Old Oct 12, 2011, 11:07 AM
hamburger is online now
Find More Posts by hamburger
Hamburger
hamburger's Avatar
Joined Jan 2010
possible asymetric quadplus? bi-copter with stabilization rotors instead of tilt?
Hi,
is it possible to build and fly an asymetric quad plus?
I want the front and rear rotors to carry all/most of the weight (like a BI-copter) To compensate torque, these need to pair CW and CCW.
The difference to BI is I do not want to tilt the main motors/rotors but
for stablization etc. it will have two little left/right rotors for roll. As these run with small props, torque should not be that much of an issue but for sake of symetry I would opt for a pair of CW and CCW again.
Rotor sizes would be in my case something like 6 and 10 inch rotors (and two small and two large motors).
The rotation would have to be as in the diagram to compensate for torque, right? This does not follow the rule of thumb provided for quads.
What do you think, possible, been done?
The problem I see is with yaw?
(This question was asked earlier in the multiwii thread but I think it deserves a broader range of experts to discuss)
If you ask why go this way and not choose the proven quad-plus or quad-x all I can say is: because a) it is possible (maybe) and b) to bypass obstacles when flying in narrow space.
Thanks, Hamburger
hamburger is online now Find More Posts by hamburger
Old Oct 14, 2011, 03:36 AM
Hamburger
hamburger's Avatar
Joined Jan 2010
come on!
No response yet meaning 'cannot be done' or 'has been done, boring' or what?
Give me a hint at least, please.
Hamburger
Old Oct 14, 2011, 03:48 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
Interesting idea but CW prop on front and CCW on the rear isn't possible because you'll end up with props spinning in the same direction that are adjacent vs opposite to each other. Any yaw will cause it to destabilize and crash because, in order to rotate CCW, the CW props need to speed up and CCW props slow down (and vise versa).
Placing CCW props on front and rear, and CW on sides would work but you end up with the smaller motors/props being over worked and really weak yaw in one direction.
patricklupo is offline Find More Posts by patricklupo
Old Oct 14, 2011, 03:58 AM
Coptaire is offline
Find More Posts by Coptaire
Spiritual Hovering
Coptaire's Avatar
Paris, France
Joined Sep 2010
This makes me think about the CH-47 Chinook, ala multi-rotor.
It seems much complex to built a solution with fixed props (no blade orientation) than the legacy bi-rotor heli is.
Coptaire is offline Find More Posts by Coptaire
Old Oct 14, 2011, 04:59 AM
Hamburger
hamburger's Avatar
Joined Jan 2010
well, if it was a true BI-copter, the two rotors must rotate CW and CCW in order to avoid constant yaw from momentum, right?
As a second step I need something to stabilize roll, that is where the two small rotors come in (again CW and CCW).
I assume that pitch (increase lift for either front or tail rotor) will work as with usual quad-plus.
So pitch and roll should be covered.
Now to something completely different:
I agree that yaw is the achilles heel of this setup.
On your standard quad-plus you yaw left by increasing front+tail CW-pair and decreasing left-right CCW pair and use momentum difference while maintianing constant overall lift.
In my intended setup the CW props are front and left, if I increase those two and decrease the other two then I get tilt with left+front raise. For the other yaw direction I do net get right-front raise but right-tail raise. Not good!
So maybe I should build a hex instead of a quad:
large BI with superimposed quad-x
front and tail - two big rotors mainly for lift, not used for yaw (CW+CCW)
4 small rotors (two on each side) for roll and yaw. ((2 CW + 2 CCW as with a quad-x)
Sound reasonable?
Hamburger
Old Oct 14, 2011, 05:42 AM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
sounds feasible but i really don't know
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Feb 05, 2016, 01:16 PM
njacobs is offline
Find More Posts by njacobs
Canada, ON, Burlington
Joined Jun 2009
You can do this with OpenAero VTOL
Originally Posted by hamburger View Post
Hi,
Thanks, Hamburger
Its 2016 and you can do this with KK2.1 and OpenAero VTOL
Check this thread, download the manual and read.
http://www.rcgroups.com/forums/showthread.php?t=1972686
Cheers
Nicholas
njacobs is offline Find More Posts by njacobs
Idea Halo Reach Falcon bi-copter -someone- VTOLs 1 Oct 11, 2011 05:52 AM
Discussion VTOL Bi-Copter - Tri-Copter Hybrid uberdisco VTOLs 1 Jul 14, 2011 02:07 PM
Discussion Bi-Copter - Tri-Copter Hybrid uberdisco Multirotor Talk 0 Jul 14, 2011 01:45 PM
Discussion how about a Tri-copter with vanes in the prop wash instead? Sky-walker Multirotor Talk 14 Apr 11, 2011 04:53 PM
Asymetric Plane - Itīs Possible on R/C ? Lucke Modeling Science 19 May 17, 2005 12:30 AM
