Old May 16, 2015, 06:08 PM
OwenD is offline
Find More Posts by OwenD
Australia, NSW, Bowral
Joined May 2013
Understanding brushless drives
For students of brushless drives for multirotors...
I recently made some validation measurements after reconfiguring the brushless drive used on one of my quadcopters.
The upgrade involved resolving a problem with SimonK compability, the solution in this case was simply removing the rather large BEMF caps from the ESC.
This 300+W input power drive is quite low cost, ESC+motor+propeller were around US$30 total... so this is budget hardware.
The measurements and write up are at Report on Hobbyking 40A ESC 4A UBEC 9261000003 / BC3540-14 brushless drive #2.
Note the very good fit to the first approximation models, an indication that the system does not contain components that are misbehaving.
Owen
OwenD is offline Find More Posts by OwenD
Old May 22, 2015, 05:25 AM
pmanu is offline
Find More Posts by pmanu
Brett
pmanu's Avatar
Auckland,New Zealand
Joined Jul 2005
reading ESC Settings
Is there any software that can read the simonk flashed ESC like the BLHeli software does ?
pmanu is offline Find More Posts by pmanu
Old May 22, 2015, 10:41 PM
OwenD is offline
Joined May 2013
Exactly like BLHeliSuite... probably not.
AVRDUDE and an appropriate ISP adapter to read unprotected memories.
AVRDUDE and USB Linker can read flash if you have the SimonK bootloader installed.
Owen
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
