Old Jan 28, 2016, 08:00 PM
uninc4life2010 is offline
Find More Posts by uninc4life2010
Joined Jan 2016
What is a good option for my first 3D electric plane?
I've wanted to get into 3D planes for a while now, and I was looking for some suggestions on a good first electric 3D plane. I saw the 47" Extra 300 from 3DHC, and it looked like a good option. I'm concerned that something like a 58" Edge 540 or 60" Yak 55 is too much plane for someone's first 3D'er. What do you all suggest, and how much will I generally expect to spend on all of the electronics needed to fly one of these?
Planes in question:
47" Edge
http://extremeflightrc.com/47-Extra-...lue_p_630.html
58" Edge
http://extremeflightrc.com/58-Edge-5...low_p_686.html
60" Yak 55
http://extremeflightrc.com/60-Yak-55...eme_p_704.html
uninc4life2010 is offline Find More Posts by uninc4life2010
Old Jan 28, 2016, 09:35 PM
VR Eyedoc is online now
Find More Posts by VR Eyedoc
Hardcore EP 3D Flyer
VR Eyedoc's Avatar
Canada, ON, Toronto
Joined Aug 2012
the first 3D plane should always be a fomie.
VR Eyedoc is online now Find More Posts by VR Eyedoc
Old Jan 28, 2016, 10:30 PM
tuck is offline
Find More Posts by tuck
Its follow the ******. your #1
tuck's Avatar
United States, CA, Citrus Heights
Joined Feb 2009
There is a part of me that wants to disagree with you VR Eyedoc. But financial responsibility suggests I agree.
Uni, edges are great, Yaks are a bit more difficult to 3d, better suited for extreme aerobatics.
Buy an epp (twisted hobbys) frame or two, then buy a balsa. 60" is easier to 3d.
tuck is offline Find More Posts by tuck
Old Jan 28, 2016, 10:33 PM
dalecheek1 is offline
Find More Posts by dalecheek1
United States, NC, Garner
Joined Nov 2012
48in TH Sbach ...Minor 3D in small space.....
06 21 15 TH 48" Sabch low an slow in small area (5 min 2 sec)
dalecheek1 is offline Find More Posts by dalecheek1
Old Jan 28, 2016, 10:51 PM
Joined Jan 2016
Thanks for the input! I'm flying a foam scratch-built FT Racer right now. It's great because the airframe was almost free to build, the electronics were very cheap, and it costs me only my time to fix it if the electronics aren't damaged. However, it is also not a true 3D plane, so there is that.
Old Jan 29, 2016, 12:44 AM
Krinaman is offline
Find More Posts by Krinaman
Joined Sep 2015
I would suggest a twisted hobbies EPP as well. The main thing is you want something you aren't afraid to crash. Spending $700-$800 on a 60 inch and then never 3Ding it because you are afraid to wreck it doesn't help you at all.
Cost would depend on what you model went with and what electronics. But somewhere in the $300ish range for everything assuming you get the TH power pack.
Krinaman is offline Find More Posts by Krinaman
Old Jan 29, 2016, 12:49 AM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
Originally Posted by vr eyedoc View Post
the first 3d plane should always be a fomie.
+100
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Jan 29, 2016, 07:11 AM
fauconnier is online now
Find More Posts by fauconnier
Flying a Falcon or a RC Heli.
fauconnier's Avatar
Canada, QC, Rimouski
Joined Jul 2012
It's always a good idea to look at old threads.
http://www.rcgroups.com/forums/showthread.php?t=2586436
fauconnier is online now Find More Posts by fauconnier
Old Jan 29, 2016, 07:19 AM
Wingin' Wayne is offline
Find More Posts by Wingin' Wayne
I like the violent stuff!
Costa Mesa, CA
Foam is your friend! TH foamies rock. Learn foam- go balsa as countless others have.
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old Jan 29, 2016, 01:25 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
I've seen people learn to be awesome at 3D with 50cc airplanes. the most important part is knowing the kinds of things that you enjoy and pursuing them with a quality airplane
Foamies help you do things low with general wild abandon. If what you enjoy is also tumbles, and KE spins and things with energy, then foamies probably aren't the way to go.
Either way, it's all about the practice.
theKM is offline Find More Posts by theKM
Old Jan 30, 2016, 12:50 PM
mnavarro is offline
Find More Posts by mnavarro
United States, CA, SF
Joined Oct 2010
I think epp foamies are great for learning orientation and getting over the fear of the airplane being in certain positions. They are also great for rolling. The next plane should be a less expensive smaller balsa in 42 to 48 size that can fly on 3s. My favorite so far is the 3dhs slick 580 Learn the basic inertia moves.. You can fly anthing after that.
mnavarro is offline Find More Posts by mnavarro
Old Jan 30, 2016, 04:27 PM
BenBen123 is offline
Find More Posts by BenBen123
Who cares? Fly extreme!
BenBen123's Avatar
United States, WA, Bellingham
Joined Nov 2013
yep i started out with katana md from Precision aero bactics but that was not a good idea. I think i had 2 flights on the thing and it was toast.
I reccomend something from twisted hobbies if you have a few hours of building under your belt.
Ben Vw
BenBen123 is offline Find More Posts by BenBen123
Old Jan 30, 2016, 06:03 PM
PapaTrey is offline
Find More Posts by PapaTrey
PapaTrey
PapaTrey's Avatar
United States, GA, Fayetteville
Joined Jun 2011
Mine first was the original addiction. Looked so easy to fly. It didn't make it through the 2nd weekend. The twisted hobbies crack yak, on the other hand, has been with me for coming up on two years in April.
In my mind, the confidence to fly it aggressively is the most important thing. It only takes a few minutes for the glue to dry and you are back in the air. Beat the snot out of it, learn a few things, then try your hand with balsa. My two cents.
PapaTrey is offline Find More Posts by PapaTrey
Old Jan 31, 2016, 12:23 PM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
DW Foamie Fusion (hybrid EPP-Depron). I love mine and still have one for park flying.
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Jan 31, 2016, 01:55 PM
mnavarro is offline
Joined Oct 2010
I know a lot of people recommend the twisted hobbies airplanes and they are absolutely fine, but for the price I like the techone or value hobby epp airplanes. The are just as good for learning the moves and there is virtually no difference for what you are trying to do.. For example value hobby has a 32" model for $25. I actually prefer the hardware on the techone airplanes. The foam on the twisted hobbies does feel a little more dense.
Discussion What 3D Nitro Planes Plane for Amateur 3D Pilot? HoosierGuy Beginner Training Area (Aircraft-Electric) 3 Sep 22, 2015 08:13 AM
Discussion What's a good first 3d airplane? Spkey 3D Foamies 5 May 15, 2015 11:41 PM
Help! Looking for a good first 3d plane :) b2f 3D Foamies 31 Jan 07, 2015 06:40 PM
Help! looking for a good 3d electric motor for my PZ extra 300 SuperPilot007 3D Flying 6 May 27, 2014 12:19 PM
Question Whats a good first 3D plane? big_poppa4904 3D Flying 88 Dec 18, 2012 12:32 PM
