Old May 18, 2015, 02:40 PM
SHPirate is offline
Find More Posts by SHPirate
SHPirate's Avatar
United States, IN, Borden
Joined Dec 2014
Question
What boat to buy??? Blackjack 29 or Lucas Oil
I have decided to try RC boats and I want something fast and reliable. I think I've narrowed it down to the Pro Boat Blackjack 29 or the Aquacraft Lucas Oil / Motley Crew. Which one is faster? Which one has the best hull? Any help on what boat I should buy would be greatly appreciated.
SHPirate is offline Find More Posts by SHPirate
Old May 18, 2015, 09:16 PM
SHPirate is offline
SHPirate's Avatar
Joined Dec 2014
NO one has an opinion or any info on these boats? Come on guys, these are very popular boats. I know some of you have them and have to have personal experience with them. I found a hobby store selling the Aquacraft Lucas Oil boat for $250! That seems like a great deal but I don't want to buy a boat that can't compete with the Blackjack 29 or has an inferior hull. I need your knowledge
Old May 18, 2015, 09:31 PM
fastblade is offline
Find More Posts by fastblade
Joined Oct 2013
Hands down I'd get the BlackJack 29.... just look at the specs alone... BlackJack has a 120 amp esc..... Aqua is only a 60 amp esc... You'd have to spend another $80 to get a 120... Plus max current on a Aqua motor is 5s and only 1800kv.... BlackJack is 6s and 2000kv...... So all in all you get everything you will eventually want in a BlackJack right off the bat.... Plus Horzion Hobby Customer Service is second to none... They usually just replace brand new what ever piece you are having problems with and rather quickly.....
fastblade is offline Find More Posts by fastblade
Old May 18, 2015, 11:11 PM
davonat is online now
Find More Posts by davonat
" DID U SEE THAT!!!? "
davonat's Avatar
Oconomowoc Wi
Joined Mar 2008
I too would get the Blackjack for the reasons stated above.....and as a rule you get what you pay for..... quality in all departments always cost more
davonat is online now Find More Posts by davonat
Old May 19, 2015, 12:14 AM
BHChieftain is offline
Find More Posts by BHChieftain
Joined Apr 2010
Hi,
I have a setup guide for both boats that can help you with some key information.
IMHO, these boats are best run on 4s. Properly set up and using the right prop, they can hit 50mph. For 4s, the Aquacraft 60A esc is just fine-- I use this esc in my p-limited racing hydros with a 2030kv motor and it performs great.
The blackjack's 120A ESC is way overkill for 4s, but not enough to run 6s reliably-- plus 2000kv on 6s is too many RPMs. Again, it is best on 4s.
Both Proboat and Aquacraft make solid RTR models especially in the 30in range. They design the boats to run in NAMBA p-limited offshore class. The electronics in both boats are proven and rock solid (on 4s...). So, don't let the "guts" sway you on the decision.
Regarding the hulls, there are some differences
The proboat cat hulls have wide sponsons, which reduce any side to side rocking. The penalty for this is that it is hard to get them perfectly flat out of the factory, and any concavity in the sponson can result in "bouncing" or "porpoising". You can fix this by blueprinting the sponsons.
The lucas oil (and motley crew) hulls generally do not porpoise, this is because the sponsons are narrower. The cost of that is some side to side rocking. But this is minor.
Bottom line, both hulls perform well, the proboat hull I think handles a little bit better provided you blueprint the sponsons. But the difference is so minor that it pretty much boils down to the paint scheme you like better...
If you want a 60mph/ 6s boat, you need to replace the ESC in both boats, and choose a motor in the the 1500kv range (1800 is pushing it but doable, 2000 is outside the sweet spot). However, these hulls are designed to run in the 50s, if you push them to 60 you should reinforce the hulls else you risk splitting the hulls if they flip. I recommend a custom hand built hull for a 6s/ 60+ config vs. going the RTR route...
If you would like a copy of the setup/running guides for these boats, plus links to the blueprinting tutorial, shoot me a note at jqhydro@gmail.com.
Cheers,
Chief
BHChieftain is offline Find More Posts by BHChieftain
Old May 19, 2015, 05:23 AM
SHPirate is offline
SHPirate's Avatar
Joined Dec 2014
Chief,
Thanks for the great info! I'll definitely send you an email for the set up of both boats. there are a group of guys (5) that live near a local lake that have decided to get these boats and have a little fun. At this point we've only set the guideline that they will all be catamarans and have a length no greater than 32". I think everyone is looking at the Aquacraft Lucas Oil / MC or the Pro Boat Blackjack 29. I'm on a small budget but I don't even want to waste my money if I can't compete. It sounds like set up is everything on these boats!
