Old Apr 15, 2015, 05:40 PM
igotit is offline
Find More Posts by igotit
United States, LA, Houma
Joined Jun 2008
Question
sma adapter question
I ordered a set of cheap antennas,i thought I ordered the right adapter...but I was wrong.
im looking at an adapter set on ebay.from the supplied ebay pic it looks exactly like what I need.....but sometimes ads have something different than pictured.
heres the adapter set im looking at,and a picture of what I have.
my rc305 200mw vrx/vtx system both have the same conections.
(pin in the center)
the antennas I ordered are the same but have the correct female nut,but pin in the center aswell.
heres the link....if the item isn't what I need...please direct me.
as stated from the pic....its what I need,i really ont wanna order....wait a few weeks just to get the wrong part because the picture looked correct..
http://www.ebay.com/itm/SMA-Female-T...item19f6e0c305
heres my connection
igotit is offline Find More Posts by igotit
Old Apr 15, 2015, 05:48 PM
DanT is online now
Find More Posts by DanT
DanT's Avatar
United States, TX
Joined Feb 2006
For what you are showing in the picture ( VTX) that looks right to me.
DanT
I can't answer for your receiver setup?
DanT is online now Find More Posts by DanT
Old Apr 15, 2015, 05:53 PM
igotit is offline
Joined Jun 2008
the receiver is identical
I wasn't certin on the termanolgy of the fittings correct name,and ads can be misleading with different pictures.
I just wanted to be sure before I start ordering.i didn't pay enough attention when I ordered this cheap stuff.
thanx dan
heres my 5.8 set
http://www.ebay.com/itm/141383483525...%3AMEBIDX%3AIT
and the antennas
http://www.ebay.com/itm/221725713789...%3AMEBIDX%3AIT
Old Apr 15, 2015, 06:27 PM
Heppy Ket is offline
Find More Posts by Heppy Ket
What place .... is this ???
Australia, SA, Adelaide
Joined Oct 2011
This will get you by, take a careful look and make sure, they look good to me, a useful site, they sell all kinds of pigtails, adapters and all, very reliable, buy with confidence.
http://www.ebay.com.au/itm/SMA-femal...item232c1b46fe
Heppy Ket is offline Find More Posts by Heppy Ket
Old Apr 15, 2015, 06:37 PM
gbmarsh is offline
Find More Posts by gbmarsh
Wait...what?
gbmarsh's Avatar
Canada, BC, Abbotsford
Joined Sep 2010
US based source for good quality adapters.
https://www.dpcav.com/xcart/SMA-Jack...g-Adapter.html
Note, there will always be some loss when using adapters so always be careful when shopping for antennas.
Cheers,
Geoff
gbmarsh is offline Find More Posts by gbmarsh
Old Apr 15, 2015, 07:17 PM
Joined Oct 2011
Don't worry about the loss too much, even IBCrazy includes adaptors with their antennae.
Old Apr 15, 2015, 07:43 PM
igotit is offline
Joined Jun 2008
Thanx guys
Old Apr 15, 2015, 07:54 PM
gbmarsh is offline
Wait...what?
gbmarsh's Avatar
Joined Sep 2010
Sure but that's on his antennas which are very well made as apposed to some of these Chinese antennas which are of unknown and inconsistent quality
That's why I always recommend the Spironet antennas as an absolute minimum antenna choice.
Cheers,
Geoff
Old Apr 15, 2015, 08:29 PM
Joined Oct 2011
True, but lets get this guy off the ground and sort the detail later.
Old Apr 15, 2015, 08:58 PM
igotit is offline
Joined Jun 2008
I agree with gb......quality counts with antennas......but im building a budget rig,will be flying los aswell as fpv.
this rig is just to get my feet wet and flying fpv.
my max distance will be 250-300 yards.
in my other thread someone suggested gogles,and the spironets,ect.
those are ideal for starting out,but this is mostly for playing around.later on ill buy something bigger and better.
a simple starter system will do just fine at the moment.
im into astronomy,and I understand the buy quality concept.the telescope mount is sorta like a fpv antenna......the quality of the mount needs to far exceed the quality of the ota (optical tube)the mount is the foundation of the entire telescope.
thanx for all the input guys
Old Apr 17, 2015, 01:05 PM
igotit is offline
Joined Jun 2008
i ordered the ebay set,$6.50 shipped....ill update once I receive them.
about the antennas.....I have a set of mushrooms with the plastic dome on them,does the dome affect signal?
is the dome needed?
Old Apr 17, 2015, 04:05 PM
Joined Oct 2011
The dome does not affect the signal, it is needed for the folks who like to try and fly through undergrowth there is a possibility of an aerodynamic advantage, but hard to see it on a multirotor.
Old Apr 18, 2015, 11:24 AM
igotit is offline
Joined Jun 2008
thanx heppy
Old Apr 26, 2015, 07:22 AM
panteras120 is offline
Find More Posts by panteras120
Joined Jul 2010
You have two connectors that not match because of the center pin, your VTx have an SMA male connector and the antenna have the same (male), so the two does not match. You need to change the antenna conector by a SMA female connector to be right.
panteras120 is offline Find More Posts by panteras120
Found SMA 90* m-to-f adapter Sixinarow FPV Equipment (FS/W) 2 Mar 17, 2015 11:11 AM
Wanted WTB ImmersionRC 600mw Transmitter and SMA--->RP-SMA adapter BladeScraper FPV Equipment (FS/W) 5 Dec 20, 2014 01:32 PM
For Sale SMA female to RP-SMA male jack RF Adapter Connector geostomp FPV Equipment (FS/W) 2 Sep 09, 2013 06:55 PM
Help! VTX Antenna adapter... [RF SMA male to RP SMA female Adapter] specificaly ! crashtested FPV Talk 3 Feb 09, 2013 04:45 AM
Off Site Adapter RP-SMA Male to RP-SMA Female Right Angle kevinsrc FPV Equipment (FS/W) 0 Nov 21, 2011 04:02 PM
