Old Nov 10, 2012, 01:43 PM
Livermore, CA
Joined Sep 2004
V929 Battery JST plug
I got a couple V929's flying and have a heck of a time disconnecting the battery. Its so tight it feels like I might rip the wires out of the board, so I sometimes use a small screwdriver to seperate them.
I got in some Tiger batts and they were the same.
So I took a magic marker and colored a male batt plug to see where it rubbed when I inserted it. It rubbed all around, meaning the female plug was just too small!
I dug into my connector stash and out of several dozen JST plugs I have, I found there was two sizes!!
The larger ones fit together ok and so do the smaller ones.
But a smaller male in a larger female is almost too loose and the larger male into a smaller female is way too tight!
So I made a tool out of pushrod wire(flattened a bit with a hammer) to push into the plug and release the wires, so I could change the plug.
It was a bit of a pain, but worth it.
Now it snaps together and releases just fine.
Butch777 is offline Find More Posts by Butch777
Old Nov 10, 2012, 02:02 PM
United States, TN, Knoxville
Joined Jun 2012
My U816 is hard to disconnect if pushed all the way. I may try a dab of vaseline on it.
variantman is offline Find More Posts by variantman
Old Nov 11, 2012, 12:25 AM
Tucson, Az
Joined Feb 2007
I used an axacto blade to slowly trim male plug to fit easier. Yes they make them way to tight and even after alot of use still tight. Rub a tiny drop of oil on finger and apply to plug. Make sure hands are dry to remove plug. U816 I had plug was insane tight now its much better.
dankar04 is offline Find More Posts by dankar04
Old Nov 11, 2012, 09:14 AM
KDS450QS(ZYX4),V977,CX-20
FyreSG's Avatar
United States, CA, Monterey
Joined Apr 2012
I cut grooves on the male and female JST connectors, so my fingers have more grip when I pull them apart.
FyreSG is offline Find More Posts by FyreSG
Old Nov 11, 2012, 11:40 AM
Livermore, CA
Joined Sep 2004
After I matched the right JST ends to each other, they snap together and apart quite easily, no struggle at all.
Old Nov 11, 2012, 08:12 PM
natscape's Avatar
Philippines, NCR, Makati City
Joined Sep 2012
I put HST on both male and female jst connectors to provide a better grip.
natscape is offline Find More Posts by natscape
For Sale UMX to JST adapter and battery plugs Hammer Aircraft - Electric - Batteries & Chargers (FS/W) 2 Oct 24, 2012 01:44 PM
For Sale EC3 Plug with JST Plug for UBEC Mikemynameis Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 17, 2012 09:24 AM
For Sale EC3 Plug with JST Plug for UBEC Mikemynameis Aircraft - Electric - Power Systems (FS/W) 0 Aug 12, 2012 09:54 PM
For Sale EC3 Plug with JST Plug for UBEC Mikemynameis Aircraft - Electric - Batteries & Chargers (FS/W) 1 Aug 09, 2012 09:21 AM
Discussion Battery Voltage different When Measured on Balance Plug and JST Plug Tracks FPV Talk 3 Sep 02, 2011 03:08 PM
