Old Jul 22, 2015, 09:43 PM
nighthawk0077 is online now
Find More Posts by nighthawk0077
Joined Oct 2009
Plush 100amp Faulty?
Not sure what to make of this? ESC seems to arm correctly, but then goes into a self destruct sequence and will not power the motor?!
https://www.youtube.com/watch?v=Js2wg5ZA8yU
nighthawk0077 is online now Find More Posts by nighthawk0077
Old Jul 23, 2015, 07:19 AM
Mike Dubovsky is offline
Find More Posts by Mike Dubovsky
Condescending Pedant
Joined Aug 2013
The video link you included is private. Can't help much.
Mike Dubovsky is offline Find More Posts by Mike Dubovsky
Old Jul 23, 2015, 08:34 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally Posted by nighthawk0077 View Post
... ESC seems to arm correctly, but then goes into a self destruct sequence and will not power the motor?! ...
Which causes/problems have you already been able to rule out?
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jul 23, 2015, 09:58 AM
Joined Oct 2009
Well if i swap out to a different ESC, all works fine, so I would say its definitely the ESC. Just never had a turnigy plush give me any trouble before.
the motor is a MEGA 16/40/1.5RC
Old Jul 23, 2015, 12:05 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Going by the 'Alert' tones, number 3 seems the closest your video noise.
eflightray is offline Find More Posts by eflightray
Old Jul 23, 2015, 02:53 PM
Joined Oct 2009
Yup, except that it arms normally first and then beeps.
Old Jul 23, 2015, 07:22 PM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Your Rx is blinking, indicating it is not bound to the Radio! Rebind, then do a throttle calibration. You MUST turn on the Radio FIRST every time, and look for a solid light. Until you have a solid light, you cannot program anything and have it stay linked between RX and TX. Also be sure the Tx is the last thing turned off every time.
It may help to go into your Radio to Travel Adj, set the throttle "low point to 104-108%, make sure high end is 100% before doing a throttle cal. fwiw Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Jul 23, 2015, 11:09 PM
Joined Oct 2009
Thanks Doug, rx is blinking because i did not power off/on the radio during troubleshooting, (blinking simply means there was a loss of power) but i can assure you its bound as you can see the control surfaces moving.
Old Jul 24, 2015, 06:47 PM
cryhavoc38 is online now
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
With any hobbywing based esc such as the plush, you must have it learn the throttle range.
if the plane has a prop, remove it. If its a ducted fan..then secure the plane..just in case you don't do the steps correctly.
Do this. turn on your tx. set your throttle trim to neutral, move the throttle stick all the way to full
Add power to the esc/receiver.
You will hear a startup tone then one to two beeps. Immediately move the throttle to zero
you will hear another beep, then usually the battery cell count beeps and then the esc will initialize and be ready to go.
test out by moving the throttle.
This routine allows your esc to learn the throttle range of your transmitter.
cryhavoc38 is online now Find More Posts by cryhavoc38
Old Jul 24, 2015, 07:45 PM
Joined Oct 2009
ok now we're just going around and around in circles here guys, this is not a throttle range programming issue as you can clearly hear the ESC arm and then go into a constant beeping.
**update** hobbyking support has confirmed the ESC is faulty after watching the video, replacement has been sent out.
Old Jul 24, 2015, 07:58 PM
ernie b is offline
Find More Posts by ernie b
3RN13
ernie b's Avatar
United States, IL, West Chicago
Joined Feb 2008
I'm glad HK is sending a replacement, but if you pull the throttle trim all the way down I am fairly certain the ESC will complete the arming cycle.
Ernie
ernie b is offline Find More Posts by ernie b
Help! TURNIGY Plush 100amp Speed Controller underh2o2long Power Systems 3 May 05, 2009 10:32 PM
For Sale Turnigy Plush 100amp ESC w/ Prog Card rheumatical Aircraft - Electric - Power Systems (FS/W) 11 Feb 19, 2009 05:28 PM
Question TURNIGY Plush 100amp ESC + 7S or 8S A123 cdis Power Systems 2 Oct 16, 2008 09:03 AM
For Sale TURNIGY Plush 100amp Speed Controller markusvt Aircraft - Electric - Power Systems (FS/W) 0 Oct 11, 2008 09:07 PM
Discussion Turnigy 5065B and 100amp Plush ESC Combo N827TM Power Systems 5 Aug 09, 2008 02:51 PM
