Old Oct 05, 2006, 11:35 PM
goodman is offline
Find More Posts by goodman
goodman's Avatar
Canada
Joined Aug 2002
RC SMART MYSTERY FM80A ESC Program
Hi, Any one has programming instruction for this MYSTERY FM80A ESC, I've bought it from eBay pricing was excellent and the unit looks very good and solid, however it did not come with any instruction.....
Any help is very much appreciated.
goodman is offline Find More Posts by goodman
Old Oct 07, 2006, 02:20 PM
thunder1 is online now
Find More Posts by thunder1
College Park, MD
Joined Sep 2002
Here's the manual for the FM80A: http://www.bidproduct.com/40a60a80a.pdf
The best place to look for ESC related info is here:
http://www.rcgroups.com/forums/forumdisplay.php?f=13
thunder1 is online now Find More Posts by thunder1
Old Oct 07, 2006, 06:44 PM
goodman is offline
goodman's Avatar
Canada
Joined Aug 2002
Great, thank you very much for your help!
Old Oct 09, 2006, 10:15 AM
goodman is offline
goodman's Avatar
Canada
Joined Aug 2002
Okay I've tried it and it doesn't work...it gives all kind of beeb and musical tone and it is very difficult to follow and it doesn't really match the description. I've e-mail to RCSmart and the eBay seller and they claim that you need a programming device to do it.....
So, my conclusion it that this unit can only work with the default setting and probably only the brake could be user programmable.
I must say that the price it too good to be true....
Old Oct 09, 2006, 02:20 PM
College Park, MD
Joined Sep 2002
I've had several of these type ESCs, but not this one in particular. I will say that ANY ESC with beeping tones is very difficult to program. But this one seems especially difficult. The manual doesn't really explain how to alter any setting other than brake.
Also, the LVC settings are incorrect for lipos. It's using a cell cutoff of 2.8 volts which is too low. Use the ESC carefully. I would redcommend to never hit LVC!!!
For $45 you could get this one which supports up to 7 lipos and has better instructions:
http://www.bphobbies.com/view.asp?id...3&pid=A3237681
Old Jan 05, 2007, 09:14 PM
Dakrat is offline
Find More Posts by Dakrat
Sky good, Earth bad!
Dakrat's Avatar
Anchorage
Joined Dec 2005
I know this might be a little late in coming but Signflyer found the right instructions for this series of ESC for bidproducts.com. Hope this helps... (worked for 10 amp esc)
Dak
http://www.rcgroups.com/forums/show...hmentid=1124838
Dakrat is offline Find More Posts by Dakrat
Old Jun 13, 2009, 01:57 PM
snait is offline
Find More Posts by snait
snait's Avatar
Joined Apr 2008
1. Cut-off voltage
option 1. Ni-Mh battery, auto setup
option 2. cut-off for 7S lipo
option 3. cut-off for 6S lipo
option 4. cut-off for 5S lipo
option 5. cut-off for 4S lipo
option 6. cut-off for 3S lipo
2. Start-up mode
option 1: auto set-up throttle range
option 2: fixed throttle range
option 3: high acceleration (hard start)
option 4: low acceleration (soft start)
3. brake
option 1: no brake
option 2: light brake
option 3: medium brake
option 4: heavy brake
4. Running features
option 1: default running direction
option 2: reverse runing
option 3: hard brake
option 4: soft brake
5. Timing modes
option 1: 2
option 2: 7
option 3: 15
option 4: 30
6. PWM modes
option 1: 8K
option 2: 16K
snait is offline Find More Posts by snait
Old Mar 07, 2012, 04:33 AM
JetMech2002 is offline
Find More Posts by JetMech2002
Racing Enthusiast AMA 3557
JetMech2002's Avatar
United States, MO, Sedalia
Joined Sep 2011
Is there a programming card for this POS? I have tried for several hours to program this with the radio without sucess. If not, I am just going to smash it so no one else has to go through the nightmare that this POS is.
JetMech2002 is offline Find More Posts by JetMech2002
Old Mar 10, 2012, 12:12 AM
R Zielinski is online now
Find More Posts by R Zielinski
R Zielinski's Avatar
USA, NH, Madbury
Joined Dec 2007
I'm pretty sure this is a ZTW ESC. I believe I have the same one branded as a Reaper, while they also go by Cyclone Power and other brands. It is actually a very decent ESC, good quality with a 4amp switching BEC. The ZTW program card should work. If you can't find the programming instructions on line for this (ZTW) ESC, let me know. The older ones had a different pattern of beeps and it took me a while to find those instructions. I can get them to you if you need.
R Zielinski is online now Find More Posts by R Zielinski
Old Jul 27, 2015, 05:07 PM
makeitworst is offline
Find More Posts by makeitworst
UH-1 Gunship, AH-1G jock 69-71
makeitworst's Avatar
So Cal ... Kingdom of Taxes
Joined Nov 2008
I did a search for ZTW Programming card on Google and was shocked to find that in the cards pictured was a HobbyWing and several others (I have) with other well known brand ESC Prog Cards.
What is ZTW like the biggest of the ESC makers? Do they make all the RC Smart ESC's too?
makeitworst is offline Find More Posts by makeitworst
Discussion RC Smart ESC Rene046 Power Systems 3 Jan 23, 2010 08:56 PM
Sold 2 RC Smart 30 Amp BL esc for sale xrbeast Aircraft - Electric - Power Systems (FS/W) 3 Jun 28, 2006 12:47 PM
For Sale RC SMART 1480 Outrunner Brushless Motor & & 30A ESC 05USP xrbeast Aircraft - Electric - Power Systems (FS/W) 4 Mar 12, 2006 07:53 PM
RC Smart motors?esc?? dottney Power Systems 1 Jul 08, 2005 08:43 AM
ESC program question??? capt soap High Performance 0 Aug 12, 2003 09:39 AM