Old May 19, 2015, 06:02 AM
restart is offline
Find More Posts by restart
Joined Oct 2014
i had a lucas oil and a miss geico29 v2
don't be fooled by the specs , i'm sure the esc is capable off handling a lot more than the 60 amps from the specs , it's smooth ,never got it hot
50 mph : the boat still handled perfect
conclusion : the LO was my favorite boat , sold it after more than 2 years , had the Mg for just a couple months
restart is offline Find More Posts by restart
Old May 19, 2015, 08:48 AM
SHPirate is offline
SHPirate's Avatar
Joined Dec 2014
I'm leaning toward the Aqaucraft Lucas oil. I love the looks of it and at $250 shipped vs $429 for the Blackjack 29 it's hard to beat. $179 will buy batteries and a few upgrades. From what I can tell on the youtube videos the Lucas Oil boats run just as fast as the Blackjack. I'm still on the fence so I would like as much input from you guys as possible.
Old May 19, 2015, 03:00 PM
Joined Oct 2013
After reading the comments from BH... I'm not sure either... There has been many times that I say to myself "why don't I just buy the hull"....but then you gotta mess with linkage, stern hardware etc.... I bought my BlackJack 24 with a blown ESC off of Ebay for half the price of new one and now I have just a little more of what would be the cost of a new one with the mods I did.... Very curious to see these blueprints.... but financially wise sounds like LO might be the way to go... but I'd rather have the BlackJack hull if possible....
Old May 19, 2015, 03:08 PM
dobydog6507 is offline
Find More Posts by dobydog6507
Joined Oct 2011
Either will do well, but the are 4 S boats...dropping 6S in the proboat is doable as per the specks, but for how long??? Plus you had better prop down when doing that as well as the increase in RPM will be VERY hard on the components otherwise.
One other thing to consider is how often you want to end up upside down.....the hull is not really that "sized" for the speeds 6S will give you. Keep them on 4S, and with some prop changes, high 40's to low 50's is achievable and more than enough for boats that size.
dobydog6507 is offline Find More Posts by dobydog6507
Old May 19, 2015, 07:50 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
the BJ3 for sure. it handles way better and is much faster. 6s flick. the Lucas will not handle chop nor speed as well as this BJ3
BlackJack v3 Fully modded (1 min 38 sec)
stoneenforcer is offline Find More Posts by stoneenforcer
Old May 19, 2015, 09:00 PM
SHPirate is offline
SHPirate's Avatar
Joined Dec 2014
https://www.youtube.com/watch?v=akGW5XF1SZM
That boat is awesome but how much money has been thrown at it after the $400 purchase price? If I'm going to completely rebuild the boat I think there are better hulls than the Blackjack 29.
Old May 20, 2015, 08:33 AM
High Dynamic Thrust
Joined Feb 2007
I bought the boat used for 250$ then sold the stock guts. purchased leopard motor $100, esc $120. plus OSE upgrades. I wouldn't under estimate the BJ3 hull just because its a mass production boat.
You can buy just the hull on ebay or HH ect.. either way. the original question of BJ vs Lucas. BJ Hands down
Old May 21, 2015, 09:52 AM
restart is offline
Joined Oct 2014
sorry but the LO , is capable of doing the same with stock motor and esc
see no difference regarding speed /handling chop
Old May 21, 2015, 05:02 PM
High Dynamic Thrust
Joined Feb 2007
yeahhh ok.....
News Pro Boat Blackjack 29 V3 Matt Gunn Racing Boats - Electric 82 Today 12:50 AM
Sold aquacraft boat lucas oil gmcmanv6 Boats (FS/W) 4 Feb 20, 2015 06:33 PM
Sold Aquacraft lucas oil boat like new in the water 1 time. gmcmanv6 Boats (FS/W) 2 Feb 17, 2015 03:21 PM
Sold Pro Boat blackjack 29 with hardware no electronics 90.00 shipped f.a.r.m.e.r Boats (FS/W) 5 Dec 26, 2014 01:16 PM
Sold NIB: Pro Boat BlackJack 29 RTR FE Catamaran Darin Jordan Boats (FS/W) 3 May 13, 2014 05:55 AM
