Old Feb 14, 2016, 05:36 PM
Acer is online now
Find More Posts by Acer
Acer's Avatar
Loveland, Colorado
Joined Mar 2000
Resurrected My HS1177 Camera for the Second Time
I broke my HS1177 FPV camera today at the field. When I took it apart I seen that a small SMD component popped off the board.
I don't like throwing things away without seeing if I can fix them first, so I turned on the soldering iron and went to work.
The component turned out to be an inductor and it was bad, so I found another inductor off an old broken VTX I had lying around. The new inductor was too large to fit on the board in the same spot as the old one, so I added a couple of wires.
Soldered her up and put the camera back together and crossed my fingers. IT WORKS!
That makes this the second time I resurrected this camera (the first time I soldered the CCD back on the board )
Acer is online now Find More Posts by Acer
Old Mar 25, 2016, 03:00 AM
Exidous is offline
Find More Posts by Exidous
Mildly Awesome
Netherlands, LI, Brunssum
Joined Mar 2011
I just had to do this to mine. Was able to solder the original back in though. Used super glue on the whole board. Covered the sensor first of course.
Exidous is offline Find More Posts by Exidous
Question My bird stops flapping for seconds at a time djacob7 Ornithopters 3 Feb 16, 2015 11:35 AM
Discussion Time to resurrect my 1983 Oly II SHVentus Thermal 15 Nov 01, 2010 10:16 PM
Discussion Second time up with Camera Aboard Autopilot68 Aerial Photography 6 Jul 26, 2008 03:18 PM
I flew my slowstick for the second, and much better time ZackG Beginner Training Area (Aircraft-Electric) 6 May 19, 2004 10:34 PM
Ok, time for my second plane, the dandy sport it is, but I have questions.... DoomsDay Parkflyers 6 Nov 29, 2003 03:26 PM
