Old May 20, 2015, 10:52 PM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
What prop?
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old May 20, 2015, 11:05 PM
cloud9000 is online now
Find More Posts by cloud9000
United States, CA, Dublin
Joined May 2009
Originally Posted by quitcherbitchen View Post
What prop?
stock prop and motor.
cloud9000 is online now Find More Posts by cloud9000
Old May 23, 2015, 11:52 AM
Joined Jul 2011
I put the watt meter on my plane with a 13x6.5 apc two blade. It only drew 29.65 amps. I flew between this prop and the 12x8 apc two blade and really like the 13 overall. The watt meter does show I could go bigger on the prop. 14" maybe. Flew one 4s battery with a 11x10 apc and the battery was only slightly warm. No GPS on board but it must have been at least 67mph.
Old Yesterday, 01:37 PM
kevinsray2 is offline
Find More Posts by kevinsray2
Australia, QLD, Buderim
Joined Jul 2014
I was going to use the Zippy Compact batteries.. about 160g.
shouldn`t need any weight in front, right?
I tested and at 60mm balance, another 160g is required?
sound strange?
kevinsray2 is offline Find More Posts by kevinsray2
Old Yesterday, 01:39 PM
Joined Jul 2014
Originally Posted by simo71 View Post
Any of the turnigy 3' 2200's will do including the Nanotech's this series is made for them & out of the two durafly 1100's (t28 & P47) I have, both are spot on cg wise etc.
7 Minutes should be a comfy flight time, 6 if you are always up in the 3/4 to full throttle range. I fly low & slow to low & fast, loops, rolls etc etc & average from 6-7 minutes flights.
I am using Zippy Compact 2200`s which are 160g.
when balancing CG at 60mm, it seems I need another 160g..
this sound right?
Old Yesterday, 02:27 PM
Joined May 2009
sounds like you do need some more weight up front. I fly with Zippy 2800mah 4S 30C, which are 300g. no other weights added and flies fine.
Old Yesterday, 09:34 PM
Joined Jul 2011
Get your ESC further forward Kevin. Sounds like it is back a bit.
Discussion Durafly 1100mm P-51D Mustang anj4de Electric Warbirds 4846 May 25, 2015 10:26 AM
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 88 Apr 05, 2015 06:13 PM
Discussion Parkzone f4u corsair VS Airfield f4u corsair Hoopsta17_99 Electric Warbirds 54 Mar 16, 2012 08:11 PM
Discussion Comparison between FMS 1.4m Spitfire or Durafly HK 1.4 Spitire Fidy$Trainer Electric Warbirds 5 Jan 11, 2012 06:36 AM
Discussion HK 1100mm P-47 captjoey42 Electric Warbirds 2 Nov 04, 2011 11:43 AM
