Old Oct 23, 2014, 07:32 AM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
HobbyKing Quanum Venture FPV Quadcopter
Looks jolly interesting.
This Deluxe package uses only the best components which include a DJI Naza Lite with GPS, Fatshark 250mW video tx and 600TVL fpv tuned camera, MultiStar 2213 motors and matched 20A Afro ESC’s for a plug and fly FPV experience like no other.
The Venture FPV Quad started life as a H-quad giving the camera a forward unobstructed view of the sky ahead, as well as allowing for optimal equipment separation to minimise video transmission interfererence & perfect flight controller positioning for the DJI Naza. With a layout decided, a sleek purpose built molded frame was forged with an aluminum main spar and unibody strengthening. All the best provisions were taken into consideration, making the Venture the best FPV cross platform frame available with options and provisions beyond any other Quad in its class.
The Venture frame has a center spar to which most components attach. The ESC mount/power distribution board has pre-fitted 20A Afro ESC’s and filtered FPV power lines. It also handles the centerline battery mounting. The Multi-mount FC position and Power module support is pre-fitted with a DJI Naza Lite and remote UBEC/USB module. The cross arms allow for in-tube wiring and the motor mounts not only look good, but protect the included 2213 MultiStar motors and have replaceable/optional landing skid options. The front arm mount houses a protected center camera mounting cube with a FatShark FPV tuned 600TVL camera pre-installed and wired with vibration isolation pads. The lower molded unibody shell attaches to the arms and spar and has provisions for universal gimbal mounting and tall skids as an option. The lower shell also has a rigid top cross roll bar that also plays the role as the GPS mount. At the rear of the lower shell a mounting cube for the included Fatshark 250mW FPV video transmitter. The upper shell is vacuum formed polycarbonate for a balance in weight and strength and lends well to customizing. Access ports have been made for all types of gear so maintenance is a snap.
The Deluxe Package only requires you to install your favorite radio receiver and calibrate the transmitter, charge up your 2200 3s battery and slip on your FPV goggles for an elevated experience. If you’re new to FPV or just want a multi-rotor that you can pull out of the back of the car and fly FPV without any hassles, the great design and top quality components make the Quanum Venture Deluxe edition a platform you can trust.
The Venture is a refined evolution of multi-rotor DNA, and exemplifies cross use without compromise.
Features:
• Goggle ready FPV fun
• Pre installed and tuned DJI NAZA with GPS
• Pre installed MultiStar motors and matched Afro 20A ESC’s
• Pre installed FatShark 600TVL FPV tuned camera and 250mW video TX
• GPS/ATTI/RTH/Acro flight modes
• Unibody construction with spares availability
• Quad esc mounting/PDB with filtered FPV power
• Protected stylish Motor Mounts
• Universal gimbal mounting and tall skid options
• Provisions for all types of equipment pre-molded
• Styled looks with true functionality
• Pre-installed motors and ESC
Specs:
Wheelbase: 430mm
Weight: 440g (AUW 1050g w/battery)
Max prop: 8~10inch
FC mounting: Naza Lite GPS pre-installed
Power Distribution: 4 Afro 20A esc pre- installed with XT60 power lead
Motors: 2213 935KV Multistar Motors pre-installed
FPV camera: Fatshark 600TVL FPV tuned CMOS
FPV TX: Fatshark 250mW 8ch Video TX pre-installed
Gimbal Mounting: 45mm square and 40mm centerline
For Specs and information on individual components please visit the associated page under the related items
Included:
Quanum Venture FPV frame
DJI Naza Lite With GPS
Fatshark 600TVL FPV Tuned CMOS camera
Fatshark 250mW FPV video TX
4 x Afro 20A esc pre-installed
4 x 2213 935kv Multistar motors pre-installed
4 x Propellers 8×4.5
Wrench set
Hardware
Instructions
Recommended Parts:
5ch Radio
2200~4000 3s battery
Note: Free Shipping offer is only available for this product. Offer is not available when other items are in the cart.
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Oct 26, 2014, 12:06 PM
Arck is offline
Find More Posts by Arck
I land with enthusiasm
Arck's Avatar
Lima-Peru
Joined Aug 2004
OK guys just bought it let see what arrives,,,
Arck is offline Find More Posts by Arck
Old Oct 26, 2014, 02:05 PM
Gaftopher
Joined Feb 2007
I will watch with interest, my finger keeps hovering over the buy button. We have a postal strike over here in South Africa its been going on for three months so I am worried it would not arrive. Very tempted.
Old Oct 31, 2014, 05:24 PM
UAVJOE is offline
Find More Posts by UAVJOE
Sr. Ext. UAS Pilot, NMSU FTC
UAVJOE's Avatar
United States, NM, Las Cruces
Joined Feb 2012
Just bought the version with power system only. I will be installing the PixHawk Flight controller. I will let you all know when it arrives.
Looking forward to details from others.
