Old Oct 05, 2013, 05:37 AM
carlbrid is offline
Find More Posts by carlbrid
United Kingdom, England, Blackpool
Joined Oct 2013
Just bought a Protech PT80
Just bought this un-run motor off of ebay
Hope you guys can offer some assistance
Carl bridson
carlbrid is offline Find More Posts by carlbrid
Old Oct 05, 2013, 06:37 AM
Dr Honda is offline
Find More Posts by Dr Honda
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
Start with posting a pic of what you got. As I recall... the fuel pump they tired to use, was a washer pump... and it wouldn't meter fuel worth a dam. Because of that... they didn't run very well. So... if you have that pump... you may want to start with getting a proper fuel pump.
The Pro-Jet ECU's aren't bad, and are still being made. You may want to contact pro-jet and see if there is a software upgrade for your ECU.
The one down side to that engine is... they tried to use stainless steel for many of the internal parts... and it doesn't last long. But, since it's a "New" engine... you should have a few hours of good running.
Regardless.... if you got it cheap... then it will be a good "Starter" engine for you.
What part of the world are you in?
Dr Honda is offline Find More Posts by Dr Honda
Old Oct 05, 2013, 04:28 PM
carlbrid is offline
Joined Oct 2013
I am in the UK and will try and post some pics
When you say a few hours how many do you imagine??.
Would the software update be done by the internet or would I need to send it back to them ???
Old Oct 06, 2013, 08:57 AM
Dr Honda is offline
Dr Honda's Avatar
Joined May 2004
Run time will depend on how hot it gets. The stainless will break down at higher temps. I know some of the early JJ engine would only go 3~4 hrs before the combustion chamber, or vaporizing tubes would give up. Because of that.... DO NOT try to run it on Diesel fuel. It's more corrosive.
As far as the ECU.... I'm pretty sure you would have to send it to Pro-Jet for an update.
Discussion Just bought an FPV recorder and cannot get good recording quality jasper7821 FPV Talk 12 Feb 13, 2013 03:36 PM
Discussion Just bought off Amazon Kong88122 Electric Heli Talk 1 Feb 10, 2013 07:56 PM
Found 1/10 Brushless system. Just bought slash roller 4x4 Supersteve Cars - Trucks and Parts (FS/W) 2 Feb 09, 2013 06:21 AM
Discussion Just bought a calypso... Bariboy Electric Sailplanes 6 Jan 29, 2013 07:48 AM
Discussion protech pt80 turbine decoysk Jet Turbines 1 Jul 18, 2011 05:17 AM
