Old Feb 10, 2016, 08:31 AM
Jerome Morris is offline
Find More Posts by Jerome Morris
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
Question
machine screw removal?
I would like to get this machine screw out.
It's attaching two parts together that are cast aluminum.
I've put some heat to it and penetrating oil to no avail.
I would like to save the screw .
Ideas? more heat? drill it out?
Jerome Morris is offline Find More Posts by Jerome Morris
Old Feb 10, 2016, 09:49 AM
tghsmith is online now
Find More Posts by tghsmith
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
you could try an overnight soak in a mild acid solution(vinegar)you most likely have some dissimilar metals crud in play..
tghsmith is online now Find More Posts by tghsmith
Old Feb 10, 2016, 10:41 AM
boater_dave is online now
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
Penetrating oil is very helpful, but I've found some work better than others. Which did you use, and how long has it been soaking? Repeated heat cycles are also helpful. When you are ready to try again, start with a cold assembly, then rapidly heat the outer aluminum. This will expand faster than the screw and possibly break the bond.
It doesn't look like a beefy assembly, so an impact driver may be out but a sharp rap on the head of the screw sometimes is enough.
Why save the screw?
Dave
boater_dave is online now Find More Posts by boater_dave
Old Feb 10, 2016, 10:52 AM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I have had good luck by heating very hot with a propane torch, and then dropping into cold water. The shock cooling breaks up the corrosion holding the parts stuck tightly together.
Kmot is offline Find More Posts by Kmot
Old Feb 10, 2016, 11:08 AM
heavymeasure is online now
Find More Posts by heavymeasure
United States, IL, Chicago
Joined Jul 2011
Heat the Aluminum and hit with the set screw with penetrating oil. Or soak in diesel fuel overnight.
heavymeasure is online now Find More Posts by heavymeasure
Old Feb 10, 2016, 01:01 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Soak it in some Aero Kroil.
green-boat is offline Find More Posts by green-boat
Old Feb 10, 2016, 01:36 PM
Union, Maine
Joined Jul 2006
Good ideas, Thanks.
Liquid wrench was the oil used.
Have some Corrosion X I could try as well.
Old Feb 10, 2016, 02:10 PM
AirDOGGe is offline
Find More Posts by AirDOGGe
Just Plane Nutts
AirDOGGe's Avatar
United States, CA, Mountain View
Joined Dec 2011
This is what I use on my old, rusty bike rebuilds.... http://www.jlsmithco.com/lubricants/...ant-11oz-spray
Nasty stuff on your hands and hard to wash off, so use good rubber gloves.
And if you use heat to help loosen the screws, use it gingerly. Aluminum melts at 1,200 degrees F, and that's an easy temp to reach with propane and small parts.
AirDOGGe is offline Find More Posts by AirDOGGe
Old Feb 10, 2016, 02:45 PM
txt killer is offline
Find More Posts by txt killer
Joined Apr 2008
Soaking it with penetrating oil is the best option. it may take a while to loosen up.
txt killer is offline Find More Posts by txt killer
Old Feb 10, 2016, 02:50 PM
ericbphoto is offline
Find More Posts by ericbphoto
Submarine or Target?
ericbphoto's Avatar
United States, SC, Piedmont
Joined Jul 2013
All the above are good ideas. They hit all my favorite oils. Soak overnight.
Try turning the screw in the tightening direction to see if that breaks it free.
You can also carefully use a small punch and hammer at the edge of the screw to tap it in the loosening direction.
Make sure your screwdriver is the proper size. A undersized or dull or rounded screwdriver blade will quickly destroy the slot in the screw head.
Last resort is drilling. Often, a left-handed drill bit will catch and remove the screw without having to use an extractor.
Not sure heat will work well this time. The screw is probably not aluminum. So if the screw expands more than the aluminum when heated, it will just be tighter when hot. It's worth a try though.
ericbphoto is offline Find More Posts by ericbphoto
Old Feb 10, 2016, 05:46 PM
Harquebus is offline
Find More Posts by Harquebus
I see all your typos
Harquebus's Avatar
South Korea, Gyeonggi-do, Ansan-si
Joined Jan 2006
+1 for Liquid Wrench. Works better at penetrating than WD-40 or anything else I've tried.
Also try tapping the area lightly with a non-marring hammer. Vibration helps break loose frozen parts.
Harquebus is offline Find More Posts by Harquebus
Old Feb 10, 2016, 05:50 PM
Harquebus's Avatar
Joined Jan 2006
This.
Most people just grab a generic flat blade screwdriver and 'make it work' even though it mars the screw head if it's undersize. I have a set of hollow-ground screwdriver bits in all sorts of sizes that that I use when precision is needed.
Old Feb 10, 2016, 07:34 PM
Union, Maine
Joined Jul 2006
Not to worry. I snapped the head off so will now drill her out.
Thanks for all the help.
Old Feb 10, 2016, 08:53 PM
ericbphoto's Avatar
Joined Jul 2013
Well that sure made the decision easy.
Old Feb 10, 2016, 09:09 PM
AirDOGGe is offline
Just Plane Nutts
AirDOGGe's Avatar
Joined Dec 2011
That was plan "B"...
Discussion Removing Small Sheared Screw Witterings Multirotor Talk 2 Feb 06, 2016 10:15 AM
Help! Need help with removing screw... JookSing The Builders Workshop 12 Jan 26, 2016 03:46 PM
Help! Removing stuck allen screw (to replace motor shaft) Oxotnik Power Systems 22 Jan 15, 2016 07:39 PM
Sold Machine Screws, Nuts, and Screws Thumbolino Aircraft - General - Miscellaneous (FS/W) 3 Jan 31, 2013 07:53 PM
