Old Dec 29, 2015, 09:05 AM
Wing-span is offline
Find More Posts by Wing-span
Chuck it and see!
Wing-span's Avatar
UK, Cambridgeshire, Huntingdonshire
Joined Sep 2006
Ok OK we can all relax!
I believe I have identified the solution to the OSD not displaying issue. To clarify, the manual is I believe wrong when it covers the connectivity between the FY31AP and the OSD. Either that or I am reeding it wrong, I have been known to make mistakes.
The correct connection between the OSD and FY31AP is as in this image here: FY31+OSD.
It works for me!
Thank you to all who have chipped in with advice.
I can tidy up my cabling, finish my install, balance and fly my HK Skyray now...
Wing-span is offline Find More Posts by Wing-span
Old Jan 07, 2016, 12:27 AM
Berkie is online now
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
Hmmm not such good news here about the 31ap
Had mine for years and it was damn expensive at the time. I thought it was supposed to be the bees knees in stabs
Anyhow was wondering if anyone has come across this.
When the 31ap powers up it gives slight ele. down and very slight up left aileron with the same in down right aileron movement, but, if I switch either RTH or CIRC on beforehand (not that there is a need to) then the controls do not move.
Clues anyone?
Berkie is online now Find More Posts by Berkie
Old Jan 07, 2016, 07:37 PM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
Berkie,
Are you saying it effectively changes the trim of the plane depending on how it is switched on?
Old Jan 07, 2016, 08:14 PM
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Originally Posted by Wing-span View Post
Berkie,
Yes, gives slight ele. down and very slight up left aileron with the same in down right aileron movement, but, if I switch either RTH or CIRC on beforehand (not that there is a need to) then the controls do not move.
Also I get no response from either RTH or CIRC once in the air, but I only mention this unless it relates to the above problem, because I don't need RTH or CIRC at the present
Old Jan 09, 2016, 08:28 PM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
When I select RTL or circle my plane just roles over into spiral dive. Any ideas anyone?
Old Jan 09, 2016, 08:37 PM
hendrnk is online now
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Are you sure you have the directions set correctly for your ailerons. ? Sorry to ask a basic question but most of time this is the cause of this type of situation.
Put the FY31 in stabilization mode and move the left wing down. That aileron should move down to correct the wing drop. Same as lift the nose up and the elevator should move down etc.
hendrnk is online now Find More Posts by hendrnk
Old Jan 10, 2016, 04:06 AM
Great Southern Land
Berkie's Avatar
Joined Feb 2007
And another odd thing.
If I select RTH or Circ. when the 31ap is OFF, the elevator slowly comes up about 5mm
Time for an Eagletree I think
Stabs are great though. They expand your flying days so much when you don't have to say "too windy"
Old Jan 10, 2016, 06:23 AM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
I have it mounted in a flying wing. In RC and ABM the plane flies and handles very well so I'm confident the surfaces are moving in the right direction.
Old Jan 10, 2016, 08:52 AM
Joined Apr 2012
The dip switches should be set:
1) off, 2)off, 3) ON, 4) off
And the Tx should be set as a normal plane with separate aileron & elevator.
Sorry if these are very basic suggestions but I cannot think of anything else that would cause that type of situation.
Nigel.
Old Jan 10, 2016, 07:30 PM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
Thank you hendrnk. You are very kind. Over the next few days I will check it all out in the hangar. The wx is too bad for test flying at the moment. I'll need to see if I can fire up the GCS to see if there are settings in there to tweak. Who knows maybe it is set to RTL and circle at 0 height above the ground?!
New Product FY thread: FY20A/FY21AP/FY3ZT/FY31AP/FY90Q/FY91Q/FY-Frame/FY-GCS/FY-OSD/FY-Dataradio yiny0730 FPV Talk 316 Sep 19, 2011 01:30 PM
Discussion Question: KK board and FY-20 or FY-90q Hamanu Multirotor Talk 2 Feb 08, 2011 04:10 PM
AXI'fy your CORONA...NIB 2820/10 iflych52 Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2004 08:24 AM
Fy or Die ? a newbie poll Demolisher Foamies (Kits) 29 Mar 08, 2003 02:31 AM
