Old Apr 15, 2015, 09:10 AM
Ole Jacob is offline
Find More Posts by Ole Jacob
Norway, Aust-Agder, Arendal
Joined Dec 2012
Some more testing...
Ft009 15t (540 type) motor. 2200mah 2S Traxxas lipo. (1 min 50 sec)
Ft009 in windy weather... (0 min 22 sec)
Ole Jacob is offline Find More Posts by Ole Jacob
Old Apr 15, 2015, 05:36 PM
Ondahelipad is offline
Find More Posts by Ondahelipad
Ondahelipad's Avatar
United States, FL, Summerfield
Joined May 2014
Originally Posted by Ole Jacob View Post
Looking good! What prop are you using?
Ondahelipad is offline Find More Posts by Ondahelipad
Old Apr 16, 2015, 09:28 AM
Joined Dec 2012
Hobbyking
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
Old Apr 20, 2015, 11:52 PM
SeByDocKy is online now
Find More Posts by SeByDocKy
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Hi, Please read my review of the UDI 002, a direct competitor of the FT009
http://www.rcgroups.com/forums/showthread.php?t=2396370
SeByDocKy is online now Find More Posts by SeByDocKy
Old Apr 27, 2015, 12:05 PM
paksau is offline
Find More Posts by paksau
Canada, ON, Markham
Joined Dec 2014
Deleted.
paksau is offline Find More Posts by paksau
Old May 06, 2015, 10:20 AM
paksau is offline
Canada, ON, Markham
Joined Dec 2014
Parallel Lipo mod
Removing the battery tray and those pesky little tabs at the bottom and top canopy reveals lots of space for an extra stock battery. Not much danger rubbing the driveshaft but I'll probably add some dividers just in case. Haven't tried the boat with 2 lipos yet but I expect almost double the run time.
Love this boat, got one for each of my kids in which we race around the local pond almost everyday now
Also got a pair of 3S 800mAh Life batteries in parallel I can try out with stock setup. Should have more punch with little danger stressing the stocks motors.
Old May 07, 2015, 09:07 AM
paksau is offline
Canada, ON, Markham
Joined Dec 2014
Adding the 2nd lipo for 3000mAh definitely increase run time 2x. The extra weight is felt from the start as the motor pushes the extra mass but once up to speed it was only slightly slower than stock, which makes sense. Shifting the weight up forward should give better balance as I notice the rear sinks more under load.
Two 3S LIFE at 9.9V in Parallel really woke up this boat, speeds were much faster although run times were only about 5 minutes due to the small size of these batts 1600mAh. Very nice, I think it's safe to run the LIFE to finish off the day.
Old May 22, 2015, 11:46 PM
JEP THE KILLER is offline
Find More Posts by JEP THE KILLER
Joined May 2015
My ft009 goes out of control. I think its because of the small amount of water inside the boat
And the receiver is wet. Please help me !!!!!!
JEP THE KILLER is offline Find More Posts by JEP THE KILLER
Discussion Skywalker 2014 - 1800mm - FPVModel - Spanish Review Japanx FPV Aircraft 10 May 12, 2015 06:29 AM
Mini-Review Turbodrone Micro Quad review stallion explosi Multirotor Talk 0 Nov 22, 2013 08:27 AM
New Product Vitality H36's Brother Vitality H39 2.4G 4-axis RC Quadcopter With camera RTF Aaron qin Mini Multirotors 14 Sep 18, 2013 09:02 AM