UAVJOE is offline Find More Posts by UAVJOE
Old Nov 17, 2014, 11:20 AM
Punisher_67 is offline
Find More Posts by Punisher_67
Another Dumb Canadian
Punisher_67's Avatar
Joined Feb 2012
I am thinking of pulling the pin on this also - anyone have this yet please some input .
Punisher_67 is offline Find More Posts by Punisher_67
Old Nov 17, 2014, 12:00 PM
UAVJOE is offline
UAVJOE's Avatar
Joined Feb 2012
i got mine and installed a RCTIMER FixHawk Autopilot. Flys good but it is under powered. It take 86% throttle to hover. I have swapped out the stock 8in props with 9x4.7 CF and went to a 4s. Much better. getting about a 10-15min flight depending on flight profile. I also added strip lights to the main fuse for night orientation.
Old Nov 18, 2014, 12:37 AM
Gaftopher
Joined Feb 2007
Was that with the supplied motors and ESCs?
Old Nov 18, 2014, 01:19 PM
UAVJOE is offline
UAVJOE's Avatar
Joined Feb 2012
Yes. Supplied motors and esc.
Old Nov 18, 2014, 01:20 PM
Gaftopher
Joined Feb 2007
Thanks Joe
Old Nov 19, 2014, 02:58 AM
Dogdude is offline
Find More Posts by Dogdude
Joined Aug 2012
Are the feet tuned ?
Seems everyone prefers "tuned items" as they must work better
I'm gonna hold out for my next quad til someone brings one out with tuned feet and arms
Dogdude is offline Find More Posts by Dogdude
Old Feb 15, 2015, 04:41 PM
StefPez is offline
Find More Posts by StefPez
France, IDF, Paris
Joined Jan 2015
Hello.
I have to change an ESC on my venture
the motor stops randomly...
Do I have to solder anything or just plug this item http://www.hobbyking.com/hobbyking/s...Firmware_.html
Sorry for my question but I don't have my venture with me to check...
StefPez is offline Find More Posts by StefPez
Old Jun 22, 2015, 11:42 AM
RyanBRZ is offline
Find More Posts by RyanBRZ
Joined Dec 2014
Would anyone recommend this quad as my first non-toy quad?
Looking for a possible fpv setup but initially just want something I can fly around, no racing. Would like a flight controller that I can set flight plans and gps home.
How is durability and availability of replacement parts? Is the quality of this quad good? Looking to spend $150-$250 if you have any recommendations.
Also found this one http://www.rcgroups.com/forums/showthread.php?t=2428836
And this
http://www.hobbyking.com/hobbyking/s...Case_PNF_.html
I can't decide, please help!
Thanks!
RyanBRZ is offline Find More Posts by RyanBRZ
Old Jun 23, 2015, 09:19 AM
2bluesc is offline
Find More Posts by 2bluesc
PCB Wizard
United States, CA, SF
Joined Oct 2010
And this
Holy thread resurrection!
I bought the quad as my first quad (it's now for sale ironically in the classifieds) and loved it. I outgrew it as I got in to FPV racing 250 sized quads. As for durability I haven't had to replace any parts, but would recommend a spare frame and of course props since they are cheap.
The onboard Naza Lite can do return to home out of the box, just read the docs.
I bought the extended height landing legs and they broke the first day, like many other people. Other then the aftermarket legs, the quad is solid!
2bluesc is offline Find More Posts by 2bluesc
Old Jun 23, 2015, 05:44 PM
RyanBRZ is offline
Joined Dec 2014
Thanks!
Does naza have the ability to set flight plans through a pc?
Looking at this one, which allows me to pick my own flight controller. I was looking at APM. My only concern is the motors, what are your thoughts on this one? If I go with this was, what parts do u recommend replacing immediately?
http://www.hobbyking.com/hobbyking/s..._Version_.html
Old Jun 26, 2015, 05:01 AM
rcnutrc is online now
Find More Posts by rcnutrc
Registered User/FE Boater
rcnutrc's Avatar
United States, CA, Monrovia
Joined Jun 2011
Thanks!
subscribed...
Been looking at this, I only want to fly the thing, I know for flying there are other choices, but i love the looks. if I don't get the Naza and FVP , can it fly with a KK2.1.5?
rcnutrc is online now Find More Posts by rcnutrc
Discussion HobbyKing Quanum DIY FPV Goggle Set with Monitor (KIT) schumixmd FPV Equipment 3572 Apr 26, 2016 08:15 PM
Discussion Hobbyking X-4 FPV Fiberglass Quadcopter Frame WOW neobot Multirotor Talk 93 Mar 26, 2016 04:46 PM
Sold NIB Quanum Nova FPV GPS Waypoint QuadCopter (PNF) moxjett Aircraft - Electric - Multirotor (FS/W) 1 Aug 31, 2014 04:35 AM
Discussion Hobby King Quanum Nova Quadcopter HK Hobbyking Dogdude Multirotor Talk 220 Jun 07, 2014 02:20 AM
Discussion Quanum Nova FPV GPS Waypoint QuadCopter (Mode 2) (Ready to Fly) $319!! LDGILLS Multirotor Talk 0 May 28, 2014 09:17 AM
