Old Feb 02, 2016, 03:45 PM
victapilot is online now
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Build Log
RCM 1/2A Basic Trainer - Electric Conversion
I plan to build one of these from Outerzone plans
Looks like a nice design, 38" span should go well with electric power
victapilot is online now Find More Posts by victapilot
Old Feb 02, 2016, 03:55 PM
victapilot's Avatar
Joined Feb 2009
I'm making the wing with ailerons. Original plane has rudder/elevator only.
Instead of 2 large spars, I'm using three 1/8" x 1/8" spruce spars, one upper, 2 lower.
The leading edge is a 1/8"x1/8" spruce stick laid at 45 deg. I will sheet in between the front upper and lower spars to the leading edge to create D box structure. The back of the D is vertical 1/16" sheet balsa web.
This has worked well for me in the past to create a light and stable structure.
Ribs are 1/16" balsa. The plan calls for 3/32", but I find that I can use less with electric power
Old Feb 02, 2016, 06:31 PM
whowhatwhere is offline
Find More Posts by whowhatwhere
CA...gimme the CA...
whowhatwhere's Avatar
United States, GA, Savannah
Joined Jun 2005
Looking good, vic.
Interesting about the leading edge. I've been working on a Guillows Piper Tomahawk (for years), and the leading edge was a 1/2" x 1/2" balsa stick. The instructions said to sand it into a LE....which I tried with not much success. Until I got one of these...man, if you're building balsa this thing is awesome. you can do larger or smaller diameter leading edges, and it has a V-shape in the center for control surfaces. Didn't take long at all, and the LE on the Tomahawk rocks.
whowhatwhere is offline Find More Posts by whowhatwhere
Old Feb 02, 2016, 06:52 PM
walter3rd is offline
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
i need to get one of those things!
walter3rd is offline Find More Posts by walter3rd
Old Feb 02, 2016, 08:57 PM
Joined Jun 2005
Oh yeah, I highly recommend it. Not to be a shill for Great Planes, but check out these pics. The first shows roughly how much was removed....more than half the stick thereabouts. In the pic of the wing, you can see the seam from the flash, but it's very smooth...you can't feel it. And it doesn't take long to do it, and really not much stress...just let it do it's thing. You need a roll of sticky sandpaper to use with it, which can be pretty handy itself. You can put a strip on a piece of spruce or a dowel and reach into tight spots to sand.
Old Feb 03, 2016, 06:43 AM
victapilot's Avatar
Joined Feb 2009
Thanks for the tip! I have a couple of ply gadgets that were included in kits. Should be easy, I overlap the 1/8" spruce with 1/16" balsa sheet. Only the balsa gets sanded round.
Old Feb 03, 2016, 08:24 AM
Joined Jun 2005
Pics when ya get there....I wanna see how you do the LE.
Old Feb 03, 2016, 09:45 AM
eliworm is offline
Find More Posts by eliworm
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
My Buddy built one of these. A great flying plane.
Jim
eliworm is offline Find More Posts by eliworm
Old Feb 03, 2016, 10:43 AM
victapilot's Avatar
Joined Feb 2009
I'm waiting for the glue to dry on the left wing, so here's what I have.
The bottom part of the D needs to be added, I'll soak 1/16" balsa in water and pull it around using a lot of rubber bands. Using aliphatic Titebond 2.
Sanding gets out most of the imperfections, then light weight filler. Hey, that's what Monokote is for - hiding defects!!
The servo slot is installed, the wing is thick enough to mount the HXT900 servo upright. (when looking at the wing inverted )
The wing weighs 30g at this point, without the aileron.
Old Feb 03, 2016, 12:14 PM
High_Start is online now
Find More Posts by High_Start
High_Start's Avatar
Germany, Berlin
Joined Jan 2016
That's a nice sanding gadget, could you tell me the product name?
High_Start is online now Find More Posts by High_Start
Old Feb 04, 2016, 11:10 AM
Joined Jun 2005
Great Planes Contour Sander (11").
Searching for it on the web I see it offered as low as $8, with $2 shipping. But typically around $10 or so. You'll need a roll of sticky sandpaper, which as I said is pretty handy as well.
Old Feb 04, 2016, 11:13 AM
Joined Jun 2005
Looking really good. I should've soaked some of my sheeting for the Tomahawk as you did, but a little late for that.
I still recommend the contour sander...you get *perfect* LE sanding results using it.
Old Feb 04, 2016, 11:43 AM
High_Start's Avatar
Germany, Berlin
Joined Jan 2016
Ahh great, thanks a lot. Nice build by the way. Seems like a lot of people still know the art of balsa .
Old Feb 07, 2016, 01:50 PM
victapilot's Avatar
Joined Feb 2009
Both wings are assembled. Added some carbon tow to the bottom struts. Need to sheet the bottom LE and the center to 3rd rib
Old Feb 08, 2016, 10:25 AM
Joined Jun 2005
Looks awesome. I typically use a dremel to turn the triangular braces into gussets to reduce weight with no reduction in strength. I love gussets...they work really well and look *so* cool.
Discussion RCM 1/2A P51D Mustang Short Kit Mark Winstanley 1/2A Planes 3 Dec 20, 2015 09:03 AM
Gallery RCM Basic Trainer 1/2a (RCM Plan from 1978) mukaghigonetto 1/2A Planes 4 Nov 23, 2015 07:48 PM
Off Site RCM Basic trainer radio control model airplane kit Mike Fortune Aircraft - Fuel - Airplanes (FS/W) 0 Jul 15, 2015 08:06 PM
Help! RCM 1/2a Basic Trainer Atomikbohm 1/2A Planes 19 Jul 16, 2014 11:39 AM
Question 1/2a basic trainer electric TLHover Glow to Electric Conversions 2 Aug 19, 2012 09:32 AM
