Old Nov 19, 2013, 05:49 AM
Warbirds Lover
Dreamcatcher's Avatar
South of France
Build Log
Me-109 E - Mini PSS from scratch
Hi !
Since I had read an interesting thread here in RC Groups that was speaking about building a fuselage by using a hot wire saw, i wanted to give it a try.
The Messerschmitt Bf-109 and specialy the model E (Emil) is one of my favorite WWII fighter and i wanted to build one since a long long time.
i also seen the wonderful slope soaring videos of beautiful correx warbirds in these threads :
http://www.rcgroups.com/forums/showthread.php?t=1335350
http://www.rcgroups.com/forums/showthread.php?t=1445391
They achieved to turn me on !
Specifications :
As this project is my first try at building a fuselage using a hot wire saw, i wanted to keep the building cost as low as possible, that's one of the reasons why i chose a rather small scale for my Me-109 project.
The other reason is that unfortunately, the slopes near home are far to be as good and efficient as the South african ones.
Our slopes are paved with big rocks and small trees but they are good enough to allow light weighted foamy gliders to fly often.
We also have the chance to have a field where we can land our bigger gliders down the slope, but nothing above 2.50 meter span.
Results :
I fixed the Scale around 1:16
It given me : 59cm long and 65 cm span - stretched to 74 cm to increase wing surface.
Mid September :
i started once again my old "Turbo Cad-LE" to design my own Me-109
Early october : I started to cut the first templates
Dreamcatcher is offline Find More Posts by Dreamcatcher
Old Nov 19, 2013, 06:10 AM
Warbirds Lover
South of France
To build my templates, I used a die cut of 3mm mdf.
Well... i used what i had in stock, but i do not recommand to do the same :
The surface of the mdf stay rough even after sanding it with a super thin sand paper so the hot wire saw don't slide easily on them when cutting the foam and create some bumps on the fuselage parts... But Nothing which cannot be recorked by some filler anyway.
Old Nov 19, 2013, 07:05 AM
Warbirds Lover
South of France
I thought the canopy template would be an easy thing to do, but i was wrong : I spent a lot of time trying to find the correct outline of this paper template.
I hope to be able to build a clear canopy...
The front part of fuselage and the spinner are made with slices of 6mm Depron stuck on a 3mm mdf and 1.5 mm light plywood "skeleton".
The elevator is make with 6mm depron.
Old Nov 19, 2013, 07:26 AM
Warbirds Lover
South of France
The spinner was a bit too long and it did not pleased me.
I shortened it at a better size, then i started to build and add some "scale details" on the fuselage.
A clear Canopy have been cut but i still don't know how i will be able to stuck the front parts together.
May be i will try foam friendly contact glue or someclear silicone..
(any idea somebody ?)
To be continued...
Old Nov 19, 2013, 02:38 PM
Carlsbad, CA
Joined Sep 2004
Dreamcatcher
I dont know what glue you should use for a clear canopy but Keep posting pictures of your build. What is the expected weight ready to fly?
rockbus is offline Find More Posts by rockbus
Old Nov 19, 2013, 02:54 PM
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
canopy glue of course
http://www.ebay.com.au/sch/i.html/_W...sid=m270.l1313
steve wenban is offline Find More Posts by steve wenban
Old Nov 19, 2013, 04:09 PM
Warbirds Lover
South of France
Originally Posted by rockbus View Post
Dreamcatcher
I don't have a sharp idea of the final weight.
i would like to keep the wing load as low as possible...
At this time, the plane's weight is 66 gr. (fuselage + 3 rough wings pannels)
I would like to reach an AUW around 100gr but i'm rather sure that it will not be possible :
I plan to use a very light weigh Orange 2.4Ghz 4 channels DSM2 micro RX.(6gr)
1gr to 3.5 gr nano servos (3 at least - ailerons, rudder, elevator => i.e. it will add 10.5gr maxi)
I will need a 300 to 500mAh 1S Lipo (something like 20 to 30 gr i guess) to power the electronics
+ paintings / decals + push rods - may be 25 gr more ?
It depends also of the weight needed in the nose to balance the plane... The WWII warbirds generaly had heavy engine ...
it could be lighter if i use a "all in one" RX + actuators like the ones used in the E-flite micro models but... i don't have this parts in my stock parts
Thanks for your interest
Best regards
Old Nov 19, 2013, 04:21 PM
Warbirds Lover
South of France
@ Steve Wenban : Thank you very much, I did not know this glue.
I will try it, I found it on the European e-bay for something like 3 euros + shipping
Have a nice day
Old Nov 19, 2013, 06:51 PM
dutchydawg1's Avatar
Nor. Cal.
Joined Jan 2004
How Cool is that !
dutchydawg1 is online now Find More Posts by dutchydawg1
Old Nov 19, 2013, 07:11 PM
Carlsbad, CA
Joined Sep 2004
100 grs is very light.
Last year a few of us built ME109's
http://www.rcgroups.com/forums/showt...&highlight=109
Good luck with your build.
Old Nov 19, 2013, 08:23 PM
Works to Fly
Slopedaddy's Avatar
United States, CA, Tustin
Joined Sep 2007
The canopy glue will work great, as Steve said. It goes on white but dries clear. Holds well, too. Very nice build!
Slopedaddy is offline Find More Posts by Slopedaddy
Old Nov 19, 2013, 08:28 PM
Works to Fly
Slopedaddy's Avatar
Joined Sep 2007
Me 109
Here's one I'm working on. It's a Epp kit by DanWings in SoCal. It has a 30" wingspan and is a mean little PSSer at around 10oz. Pictured is Dans plane, the first one. I'll post mine in a few weeks when I finish it.
Old Nov 19, 2013, 08:50 PM
No fuse too fat
slopeiron's Avatar
USA, CA, Redondo Beach
Joined Apr 2002
Nice project! I've always loved the Emil. I just bought the ESM myself.
ESM BF-109E
Yes, it's a power plane. What can I say? It's addicting.
slopeiron is offline Find More Posts by slopeiron
Old Nov 19, 2013, 09:58 PM
Works to Fly
Slopedaddy's Avatar
Joined Sep 2007
Kyosho
OK, since a particular local group of excellent slopers has gone power, here's my Kyosho
E50 Kyosho,60", 6 cell, fast as hell, ME 109. I guess I need to get this one going again!
Old Nov 19, 2013, 11:44 PM
Dick J's Avatar
United States, CA, Lake Forest
Joined Jun 2008
Real slopers dont do power
Just kidding my friend
Dick J is online now Find More Posts by Dick J
Sold Rare Dave Platt Models kit ME-109 from 1980 CADILLAC200 Aircraft - Fuel - Airplanes (FS/W) 2 Jun 17, 2013 10:05 PM
Discussion Dynam ME 109 from Nitroplanes stuka Electric Warbirds 1 May 19, 2013 07:32 PM
Gallery ME 109 and mini me czechyour6 Your Plane Photos 0 Mar 19, 2005 10:39 AM
