozs. First one was 5.5. Just keep at it!
Tumbler is offline Find More Posts by Tumbler
Old Aug 17, 2014, 06:29 PM
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
Shoey... Thanks for the feed back. Yes, failures make one more creative which furthers the hobby.
Tumbler..... Nice work on the ordinance. For that size it seems you are getting good results. Nice pics.
So after flying this morning I decided to give it another go. Last night I was thinking that one of my issues maybe the flex in the mold. The silicone that I'm using is a bit softer than other types that I normally use and may be the problem. This stuff is designed for super high details and not being able to pressure cure it makes it a bit flexible. So I built up enclosing walls around the molds so that I could clamp them together from all sides. I also, cut pour vents into the tops of the molds where I had smaller air vents. I then poured in from the top keeping the mold vertical and used less foam.
It worked!! So as you can see in the pics. I have to sand the pod nose points back after molding which is acceptable. The pour that I did today was with no prep to the molds. So no primer or skinning. I let the foam harden for three hours and so far no deformation of the foam after it comes out of the molds. So tomorrow, I'll try one with primed walls but no skin except in the detailed parts.
At least I had 95% success without hardly any flashing and that makes me think that a stiffer silicone will be better for the next go around. Well these pods are costing about $250 to make but should come out ready to mount and thats worth it.
acesimmer is offline Find More Posts by acesimmer
Old Aug 18, 2014, 09:51 AM
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
The repeatability will be fantastic, I am impressed with your efforts. I can make stuff all day long but a one off is only good for the first "re-kit". You have some longevity going here, that's what impresses me!
Eddie P is offline Find More Posts by Eddie P
Old Aug 18, 2014, 12:06 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
lookin great!!!!
corsair nut is offline Find More Posts by corsair nut
Old Aug 24, 2014, 05:44 PM
acesimmer's Avatar
Joined Oct 2011
Eddie..... Yes, the plan all along is to have the ability to manufacture parts when required. I'm a firm believer that spending big bucks on molds and such that it makes sense to go the extra mile and have re-production capability.
Thanks Nut.......
I'll be away for a few days due to a must do trip. BTW, today I maddened the T28 with all going very well. So she should be with the two Euros in Vegas.
Old Aug 24, 2014, 06:10 PM
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Congrats on the maiden Ace! Did you get any video?
DamonH is offline Find More Posts by DamonH
Old Aug 26, 2014, 12:48 AM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
exellent news jim!
Discussion Looking for a composite lightweight 90mm jet? firehawkzach Electric Ducted Fan Jet Talk 21 Jan 25, 2013 06:26 PM
Discussion Scratch Build RQ-7 Shadow Composite/Balsa parri0923 Balsa Builders 2 Jan 17, 2013 04:17 PM
Sold Stearman PT-17 scratch-build from Barron's Scale Classics Plans 1/6th Scale spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 5 Jan 06, 2013 10:01 PM
Build Log Scratch Build Composite UAS System parri0923 UAV - Unmanned Aerial Vehicles 6 Jan 04, 2013 04:27 PM
Discussion Euro Fighter Typhoon scratch built for 90mm fan Lboogie Electric Ducted Fan Jet Talk 56 Jul 22, 2009 12:59 PM
