Old Jun 01, 2012, 05:38 PM
Step 1: Tear it apart
MassiveOverkill's Avatar
United States, FL, Melbourne
Joined Feb 2011
Super Mono X
Ripmax - Joysway Super Mono X (2 min 3 sec)
$150, yes it's plastic. Thoughts?
My review:
I haven't been able to run her yet as a grub screw was left off the drive dog and I need to go pick one up (glad I tested her in the tub first).
Pictures:
Here you can see the missing grub screw as well as the drain plug on the upper hull::
Size comparison to my Double Horse 7009:
Reciever is a 4 Channel:
Water-proof O ring:
Water cooled ESC:
Hull thickness is a about 3mm
Perfect candidate for a straight shaft with flex end:
Brushless outrunner:
Inside Rear:
Inside Front:
Motor water block:
Accesories include the 2.4 Ghz Tx, 1800 mAH 3S lipo, spare prop and canopy gasket, 2 allen wrenches, and lip charger with AC wall plug as well as DC alligator clips:
Included Lipo charger:
Charge ports for 3S and 2S:
DC input:
Guts:
Self-righting test. I can only see her not self-righting in a a freak turnover in glassy conditions:
Super Mono X self-righting (0 min 47 sec)
Hopefully it won't be hard to find a grub screw for the drive dog and do a video run.
MassiveOverkill is offline Find More Posts by MassiveOverkill
Old Jun 01, 2012, 08:21 PM
Outdoor Extremist
rustlererad3's Avatar
Pennsylvania
Joined Jul 2010
looks fast furious and fun updates in the future
rustlererad3 is offline Find More Posts by rustlererad3
Old Jun 01, 2012, 09:11 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I'm going to have to learn to drive like that, just to aggravate Jan.
bill34207 is online now Find More Posts by bill34207
Latest blog entry: My "Jet Set"
Old Jun 02, 2012, 07:53 AM
Joined Feb 2011
I'm just about to pull the trigger on this. It's so hard to find Joysway boats in the US. The one I'm about to buy says it comes with lipo and charger (normally most higher-end boats don't). I guess I'll have to suffer with lubing the shaft every run (why can't someone make something like a greasable fitting like on u-joints), unless I find a way to rig up an internal u-joint and use a straight shaft.
Old Jun 02, 2012, 08:03 AM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
That's not too bad actually, it is a small boat. There are lots of people who don't have the skills to drive a boat like that, avoiding the bank by throttling down, nice.
Regards, Jan.
pompebled is online now Find More Posts by pompebled
Old Jun 02, 2012, 08:13 AM
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
That thing rips!
Thats actually what i would call "bashing"...............runnin hard and turning quite a bit, mostly full throttle.
The Short bursts.............on off on off on off on off..............are what gets Jan...........
scorpion1 is offline Find More Posts by scorpion1
Old Jun 02, 2012, 08:15 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
This is what drives him nuts!!!......................me too actually
Brushless Tower Hobbies Turbo Vee 3 rc boat (3 min 29 sec)
Old Jun 02, 2012, 08:16 AM
Joined Feb 2011
So I'm seeing alot of positive comments. For $150, this doesn't look like a bad deal? I'm not going to regret this purchase as if I bought a Traxxas?
Old Jun 02, 2012, 08:34 AM
Sneek, Netherlands.
Joined May 2004
You can't really compare the Spartan and a 45 cm mini mono...
Relatively speaking, everything on the Spartan is bigger and more robust, so it should last longer, but the Spartan is capable of higher speed, which puts more strain on the components.
I'm guessing the Super Mono X has the stronger hull, it terms of plastic thickness per weight, but I wouldn't crash both boats at full speed...
Regards, Jan.
Old Jun 02, 2012, 08:05 PM
Outdoor Extremist
Pennsylvania
Joined Jul 2010
you could buy both and compare em for me so i know what to buy when i get a boat
Old Jun 02, 2012, 09:17 PM
Joined Feb 2011
I dropped the hammer on it. Told the vendor if it comes with Lipo and charger to proceed with the order, but if it doesn't, cancel it. I guess I'll find out Monday.
Old Jun 03, 2012, 07:05 AM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
You don't have to grease the flex shaft every run, but you should take it out and dry it off, then re-grease and re-install it after you're done running for the day.
wparsons is offline Find More Posts by wparsons
Old Jun 03, 2012, 05:21 PM
will fly for food
wavekatcher's Avatar
United States, CA, Ben Lomond
Joined Mar 2011
Looks like what I've been looking for in size and price. I went ahead and ordered one today from AlleRC.com, my favorite place to buy hyperion batteries. Hopefullly, I can give you all some newb rc boater feedback next weekend.
wavekatcher is offline Find More Posts by wavekatcher
Old Jun 03, 2012, 05:46 PM
Joined Feb 2011
Great!! Let us know if yours comes with Lipo and charger. Title says \w but underneath it says you have to purchase seperately. On the Chineese websites I see packages with and without lipo and charger.
I'm really hoping I can covert this to straight shaft or straight\flex hybrid.
AlleRC looks like twin of EmpireRC, which is where I got mine from, but it looks like EmpireRC is just a front for a suite of RC vendors.
Old Jun 03, 2012, 09:32 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
Not sure what the big hate for flex shafts is? They work and they work well, there's a reason it's the drive system of choice for electric, nitro and gas boats.
You still have to keep a solid shaft greased properly, so it won't save you any maintenance by swapping to a solid shaft.
In all seriousness, it takes about 5 minutes tops to remove, dry, grease and re-install a flex shaft in most boats.
Mini-HowTo Phoenix Sim DX5e Mono Jack Adapter Solutions: RS Mono Adapter will work! KC Simulators 26 Yesterday 11:38 AM
For Sale Super Tigre Serie X .61 keok Aircraft - Fuel - Engines and Accessories (FS/W) 1 May 14, 2012 11:31 AM
For Sale New Novak GTB 2 w/ X-Drive *GOING FOR SUPER CHEAP* sixshooterstang Cars - Cars and Parts (FS/W) 0 Mar 16, 2012 11:09 AM
For Sale Custom Airbrushed RARE Aeromarine Mini X Deep Vee Mono Hull hydrofreak1 Boats (FS/W) 2 Feb 13, 2011 08:56 AM
Rave Un-Modded x-Twin Mono Vid In 8ft x 8ft Room! Ben-Solo Scratchbuilt Indoor and Micro Models 10 Feb 26, 2006 01:10 PM
