Old Jan 31, 2016, 08:48 AM
bogbeagle is online now
Find More Posts by bogbeagle
Joined Mar 2007
Arrangement for multi-engines.
How is the electrical power organised on multis?
For example; let's say that I want to use 3 motors on a fixed-wing model. The great advantage of electric power is that I can probably avoid having an "engine out", with the associated control problems.
If each motor has a separate power supply, then I could still find myself having to deal with asymmetric flight, if one battery became exhausted prior to landing.
Do you run several motors from a common power supply? Or what?
bogbeagle is online now Find More Posts by bogbeagle
Old Jan 31, 2016, 09:59 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Several motors and one battery (or more than one but connected in parallel) is common.
Of course you still have the possibility of one ESC dying or the LVC on one being lower so cutting that motor first if you try to run too long. Nothing is perfect.
Steve
slipstick is online now Find More Posts by slipstick
Old Jan 31, 2016, 10:08 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally Posted by bogbeagle View Post
... Do you run several motors from a common power supply?...
too long battery wires will kill ESC over time: precautions, solutions & workarounds
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jan 31, 2016, 10:27 AM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
I have seen lots of people talk about common power supply. I ran H9 Twin Otter on separate and it was a bit tricky getting back from strong downwind when one cell in a battery failed.
But to be fair the battery had poor reliability record, I found out after from others who experienced failures with particular brand.
Now if I had the two batteries on that plane connected in parallel and then powering both motors maybe I would only have experienced a fair power drop to both motors instead of totally losing one motor due to the bad battery going to LVC.
With good quality batteries I fly with confidence either way.
davidmc36 is online now Find More Posts by davidmc36
Old Jan 31, 2016, 10:33 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
And if you want to add some extra wire length it can be nice to have Data Logging ESC. When I did an extra foot or so of heavy guage wire on the 7 Foot 182 the logs showed like 1% ripple, so only 10% of the level that Castle says you should add Caps at to protect the ESC. So there was absolutely no need to add any caps.
http://www.castlecreations.com/produ...-cap-pack.html
Old Jan 31, 2016, 11:34 AM
Joined Mar 2007
So, a common battery ... with each motor having its own ESC.
Would that be considered to be good practice?
I am thinking of modelling a tri-motor ... Dewoitine 332. Don't want to find myself with no power and unable to reach the runway.
You can prolly tell that I don't have much experience with electric models. I do fly a couple of powered gliders, but nothing fancy.
Old Jan 31, 2016, 12:44 PM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
My Concorde twiin EDF has separate battery to each motor but my Tu144 has paired batterys....
Which is best ? To be honest logic says PAIRED. In practice ? Yes I have had my Concorde suffer reduction of power on one side ... and its obvious by SOUND when it happens ... the synch of motor sound goes awry. Did it cause loss of model ... no but it sure made my heart race.
The criteria is not whether you have separate batterys - but the capacity you need to fly for a reasonable time. A single battery could be the answer but it would need to be a substantial C rating to cater for the demand on it. With multiple packs paralleled - the C rating can in fact be less - because the packs add up .. I know - some Guru is going to argue this - but I base that statement on actual use and not bench theory.
There is an additional advantage of paralleling packs .. in failure - you only have to replace probably one pack instead of an expensive large single. Second - you can split the packs location so that weight is distributed better.
Nigel
solentlife is online now Find More Posts by solentlife
Old Jan 31, 2016, 02:46 PM
Joined Mar 2007
WRT the 3-engine Dewoitine ... I thought that the centre motor might have its own pack, with the outboard motors sharing a pack.
If either of the packs quits, the model should remain controllable and have at least some power.
Old Jan 31, 2016, 02:59 PM
solentlife's Avatar
Joined Jan 2010
Good idea.
Nigel
Old Jan 31, 2016, 03:17 PM
DKNguyen is offline
Find More Posts by DKNguyen
Edmonton, Alberta, Canada
Joined Oct 2008
If the distances are too great, I would put a battery pack local to each motor that could handle the motor's amp draw on it's own, but then link all of them up on their positive terminal to form a sort of distributed battery pack where the local battery pack acts as a transient buffer (sort of like the big capacitors on ESCs) to reduce the voltage spiking on the lines.
I didn't talk about linking up their negative terminals (ground terminals) because that is mandatory if they are all to interact with some other electrical system (i.e. your receiver).
DKNguyen is offline Find More Posts by DKNguyen
Old Jan 31, 2016, 03:58 PM
Joined Mar 2007
Crikey ... that sounds a bit complicated.
Old Jan 31, 2016, 04:02 PM
DKNguyen is offline
Joined Oct 2008
Not really...just set up battery for each motor, and then connect them all without moving where they physically are. That's all it really is.
Old Jan 31, 2016, 06:13 PM
Staffs, UK
Joined Nov 2003
It's actually just what I said originally...several batteries connected in parallel. Just a confusing way of describing it .
Steve
Old Jan 31, 2016, 08:11 PM
Mike Dubovsky is offline
Find More Posts by Mike Dubovsky
Condescending Pedant
Joined Aug 2013
Originally Posted by DKNguyen View Post
. . . I didn't talk about linking up their negative terminals (ground terminals) because that is mandatory if they are all to interact with some other electrical system (i.e. your receiver).
If you do not have a common negative wire that is capable of carrying the expected unbalanced current ( such as if one battery sags earlier than the others) then the puny servo sized wires that link the radio signal to all the ESC's will be forced to carry current that they are not intended to, and carry it through the receiver bus. Better to use a common negative conductor that can carry the full motor current. Of course best of all is to never get near the point where the batteries might be fully discharged with a multi-motor plane. Or any plane for that matter.
Mike Dubovsky is offline Find More Posts by Mike Dubovsky
Old Jan 31, 2016, 08:13 PM
DKNguyen is offline
Joined Oct 2008
Yes, wire up the negative as if they were motor wires and not just token electrical connections.
Data Wiring Diagrams for Multi-Engine PARK FLYER Electrics P. Tritle Scale Kit/Scratch Built 14 Feb 09, 2016 02:22 PM
Discussion Hybrid multi-rotor , gas engine for lift and electric motors for control khaled_abobakr Multirotor Talk 2 May 08, 2015 06:17 PM
Sold LAST DAY to arrange for Toledo pickup--Several boats to move... pmisuinas Boats (FS/W) 8 Apr 01, 2014 06:59 PM
