Old Yesterday, 07:45 PM
fbsully993 is online now
Find More Posts by fbsully993
Joined May 2015
Question
battery charger
hello im looking for a charger that could run off of AC and DC [like a 12 volt DC car battery] but it also needs to charge at least 2 battery's i would prefer 3 but 2 would be fine also i would like it to be fairly cheap but reliable also what battery brand is your fave
fbsully993 is online now Find More Posts by fbsully993
Old Today, 12:32 AM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
There is only one choice. The HobbyKing Reaktor 300W. Forget AC power. Get a server power supply for around $25.
http://www.hobbyking.com/hobbyking/s...e_Charger.html
http://www.lipoconnectionsolutions.c...rgers-1244.htm
Even though you may think this is overkill you will appreciate the extra power with the ability to charge multiple batteries at the same time. With only a 12V power supply you realize less than the 300W power. It will still provide plenty and later on you can add another 12V power supply to get the full 300W.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Today, 10:12 AM
Joined May 2015
http://www.hobbyking.com/hobbyking/s...ktor%20charger
Glen
can you check both links for some reason i cant open them the hobbyking one says that it is an old webpage
Old Today, 10:20 AM
BigBadDogg is online now
Find More Posts by BigBadDogg
BigBadDogg's Avatar
United States, MI, Wyandotte
Joined Dec 2014
fbsully. This is a far better option without the added expence and cost of a parellel board.. 2 banks.. thats 2 10 amps chargers not one..http://www.horizonhobby.com/HRC44164...FY82gQodUIcAAQ
BigBadDogg is online now Find More Posts by BigBadDogg
Old Today, 10:36 AM
SilverSport is online now
Find More Posts by SilverSport
25th year Newbie
United States, LA, New Orleans
Joined Dec 2014
Sounds like you are looking for a New Toyota Corolla for 2 Grand!
I can't open those links either, but know what he is pointing you to.
In your OP, you stated a lot of what you want it to do, but none of the specs on the batteries so we can say that a particular charger will let you accomplish it. Let us know the specs on battery packs please. Number of Cells, mAh, Max charge rate - usually 1C - 5C.
As for the recommendation from ggcrandall1, I agree, spend the money now. I argue with guys at the field that say my iCharger is not a real charger and I should get a HiTec X4 or similar charger that is 4 chargers in one AC only, requires a expensive generator to run and costs $200 .... and can only charge the most commonly used cells in 1 hour because each of the 4 charge circuit can only support 50W, and probably half a day for a 6S5000. I can charge the same battery in 20 minutes from my $70 deep cell on my I Charger, and I can charge 4 at a time using A/C in about 30 minutes.
The problem with AC/DC chargers is you are usually limited to 50-80Watts Maximum. I have a 50Watt HiTec X1 ACplus, I love it, and I do most of my field charging from it. It can handle 2 3S 3000 in a little over an hour right below a 1C charge rate, I can do 3 500mAh 3S cells in 20-30 minutes on it from 3.7v. I bought it as a backup and it is worth every penny of the $70 I paid. It also is the charger I use to recharge my Deep Cycle Lead AGM battery.
SilverSport is online now Find More Posts by SilverSport
Old Today, 11:39 AM
Cyjonz is online now
Find More Posts by Cyjonz
United States, IA, Armstrong
Joined Jan 2014
Your not going to find a better charger for the money than this one. Same as link above that doesn't work. http://www.hobbyking.com/hobbyking/s...e_Charger.html And this power supply and you will be set. http://www.lipoconnectionsolutions.c...rgers-2462.htm
Cyjonz is online now Find More Posts by Cyjonz
Old Today, 12:06 PM
James_S is online now
Find More Posts by James_S
United States, WA, Woodinville
Joined May 2014
That power supply is massive overkill for what he's looking for though. Pretty much any cheap server power supply will work to charge his batteries from a Reaktor, sure he might eventually want to upgrade but server supplies are practically free. If you know anyone who works in the tech industry they generally are free.
James_S is online now Find More Posts by James_S
Old Today, 12:30 PM
USA, GA, Marietta
Joined Aug 2005
I corrected the links in post #2.
Glen
Question Can I charge a lipo battery through a lipo charger through a laptop charger? Littlesopwith Batteries and Chargers 12 May 14, 2015 01:58 PM
For Sale Losi Micro Quick Charger, Batteries, Wall Charger rockster567 Cars - Accessories (FS/W) 1 Apr 16, 2015 07:08 AM
For Sale Losi micro quick charger, wall charger and batteries rockster567 Cars - Cars and Parts (FS/W) 1 Apr 16, 2015 07:07 AM
Discussion Need a good battery charger for my 11.1v batteries felixthemaster Batteries and Chargers 0 Jan 17, 2015 12:21 PM
Discussion New USB battery chargers for 3.7v batteries DonRhone Electric Plane Talk 3 Jan 05, 2015 04:57 PM
