Old Apr 08, 2014, 08:38 AM
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, OH, Columbus
Joined Jul 2010
Byron F16XL
Hey guys, I was looking around the net for something diffrent, as Im looking for another project.
I just finished a Byron F16 Trubine build and really like the size of the Byron, and really love Delta wings as I really miss my Delta Dart 106.
So I came accose a short thread about converting Byron F16 to the F16XL. Found a link, sent in my $15 and just recived a full scale print out on makeing your own XL delta wing.
Now Ill be onest, I still new in my mind, (only been flying for 3 1/2 years now) and while I have modded a lot of ARF's, I have never buit anything from a set of plans.
I was thinking of actuly keeping this one edf, I was thinking of useing a XPS fan or Byron Fan on 14s with as much thrust as I can get, and add some thrust vecotring.
As the bryron F16 is already a flooter, and with almost 2x the wing as the orginal, I figured a little exstra battery wont hurt things. and may come out around the same weight due to no elevator control etc.
So I can find little on this convershion. And Im currently looking for a good or bad fuse and rudder, with just the stock wire landing gear to try to build my own.
So do any of you have any info on this conveshion?
Can I just send the plans to a foam cutter and have them make the foam coars?
Thanks Mike
mikes68charger is offline Find More Posts by mikes68charger
Old Apr 08, 2014, 07:04 PM
United States, SC, Florence
Joined Nov 2004
F-16xl
The first model I saw done of this was done by Ivan Munninghoff, he was a contributer to one of the r/c magazines and did an article on it . Sorry I am drawing a blank on the name of the now defunct magazine. I bet, A10pilot, can help some on this because as I recall he and Ivan were good friends.
Regards, Roger
jetjock50 is offline Find More Posts by jetjock50
Old Apr 08, 2014, 07:16 PM
Joined Jul 2010
Regards, Roger
Yes the planes I got sent have Ivan name on them.
Im excited I didn't think it would be so hard to find a old used fuse
Old Apr 08, 2014, 08:36 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
to do it scale i believe there where two fuse section added ,and a bend in the fuse ,so the tail would clear when landing at high AOA. i've seen the nasa bird fly a few years back ,seems to fly well . i know C/N did one to a HP F-16 and it flew well also.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Apr 08, 2014, 10:52 PM
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
I had started this project last year, but I have run into a host of problems.
1st The plans are not to scale, meaning if you use the plans as templates, the parts will not fit.
2nd I got some quotes to have some cores cut and they want an outrageous price to do so. Here again the plans are not scaled correctly, cores will not be cut correctly.
So I decided to just start all over again. Been working on a new airfoil and wing platform so that it would look a little more correct proportions, with out extending the fuse.
So while working of the XL problems this cause me to think about the Falcon 21. (got deltas on the brain) and got side tracked working on this project.
The Falcon 21 actually looks more scale than the F-16XL.
But the work stopped when the T-33 got may attention.
Oh well maybe later, so much to do and so little time.
Clay
racer1 is offline Find More Posts by racer1
Old Apr 09, 2014, 12:55 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
you can say that again Clay
Old Apr 09, 2014, 09:11 AM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
You mean a f21 kfir?
corsair nut is offline Find More Posts by corsair nut
Old Apr 09, 2014, 09:13 AM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
Just googled it..falcon 21 is pretty interesting!
Old Apr 09, 2014, 11:18 AM
5kW Club
racer1's Avatar
Joined Feb 2007
Yes it is. It was a concept plane before the XL. But notice the wings now belong to the F22.
Clay
Old Apr 09, 2014, 12:56 PM
Joined Jul 2010
Ya its cool, I never new the F16 was redesigned so many ways.
So how much were you being quoted for the foam coars?
I really think this would be a fun project. Still looking for a doner F16 but Im sure it will pop up
Old Apr 09, 2014, 02:45 PM
5kW Club
racer1's Avatar
Joined Feb 2007
Quotes around $200.00 per set.
Like I said the places are scaled wrong. You will have to fix them first to even cut cores.
Old Apr 09, 2014, 03:33 PM
United States, MA, Hadley
Joined Oct 2006
Mike, I have a pamphlet on the xl that was written by Ivan and has all the info as well as a contact for the correct wing build, I did have everything to do it as well as a complete correct set of plans, but I think I sent them to someone else who was in need. sucks to get old You probably have the same thing, but if you need these I think I can scan it and email it.
nighthawk117 is offline Find More Posts by nighthawk117
Old Apr 09, 2014, 04:57 PM
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Plans and Cores
I got the plans, Got a set of cores done by Ivan and I have a NIB F-16 kit, one of these days I will finally build it.
Ralph
CRCJA is offline Find More Posts by CRCJA
Old Apr 09, 2014, 04:58 PM
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
PLUS we won't mention that some of those that quoted us now list the plans and cores for sale We sent the drawings and a digital copy BUT it was at least $250.00 per set if I recall
Ralph
Old Apr 09, 2014, 10:53 PM
Joined Jul 2010
I have never bought foam coars before so 200 dose not see like to much
Aerofoil for electric F16XL MattyB Modeling Science 2 May 27, 2004 11:19 AM
F16XL Carnage report isaac-bees Electric Ducted Fan Jet Talk 13 Aug 12, 2003 05:25 PM
F16XL CG--Help isaac-bees Electric Ducted Fan Jet Talk 2 May 04, 2003 08:56 PM
EDF50 Contest: F16XL Progress isaac-bees Electric Ducted Fan Jet Talk 50 May 01, 2003 11:05 PM
f16xl charles packard Electric Ducted Fan Jet Talk 6 Jun 21, 2001 12:53 AM
